Re: Quick brake change help!
The ones that are together go for the front. You will notice one of the cylinders is larger, the orientation will become obvious when you take the old one out. Take the protective backing tape off. The small ones are for the rear brakes ( eight, 8, is enough) and they are all the same. I do not know the part numbers of hand, I am assuming you have a qualified parts supplier.
 Having fun in Puerto Rico
