LinkBack (26) Thread Tools Display Modes
  23 links from elsewhere to this Post. Click to view. #1
Old 07-24-2008, 06:52 PM
Clutch delay switch defeated = joy!
Greetings folks - my wife and I just purchased our '07 Boxster S 2 weeks ago and I've been educating myself on everything I can get my hands on with this particular forum being most useful.
My issue is simple - during low loads (feathering the clutch up a slight incline or away slowly from say a drive through) I have a distinct metallic rattle/tink coming from the rear of the car. Initially it sounded like a loose exhaust clamp to me, but I finally narrowed it down to the clutch last night. It is very noticeable when backing up out of the garage, or where sound will be echoed back (parking garage, alongside a wall, etc).
I can replicate the sound 100% of the time by doing this :
- car started and idling
- transmission in neutral
- clutch in, slight revs (800 to 1200 rpm), so just above idle
By contrast, if I rev gently in neutral from idle without touching the clutch, all is buttery smooth.
But if I depress the clutch, disengaging it, just 100 revs up from idle and through 1200, there is a very distinct metallic rattle sound that actually sounds much more like exhaust noise than flywheel chatter. If I hold revs at say 1,000 and remove my foot from the clutch, the sound slowly goes away. Clutch back in while holding revs at 1,000 and voila, sound is back.
It doesn't happen any other time during driving and shifts are wonderful direct and smooth, so I've attributed it to just being a quirk of the car and not a real problem. But in the past few days it seems to have gotten louder and I'm uncertain that it's not a symptom of something else.
The car has 3,800 miles on it - 2,800 of them put on by a previous owner (we purchased the car from a dealer out of state). My first gut check is that the previous owner was a "clutch rider" and the throw out bearing is in less than fantastic shape. Usually however, a bad throw out bearing will squeal a bit and vibrate when clutched in, neither of which happen in my case.
I guess I'm looking to see if anyone else also has this sound with their car before dragging her up to the dealership. I've lightly lubricated the connecting rod on the transmission (shifter linkage) as that was rather "klinky" with the amount of play it had. I've read up on the clutch slave failures and pressure plate bolts and while I haven't ruled those out, I don't think that's the case (I intend to bleed the clutch this weekend which will give me a chance to inspect the slave mounting and snugness). My car was built in January of '07 so it looks to be a mid-year build.
If I'm honest, it almost sounds like an engine control version of BMWs much hated CDV (clutch delay valve). Various new Mazdas employ ignition retardation when the clutch is depressed to smooth out shifts (and preserve clutch life). I wonder if perhaps Porsche does something similar?
The next time anyone is backing up out of their garage, roll down the windows and give this a shot. Maybe they all do it, or maybe I need to meet my Porsche service advisor for the first time...
Cheers!
Old 07-24-2008, 09:05 PM
Seamus's Avatar
Images: 10
Do you have the PSE? Could be the valves in the exhaust system which open/close to produce a louder exhaust? Just a guess.
'07 CS, Meteor Grey, stone grey, 19" Carrera Sport with meteor grey spokes/polished rim, headrest crests, bi-xenons, Bose, power seats, rain sensor, fire extinguisher, heated seats, dimming mirrors, FabSpeed Maxflo II catback
'06 CLS 500, white, beige
'04 Black Ranger Edge
Old 07-25-2008, 12:35 AM
Nope, no PSE on the car. I did wonder if perhaps the vacuum hook up point for the car had come loose, as I imagine the 2007+ cars have a connection point capped if you don't have PSE, but I'm unsure of where to look for that.
Old 07-25-2008, 06:41 AM
I explored some more tonight and I'm even more uncertain now about what it is, or what's causing it.
It's the exhaust note changing for certain - nothing mechanical is rattling or loose. The same criteria applies in testing...clutch in, slight revs (or slip the clutch as you would when climbing a slight incline) and it's there and impossible to miss. Not the sort of note you want your new instrument to blare.
