| Cayman and Boxster Electronics Discussion of CD players, PCM, Sat Radio, iPOD and other electronic items. |
02-09-2010, 02:07 AM
Is it okay to solder a Battery Maintainer charger?
My battery tender cable got cut in half on accident. Is a solder connection safe enough to salvage the battery maintainer?
02-09-2010, 02:35 AM
Re: Is it okay to solder a Battery Maintainer charger?
Yes, so long as you insulate the soldered wire joints after.
2010 Cayman S, special build.
02-09-2010, 03:57 AM
End of story; close link.
Augie
Sport Chrono,Seats & steering wheel, Xenon, Bose. JIC Cross coilovers, Mantis pulley & oil sump ext, Epiq p/s insulation, TR Motorsport wheels, Hoosier; BMC air filter, DCM harness bar, G-Force harness, Corbeau Forza II seat, Softronic Plenum & 4.1, Milltex headers & exhaust, Motorsport VOS
02-09-2010, 06:55 AM
You mean we cant stretch out this thread?
Not that Im trying to but I see you dont have the desnork mod. It will help your mod combo (virtually the same power mods as my old 06).
02-09-2010, 08:48 AM
Insider
The easiest way to do this is cut the two wires in a staggered fashion. IE so each wire is separated by an inch or two from the other opposite polarity wire. Make sure the spacing is sufficient so that the bare wires don't touch.
____________X_____________________________
_______________________X__________________
Slip a piece of appropriately sized heat shrink tube over the wire now. You can get this at Radio Shack. Make sure it's just a little bigger than the wires. Most only shrink by a factor of 2. Also ensure it's long enough to cover both joints.
Twist the wires around each other as opposed to making a pigtail sticking out. Make sure you preserved the polarity otherwise you'll have a battery discharger. Solder both.
Slip the heat shrink tube up over both soldered joints and shrink it. A heat gun is best but the Rat Shack variety will usually shrink with a hair dryer. Done and it usually looks ok too without big lumps etc.
Les
02-09-2010, 11:50 AM
Or you can just use crimp connectors.
02-10-2010, 12:37 AM
Yes I do. Signature space is limited.
Augie
02-10-2010, 01:30 AM
Insider
And if you want a really hermetically sealed joint, solder the staggered joints, paint with liquid tape, then heat shrink for tensile strength. Then you can cover the joint with black vinyl electrical tape to minimize the visual effect.
Kenny
