LinkBack (18) Thread Tools Display Modes
  #121
Old 08-16-2008, 11:34 AM
Slatfatf's Avatar
Geek
Images: 261
Carpet & foam cover on rear wall of passenger compartment - 7.5 lb
This weight includes the plastic trim piece on top of the carpet.
  #122
Old 08-16-2008, 12:10 PM
kareldeeley's Avatar
'Yellow Peril'
Images: 17
You could Unbolt and remove the Front Trunk Cover, both Doors and the Rear Hatch...... Take the seats out and sit on the floor..............
Cheers Karel
  #123
Old 08-16-2008, 12:33 PM
Slatfatf's Avatar
Geek
Images: 261
The rear hatch is definitely on my list.
  #124
Old 08-16-2008, 01:06 PM
'Yellow Peril'
Images: 17
FF - I thought I was Crazy, until I met you...................
Cheers Karel
  #125
Old 08-29-2008, 04:42 PM
Slatfatf's Avatar
Geek
Images: 261
OK here's one that's too hard-core even for me (for now!)...
Cargraphic sells carbon fiber/Kevlar doors (Cargraphic | The classic and sportscar specialists | for Porsche - P87/P87S Cayman - Aerodynamic Tuning). Only 5.7 kg each, 1,500 Euros. An integral side-impact door beam is another 1.5 kg, and another 350 Euros.
I wonder how much weight is saved over the normal steel doors?
  #126
Old 08-31-2008, 04:56 PM
Slatfatf's Avatar
Geek
Images: 261
I did the lightweight battery installation today (see Lightweight Battery). My actual weight savings, including terminal adapters and all mounting hardware, was 36 lb. Total cost, including battery, terminal adapters, and mounting hardware, was about $100. So, for $100, you can reduce your Cayman's weight by about 1.2%, with a commensurate gain in acceleration, braking, and cornering. You can't beat this mod for cost-effectiveness!!
  #127
Old 08-31-2008, 05:16 PM
Bodhii's Avatar
Images: 109
The battery idea sound like a real winner! I think I will try it.
But every time I look at this fun thread, I wonder at what point have we just made the Porsche version of the Ariel Atom? LOL!
Seat of the pants dyno http://www.planet-9.com/signaturepics/sigpic5112_3.gif
Your Current Signature Picture
  #128
Old 08-31-2008, 05:50 PM
Slatfatf's Avatar
Geek
Images: 261
Only Clarkson is a big enough idiot to run the Atom on a track without a full-face helmet... setting a fine example for all his adoring fans.
  #129
Old 09-09-2008, 11:44 PM
Slatfatf's Avatar
Geek
Images: 261
Air Injection Pump - 2.5 lb
If you install a Motorsports Vapor Oil Separator (VOS), you have to do something about the air injection pump that is in the way. Either the pump must be hacked into with a saw or grinder to provide clearance for the Motorsports VOS, and then the hole patched; or else the pump can be removed. The pump's only purpose is to inject additional air into the intake ports during the first few minutes of operation to help the secondary catalysts in the exhaust manifold warm up faster. If one chooses to remove the pump, you'll save 2.5 lbs. No CEL will come on if you have the latest flash from Softronics. I don't know if you'll get a CEL or not with the stock flash.
  #130
Old 09-10-2008, 10:39 PM
sharkster's Avatar
Silver Sponsor
Those are so much smaller than the old 996 ones and probably weight half as much Smog guys won't like it but... they can't see it's gone either
  #131
Old 09-11-2008, 01:37 AM
Slatfatf's Avatar
Geek
Images: 261
Originally Posted by EstateWax View Post
Removing sprung weight, one pound, is like removing 4 pounds of unsprung weight. Buy magnesium wheels and carbon brakes. Use lightweight racing tires. Enjoying better braking and handling.
Uhhhhh.... isn't that backwards?? Unsprung weight is stuff like wheels and brakes (not riding on the springs). Unsprung weight reduction has the extra benefit, not sprung weight.
  #132
Old 09-11-2008, 01:46 AM
Slatfatf's Avatar
Geek
Images: 261
Originally Posted by jderiansf View Post
btw. if I drive my car every day, every other week, is that enough to keep a lightweight battery charged?
I've been trying out a lightweight battery as my almost daily driver for a couple of weeks now. It's summertime now, but even so the engine cranking is noticeably less powerful than what we're used to. But I'm sticking with it to see what happens...
EDIT: November 13, 2008. As an experiment, I tried leaving the lightweight battery installed in the car to see what would happen, instead of the recommended approach of swapping it in and out for track or AX days. The result was that the battery died a slow death over a period of about 10 weeks. During this time I drove the car normally - plenty of short trips, some long trips, some times where the car wasn't driven for a week, etc. I did charge the battery a few times - maybe once every 2-3 weeks. As the battery began to die some side effects cropped up. The clock would reset on every start, and sometimes the fuel gauge would read incorrectly.
The weight savings is fantastic, so I'll pick up another battery and swap it in and out for track and AX days. It only takes a few minutes.
  #133
Old 09-11-2008, 01:50 AM
Slatfatf's Avatar
Geek
Images: 261
Originally Posted by 4by4 View Post
Anyone care to comment about my idea to remove the underbody panels?