The best way I can describe it is....flat flatulence. The exhaust note on these boxers is fairly unique as it is, and some have referred to them as flatulent to begin with. But to my ears, when it's idling or in neutral (or of course at full song), it's a symphony and harmonious. The flat tone while slipping the clutch is certainly not normal.
Also, it's a narrow window. Idle = fine. 2,000 revs = fine. Anything in-between results in our new little gal cutting the cheese...
So, I'll keep looking. I noticed tonight that relative to the other cars in the stable, she was quite drippy when cold...a bit of exhaust vapor condensation when cold (rich) is normal, but I had a small puddle pouring out the back of the exhaust tips tonight when looking once again. The other cars may bead a bit on the tips, but nothing even close to what the Boxster is producing. Curious...tank of bad gas perhaps, but we're on our 4th tank now and the sound has been there more or less since we brought her home.
No codes either (code reader handy) - so if it's a cat on the way out, or perhaps something with the air injection pump, it hasn't gotten bad enough for the car to throw a flag.
I'll post what it is when we discover it for posterity.
Old 08-02-2008, 10:52 AM
I had a nice little "Eureka!" moment this evening and thought I'd share my findings.
First though, a quick history lesson.
My wife owned (briefly) one of the new MX5 PRHTs. Fun little car, but not our cup of tea. One of the first irks we discovered with it was that there was a rather peculiar amount of throttle lag post shift. This was very noticeable on brisk shifts from first into second under WOT. It felt like the car was holding back a bit for say a 2 count, then giving you what your right foot had originally requested. When really stomping the loud pedal from a dead stop, you felt it on the fist 3 shifts and it drove you MAD!
It felt this way, as it turns out, because it WAS this way. In an effort to extend the life of the clutch (and by association the entire drivetrain in general), Mazda engineered a software version of BMW's infamous CDV - clutch delay valve. The clutch in the MX5 triggered two switches. One switch, at the bottom of full travel, to indicate that the clutch was fully depressed to allow the car to start. A normal feature on all manual cars. But the second switch was the culprit - it resided at the top of the clutch arm and was always "IN" when the clutch wasn't depressed. So, when you pushed the clutch in, this switch would release "OUT" and the ECU would slightly retard timing for just under 2 seconds. This made for smoother (though laggy) throttle response from a dead stop in 1st gear, smoothed out the throttle uptake post shift for most drivers, and in, theory added life/miles to the clutch.
So WTF does this have to do with our 987?? I'm getting there...let me put this whiteboard away...
Our 987 has exactly the same arrangement as the MX5. I searched here and abroad (googleahem) and found nothing relating to this topic, so I'm bringing it up here in as much detail as I can muster at 4am.
It took me 30 seconds to verify that this is what I was hearing (as described in my first post) once I had the switch removed. Press the switch pin in while holding RPMs at 1,000 and the engine sounds (and is) normal. This is the state that the clutch is normally in (foot off the clutch, pushing this second switch pin IN) If you release the pin however while holding 1,000rpm and "Braaaaaappppp" - note change. Timing change. It lasts just at or under 2 seconds.
In the MX5, disconnecting this switch (or taping it shut to be always IN) resulted in a CEL after 50~80 miles. Nothing major, just the modern cars way of telling you that something was amiss. My scan tool resulted in, yup, "CLUTCH SWITCH ERROR" on the MX5 which was easily erased and reset. In that car, where HP and response was much more dear, it made a world of difference and was worth the slight inconvenience of having to hook up the scan tool every so often. In fact, I'd say that the acceleration times that magazines posted for that car were nigh impossible without having defeated the clutch delay switch. It was THAT intrusive in those first 3 upshifts under full giddy up.
In the 987, I'm guessing it will do the same (throw a CEL over time) but if we're lucky it will throw a soft code, store it, realize that it's not the end of the world and not trigger a CEL.
