| Cayman and Boxster Configurations This is the place to post your Cayman or Boxster spec or configuration or to compare one configuration to another. |
03-06-2009, 08:02 AM
$91,990 Cayman S!
I just priced out a new 2009 Cayman S configured how I'd buy it if it were up to me, and that's the price I came up with. A couple of things I couldn't figure out from the configurator were:
1) No sign of stitching anywhere, even checked 911 configurator, is colored/deviated stitching not being offered anymore?
2) The floor mats that were more than $400 do those have colored trim? It just said smooth leather trim, but it didn't say if it was say in speed yellow like the current generation Cayman can be ordered in.
03-06-2009, 08:14 AM
Re: $91,990 Cayman S!
Yup...they can get pricey really fast. I'm sure that would be a REALLY REALLY nice Cayman though...
03-06-2009, 08:29 AM
Yikes!.....I bet I could get one above $100k though!
The deviated stiching option always seems to show up a year or so after a new model/revision is announced, crazy.
I think $400 floormats would be frowned upon in todays economy though, you might want to leave those out.
03-06-2009, 08:35 AM
Yup, they have speed yellow trim in leather.
Cayman Club Outsider
Reason: Added photo
03-06-2009, 08:53 AM
Yeah that's the current generation Cayman or should I say first gen now, and I remember on the order guides it was pretty specific about bindings in various colors, but on the configurator it doesn't say so I wasn't sure if it was these floor mats again (which I like) or something different.
03-06-2009, 09:07 AM
That proves I like my current Speed Yellow Cayman S more and more every day.
 Having fun in Puerto Rico
03-06-2009, 09:48 AM
Ken
The dealers have the deviating stitching in their computers. There is also alcantara inserts for the seats as well. There are two choices of floormats, w/ leather trim or w/ colored trim. They are in the 911 configurator and I thought they were also in the Cayman configurator as well. The 09 CS I had originally configured was around $85-87K, w/ PDK, LSD, PASM, PSE, and SC totalling $10K alone. The car specifications below are not that much different than my 06 which had an MSRP of 73K prior to the addition of the Techart 19" Formulas. Dave
Cayman S $60,200
Exterior Color
Carrara White B4 $0
Interior Color
Black Full Leather
AT $2,385
Exterior
Grille in Rear Lower Section
XAU$390
Performance
Sport Exhaust System
XLF $2,500
Sport Chrono Package
639 $1,320
Limited Slip Rear Differential Lock
220 $950
Porsche Active Suspension Management ( PASM)
475 $1,990
7-speed Porsche Doppelkupplung (PDK)
250 $3,420
Wheels
19" Carrera S II wheel
419 $1,550
Wheel Accessories
Rims and Caps - Exterior Color
XD9 $1,390
Interior
Gear Lever Trim in Exterior Color
CDJ $295
Sport Chrono Timer Display Painted in Guards Red
CGG $500
Seat Belts - Guards Red
XSX $340
Sport Seat Backs Painted in Exterior Color
XSA $1,580
Leather Sport Seats
P77 $440
Interior Leather
Floor Mats With Colored Trim
Chosen color: Guards Red
CFX $425
Storage Compartment Lid with Model Logo
CUV $295
Porsche Crest in Headrest
XSC $285
Interior Carbon
Door Entry Guards in Carbon, Illuminated
CXD $1,280
Rear Center Console in Carbon
XMJ $1,625
Door Finishers in Carbon
XTL $2,150
Carbon Package
803 $890
Total Price* $86,200
03-06-2009, 10:29 AM
Coordinator
Yea, that's almost the same price I came up with. Which I guess is good becuase now I no longer have to think about 'upgrading' since I'll never be able to afford it!
I saw a picture somewhere with a leather rear center console (with nice stiching too) that looks awesome. I'm guessing that was an extra unfathomably expensive upgrade but I loved the way it looked. Esp since my rear center console somehow got all scratched up.
2006 Arctic Silver CS with SRP and LSD
03-06-2009, 10:52 AM
Wow! that's damn pricey considering for about the same money you could get a lightly used 997 GT3!
03-06-2009, 01:23 PM
Member of Northeast Group
Deviating stitching is available. "Custom Tailoring and Deviations - Other" pages 19, 20 & 21 in Cayman order guide
03-06-2009, 01:39 PM
The driver formally known as Torque
My total price, configured was $99,955. A lot of that though is cheeper to get as tequipment through suncoast. Aerokit for example.
Then we still need a roll bar, suspension + airlift (would be nice if we could order the GT3 airlift system for the cayman), clear engine cover, exhaust, flash... i think thats it...
03-06-2009, 02:01 PM
Kestrel Racing
Ya'll are nuts
Well, if you're going to insist on gold plated trim pieces, you're going to have to pay the price.
03-06-2009, 04:09 PM
btw airlift and the dynamic engine mounts on the GT3 will not be available until Sept 2009 earliest and I have only seen these on the German configurator so far
Current Cars:
2004 Atlas Grey - Boxster S
Buy me a Beer:
03-07-2009, 02:18 AM
Clearly out of my price range !
Augie
Sport Chrono,Seats & steering wheel, Xenon, Bose. JIC Cross coilovers, Mantis pulley & oil sump ext, Epiq p/s insulation, TR Motorsport wheels, Hoosier; BMC air filter, DCM harness bar, G-Force harness, Corbeau Forza II seat, Softronic Plenum & 4.1, Milltex headers & exhaust, Motorsport VOS