There must be a LOT of weight there.
I don't have a lift, so that's a hard one for me to try. But I agree that there's a lot of weight in the underbody panels, and removing that weight would be great for autocross!
  #134
Old 09-11-2008, 01:56 AM
Slatfatf's Avatar
Geek
Images: 261
Originally Posted by watrousmark View Post
How about replacing ALL of your nuts and bolts with Titanium nuts and bolts. The nice folks over at YOYODYNE would be glad to give you a discount on that many nuts and bolts. Now there would be some weight savings. Of course you would have the added benefit of a lighter wallet too.
YOYODYNE!!! I love it!!
"A screaming comes across the sky..."
  #135
Old 09-11-2008, 02:05 AM
Slatfatf's Avatar
Geek
Images: 261
Originally Posted by Amazin View Post
Fort, I just checked your original post re weight reduction as the best mod to improve performance. That may well be correct.
However, in my experience (50+years) the best way to improve autocross results is more seat time, do all the fun runs available and all the events you can.
Ride with some fast guys/gals whenever possible and have some of them ride with you. Most will be glad to help, at least until you start beating them.
Also read some autocross books and attend some schools when available. Like most sports, the more you do it the better you get.
All of which you probably know. The main point is to have fun!
That's really good advice - thanks!
Alan Jung, who is incredibly fast, has been kind enough to ride with me and let me ride with him. It was very helpful, and it made me painfully aware of how far I still have to go as a driver!
  #136
Old 09-11-2008, 02:10 AM
iremembercliford's Avatar
Images: 5
Not sure if this has been suggested already, but rather than removing all these little parts, why not just remove the entire engine, cut a hole in the bottom of the car and Flintstones it?
  #137
Old 09-11-2008, 03:52 PM
glenn's Avatar
Images: 33
Fort,
I have really enjoyed this thread. Thanks. I have been laughing my **** off.
I did not see removing ALL the carpet from the rear compartment. Its got 1 inch of heavy foam stuck to it. I removed it all from my car last year. It had to be 20 pounds+.
CaymanS Track Videos
2004 996GT3 / 1999 Boxster Spec Race Car / 2007 CaymanS Track Car
(Modified with parts from: 997GT3, 997GT3RS, 9967GT3, Porsche Motorsport, Tarrett, Mantis, Arlan, APRacing, Moton, Eibach, Tubi, Aasco, Quaife, TCDesign, Heigo, Fikse, Softronic,TeamTech, Traqmate, ChaseCam, Pagid, Rennline, SV Tek)
  #138
Old 09-11-2008, 03:57 PM
Slatfatf's Avatar
Geek
Images: 261
Originally Posted by glenn View Post
Fort,
Thanks, glenn!
I haven't really tackled the interior, yet. That would've bumped me up a class in the Zone 7 AX series. But now the season is over... Thanks for the suggestion.
  #139
Old 09-11-2008, 04:41 PM
sharkster's Avatar
Silver Sponsor
When I was drag racing the old 996TT a few years ago I tried all sorts of different ones but leaving the car undriven for a couple of days or so and the 'ol charger had to come out. The Braille does seem better than those Odyssey ones though for sure.
  #140
Old 09-25-2008, 11:38 AM
Wheel Center caps
since unsprung weight matters so much remove the Porsche center caps that must be 2-3 ounces....
LinkBack to this Thread: http://www.planet-9.com/cayman-boxster-modifications/24186-weight-reduction.html
Posted By For Type Date
Cayman S as a trackday car? Stripped/etc - Page 2 - Rennlist Discussion Forums This thread Refback 05-11-2009 10:35 PM
Are Porsche losing the plot? (Again) This thread Refback 11-27-2008 09:52 PM
Are Porsche losing the plot? (Again) This thread Refback 08-08-2008 10:16 AM
The Cayman Club This thread Refback 08-02-2008 12:57 PM
Are Porsche losing the plot? (Again) This thread Refback 07-27-2008 10:46 AM
Are Porsche losing the plot? (Again) This thread Refback 07-27-2008 08:37 AM
Are Porsche losing the plot? (Again) This thread Refback 07-26-2008 05:55 PM
Are Porsche losing the plot? (Again) This thread Refback 07-26-2008 02:11 PM
Are Porsche losing the plot? (Again) This thread Refback 07-26-2008 09:21 AM
Porkers.co.uk ::: Porsche Forum This thread Refback 07-25-2008 05:10 PM
Porkers.co.uk ::: Porsche Forum This thread Refback 07-25-2008 11:55 AM
Are Porsche losing the plot? (Again) This thread Refback 07-25-2008 11:32 AM
Are Porsche losing the plot? (Again) This thread Refback 07-25-2008 11:31 AM
Are Porsche losing the plot? (Again) This thread Refback 07-25-2008 11:25 AM
Are Porsche losing the plot? (Again) This thread Refback 07-25-2008 11:24 AM
Are Porsche losing the plot? (Again) This thread Refback 07-25-2008 11:19 AM
The Cayman Club This thread Refback 07-16-2008 08:09 PM
Cayman Modifications on The Cayman Club - Porsche Cayman Forums | BoardReader This thread Refback 06-17-2008 01:27 AM