I drove 25 miles tonight with the switch taped IN (to replicate what position it is in during normal driving). As expected, the difference is dramatic. The flat engine note "Braaapp" when leaving a light in 1st gear with the top down (obviously a Boxster here but windows down in a Cayman would be very similar) is gone. Throttle response is very quick from a dead stop, which takes all of 4 stoplights to readjust to (to compare, think of non-sport to sport mode throttle response and it's similar).
Before the switch defeat, I had subtle but noticeable delays on moderate (low speed) low RPM shifts that are now gone. In my case, this always happened right around 3,000rpm under normal driving conditions (not too slow, and not having fun either) and because it was rather consistent in this regard, it felt like a brief surge or hiccup when it happened. What I was feeling was the clutch delay (just under 2 seconds).
So, to illustrate, you'd pull away from a stop in 1st gear, accelerate up through say 3,500rpm, shift into second, revs falling to 2,300 or so, and as you accelerated through 3,000, right at that point you would get what felt like a slight hiccup or surge. This didn't happen all the time, but was quite noticeable when it did happen.
As with the MX5, that brief hiccup or delay is gone making for very linear, smooth throttle take-up and response, post shift. I have a rather sensitive backside and if you're like me, you'll appreciate this change. Anyone who owns (or has owned) modern BMWs and has performed the CDV-ectomy will know what this feels like, pre and post.
The advantages for me are simple - the embarrassing and annoying "braaaaap" is gone, making for much more enjoyable 1st gear starts (as well as driving up any inclines, parking the car, backing up, and so on). And, of course, linear and smoother shifts.
The disadvantages for someone doing this are perhaps a slightly lower life expectancy of the clutch, the possibility of a CEL (check engine light) and/or stored "CLUTCH SWITCH" error and, quite probably, the lose of clutch triggered cruise control deactivation. If these things bother you, this probably isn't something you want to try.
But if you want to try a 30 second experiment to see how your car feels with this "feature" disabled, it's a piece of cake, and just as easy to restore if you don't like it.
To have your own little Eureka! moment, poke your head down in the footwell and peer up at your clutch pedal. Operate the pedal and observe the two switches - one beneath the clutch arm, and one at the top of the clutch arm. The one beneath the clutch arm will be pushed down (IN) as you push the clutch in. This switch is the "Have you pushed the clutch in yet, you sod?" switch before the ECU will allow you to start the engine. Ignore this switch.
The reddish switch at the top of the clutch pedal is the one you want. By pushing the clutch in, you will observe the pin releasing OUT as the clutch pushes in. When the clutch is up, the pin is pushed IN. The switch module is a sort of terracotta/red color. If you grasp it and turn it gently anticlockwise, you can remove it from the bracket holding it in place. You will see the pin is now out. All you have to do is tape that pin in (I wrapped mine end over end several times with black electrical tape) - you can use a zip tie or rubber band as well. Once you've taped it down, you can simply snug the whole bit behind the carpeted fuse panel surround trim (if you've done the Mods4Cars module, you know which panel I'm referring to). You can also probably push it back into the bracket, but this will weaken the tape in the fashion it was wrapped around end to end. Alternatively you could probably just disconnect the harness wired to this switch, but in the hopes that the switch being plugged in, just simply not used any longer, will not result in a CEL. Unplugging it may result in a CEL straight away.
Anyhow, if you're bored or curious to see how your car drives with this "feature" switched off, have a go and report back on what you find. I quite like it and intend to keep it this way, CEL or no. I'll simply keep my pocket scan tool in the door cubby and clear the code as needed. But here's to hoping that it simply stores a soft code and won't light up the dash after 100 miles (25 miles so far and no CEL).
What would be grand, if I may dream for a moment, is for someone like Scott at Softronic to see if it's perhaps possible to // this particular switch activity altogether, or perhaps ignore the error message (if generated) by having it disabled.
