06-05-2009, 02:30 PM
Gen 2 Gen 1 Suspension
Plan on upgrading to PSS10's ( PASM)
I also plan on upgrading to a Gen 2 in the future.
A few Q's
Are the PSS10's the same for a Gen 1 and Gen2 ?
Same question re 996 Gt3 LCA's ?
thanks in advance
06-06-2009, 08:22 AM
Re: Gen 2 Gen 1 Suspension
Bump ............................................
06-07-2009, 10:15 AM
bump 123456
06-07-2009, 11:01 AM
Porsche Idealist
I would not think that going from PSS10s to Cayman Gen2 struts/shocks would be an upgrade if that's what you mean. Just purchase something that you can use long-term now without having to change 2 years down the road.
996 LCAs not the same, and I would not recommend them, think of 997 GT3 LCAs if you at want to, but why not go to Tarrett or GMG LCAs? Similar cost and better IMO.
FT
VitalMethods
06-07-2009, 11:43 AM
I thought he meant he wants to put PSS10s and GT3 LCAs on his gen1.
And he wants to know if he can transfer them to a gen2 when he gets one.
06-07-2009, 12:13 PM
Porsche Idealist
996 GT3 LCA's don't fit Gen 2 caymans? What a shame. Much cheaper than 997 GT3 LCA's. And Tarrett units ARE 996 GT3 LCA's. Don't know of any advantage of 997 GT3 LCA's
997 GT3 front sway bar
Quaife TBD
Hawk HP Plus pads
06-07-2009, 02:20 PM
Correct, I plan on upgrading to a gen 2 in the future. Ideally, I'd like to invest into something I can carry over.
where can I get prices on 997 GT3 LCA's ?
06-07-2009, 03:07 PM
My understanding is the 996 LCA's are a direct bolt on but 997 aren't? I haven't confirmed this about the 997 LCA but it seems like most people use the 996 on the CS.
Nitto NT-01 on Stock 18's (track), 19' Sport Design (street),PSS9's,Pagid RS-19,GT3 Seats,GT3 brake ducts, GT3 front Control Arms, 6pt Harnesses,Heigo Rollbar + TC Design Harness Bar,Remus Catback,Softronic Flash,Rennline pedels,Sharkwerks/Safecraft Extinguisher
06-08-2009, 09:43 AM
PCA / POC Member & Club Donor
Either the 996 or the 997 GT3 LCA will bolt in without a problem. The only difference is that the 996 has rubber mounts and the 997 has solid mounts.
The 996 LCA are much less expensive and allow the same adjustability, but will not be as rigid. Some race organizations only allow the installation of the 996 rubber mount LCAs (e.g., POC).
Neither Tarett nor GMG manufacture LCAs, they only re-sell the OEM parts through their websites, so they can not be any better. Ira at Tarett does make a monoball mount for the LCA, but not the control arm itself.
We set a new POC LI class record at Willow Springs this weekend (1:33.9) running the 996 arms so they can be that bad.
Cheers,
06-08-2009, 02:29 PM
I just got pricing on 997 Cup LCA's vs 996 GT3 LCA's
The cups were cheaper
Anything I need to know before I order em ?
Reason: gramma
06-08-2009, 02:35 PM
The cups were cheaper by a bit.
Interesting. Make sure your quote is for all necessary parts and not just for the arm. Other parts needed are the internal pivots, trailing arms, shims, hardware, etc.
Also, if you are going to use the arms for competition you should check and make sure the "cup" arms are legal in your class/club as many classes do not allow the solid mounts installed on the 997 or cup car arms.
Cheers,
06-08-2009, 04:00 PM
thanks Krokodil. i'm pretty sure it is the whole kit but I will call Farnbacher tomorrrow to make sure it is so.
The car is not being raced. just weekend track driving.
