Greetings all,
First, yes, I did use the search function. And didn't find the answer to this question:
In the quest for a) better and louder sound from the stock
PSE and b) eliminating the "power washer" sound at WOT and high rpm, does anyone know what the effect would be of removing the secondary cats from the mufflers?
Judging by that "power washer" sound, there must be some significant restriction in that muffler system somewhere. I recall looking at the photos of the internals (photos now unavailable apparently) which showed a pretty restrictive looking secondary cat. So I wonder if that's where the restriction is.
The
PSE looks like it has a fairly straight passage out the tail pipe after the cat, so that makes me think that perhaps removing the cat might be the solution. It won't affect the check engine light. We don't have sniffer tests here in
Texas. So I don't see a problem with that.
Now, if those assumptions are true, would it sound better?
Next, how would you remove them?
Get out the Dremel with a zillion little cutting discs and then find someone to weld the thing back together? Can a water jet cutter do it? Would regular welder guys know how to weld it back afterwards?
For that matter, once opened, would the cat just slide out or are we looking at radical catectomy?
Thanks for your thoughts, I do appreciate your time and attention.
- Mark
PS: Yes, I have thought of the
Borla as well so I wouldn't ruin a perfectly good
PSE, but I do like the switchabilty. It's just not loud enough...