Keep in mind that this will make the throttle snappier off the line, so if you're clutch uptake challenged, this may frustrate you more than tickle you. On the other hand, if you enjoy full control over the tactile and feedback heavy controls of your car, you will quite enjoy this tweak. For me, it's a 50/50 affair...50% of my joy comes from no longer having the flatulent flat "braaaap" when parking/backing up or leaving a stoplight. It's not the most pleasing tone in the world and now I'm left with that glorious flat six arrangement, sans drunk trombone player. The other 50% of course comes from having linear throttle response post shift(s).
Apologies for the lengthy post here, but I figured I'd better explain myself if I was going to offer up a solution to my own question and go over the "why".
Cheers!
Old 08-02-2008, 10:56 AM
I posted a complaint/question regarding the flat "braaaap" I was getting with my 987 Boxster S. I discovered the cause of it and posted here - I figured I'd create a new thread with a title that actually captures the crux of what it was, versus my original post "Odd clutch rattle"
Link to original post...
http://www.caymanclub.net/cayman-com...tml#post285624
Old 08-02-2008, 03:36 PM
K-Man S's Avatar
Images: 2678
Pictures?
Do you have sport mode and did you try it in sport mode vs non-sport, I am wondering if in sport mode the ECU ignores the switch because I don't seem to get the effect you are talking about in sport mode but I'm curious if that's just in my head and it would be even more responsive with this modification.
K-Man S
Old 08-02-2008, 04:03 PM
Images: 13
I merged these two threads - no sense having both floating around on the same exact subject. People who posted to the thread will be looking for the same title.
Old 08-02-2008, 08:05 PM
Originally Posted by K-Man S View Post
Pictures?
Nope, sport mode doesn't ignore the switch functionality - I have the Softronic flash with sport mode on all the time and the switch continued to function in spite of it.
I'll snap some pictures and perhaps whip up a 5 minute article on this - currently, the thread title "Odd clutch rattle" may not draw in folks interested in learning about the clutch switch and how it functions and I don't think I can rename the thread title....
Old 08-02-2008, 08:46 PM
Images: 13
Changed title...
Old 08-02-2008, 10:56 PM
motionless's Avatar
omg I'm going to try this immediately. I absolutely hate the lag/delay/sound whatever it is in the Cayman when you try to go up ramps and inclines in first gear. I have to go up and around 2 levels of underground ramps on my way out from my garage everyday, and it is hugely annoying. When feathering the clutch up the ramp (sometimes I have to stop for other traffic) the engine feels like it has about 45hp or something!
Old 08-03-2008, 03:28 AM
Give it a shot and post what you think. The difference is immediate and very noticeable to me.
For what it's worth, I'm up to 60 miles without a CEL or stored soft code. So far so good.
Originally Posted by beez View Post
Changed title...
Excellent! Thanks Brad!
Old 08-03-2008, 04:00 AM
Banned
Nexus-6
Thanks for your post I am going to give your discovery a try and since your out front on this keep us posted on anything that comes from this mod.
Old 08-03-2008, 11:43 AM
phayd2black's Avatar
I find this thread very interesting but I thought of a quick question. Since you mentioned this could shorten the life of the clutch, do you think that there would be any issues with trying to cover warranty repairs? I think the clutch should be a covered item should it have major issues in a low mileage vehicle.
Old 08-04-2008, 04:14 PM
The clutch is considered a wear item and is not covered under warranty anyway unless it's due to a covered failure (e.g. clutch slave cylinder) or Porsche is covering it as a "good will" replacement.
Old 08-05-2008, 05:05 PM
blueyes's Avatar
Done mine and have covered 100 miles with no faults showing.
The car seems better and the only downside was stalling twice at traffic lights.
Old 08-05-2008, 07:34 PM
Nice research. I previously thought the "braap" was the oil scavenger.
Old 08-06-2008, 05:01 AM
Cleared 200 miles today - no CEL and no stored codes so far.
Throttle in sport mode with AC on full (105 Dallas heat) = touchy. You get used to it, but from a dead stop the throttle is now linear and sensitive meaning your immediate instinct is to back off when revs rise too rapidly (happened to me, too).
  #20
Old 08-06-2008, 05:54 AM
JCay's Avatar
aka 'Torque'
Images: 52
Very intrersting... do you think this has a noticable difference on acceleration?
0-60 times would be improved?
Thanks for posting this!
LinkBack to this Thread: http://www.planet-9.com/cayman-boxster-modifications/25405-clutch-delay-switch-defeated-joy.html
Posted By For Type Date
Clutch Delay Switch - Rennlist Discussion Forums This thread Refback 09-24-2009 03:25 AM
Better gear shifting - Rennlist Discussion Forums This thread Refback 09-21-2009 09:33 AM
Odio el CDV - Foro SoloPorsche.com This thread Refback 07-22-2009 10:18 PM
Very slight hiccups or surges in throttle smoothness - Rennlist Discussion Forums This thread Refback 06-27-2009 12:12 AM
potential boost for us slushbox owners? - Rennlist Discussion Forums This thread Refback 05-27-2009 04:00 AM
Rennlist Discussion Forums - View Single Post - 996 motor mounts This thread Refback 03-22-2009 02:17 AM
996 motor mounts - Page 2 - Rennlist Discussion Forums This thread Refback 03-19-2009 02:22 PM
996 motor mounts - Rennlist Discussion Forums This thread Refback 03-19-2009 07:25 AM
Bmw Boxer Cup, Bmw Black Grill, Bmw Brake Rotors - Startersolinoid This thread Refback 03-08-2009 08:54 AM
Sprint Booster installed on CS with Sport Chrono - TeamSpeed.com This thread Pingback 02-19-2009 01:27 AM
Sprint Booster Installed on CS with Sport Chrono - 6speedonline.com Forums This thread Pingback 02-18-2009 04:49 PM
Anyone Else Mod Their Clutch Delay Switch? - RennTech.org Forums This thread Refback 02-05-2009 01:51 AM
Anyone Else Mod Their Clutch Delay Switch? - RennTech.org Forums This thread Refback 02-04-2009 09:30 AM
Anyone Else Mod Their Clutch Delay Switch? - Rennlist Discussion Forums This thread Refback 01-09-2009 04:35 AM
Anyone Else Mod Their Clutch Delay Switch? - RennTech.org Forums This thread Refback 01-04-2009 10:30 PM
Anyone Else Mod Their Clutch Delay Switch? - RennTech.org Forums This thread Refback 12-30-2008 02:54 AM
Anyone Else Mod Their Clutch Delay Switch? - RennTech.org Forums This thread Refback 12-23-2008 05:31 PM
Anyone Else Mod Their Clutch Delay Switch? - RennTech.org Forums This thread Refback 12-16-2008 01:22 AM
RennTech.org Forums > Anyone Else Mod Their Clutch Delay Switch? This thread Refback 09-29-2008 01:13 PM
Anyone Else Mod Their Clutch Delay Switch? - RennTech.org Forums This thread Refback 09-14-2008 02:18 AM
Anyone Else Mod Their Clutch Delay Switch? - RennTech.org Forums This thread Refback 09-12-2008 05:06 PM
Anyone Else Mod Their Clutch Delay Switch? - RennTech.org Forums This thread Refback 09-12-2008 04:59 PM
RennTech.org This thread Refback 09-12-2008 03:59 PM
Anyone Else Mod Their Clutch Delay Switch? - RennTech.org Forums This thread Refback 09-12-2008 03:52 PM
Anyone Else Mod Their Clutch Delay Switch? - Rennlist Discussion Forums This thread Refback 09-12-2008 03:49 PM
The Cayman Club This thread Refback 08-04-2008 04:17 PM
