06-08-2009, 10:12 AM
Camber plates vs. GT3 LCAs
Hi:
What are the pros of going with GT3 LCAs over camber plates. Camber plate solution seems as effective and much less expensive. Am I missing something?
Tomasz
Tomasz
06-08-2009, 11:52 AM
Silver Sponsor
Re: Camber plates vs. GT3 LCAs
We use the GT3 parts as they are tried and true(especially in our racing programs)... and they give us all of the camber adjustment we need.
Casey Parkin : Washington, DC
Tischer Porsche Sales | cparkin@tischer.com | 301.679.4384
TPC Racing Marketing/PR | cparkin@tpcracing.net | 410.799.7223
Tischer and TPC are two completely separate companies. I just happen to work for both. Please direct your questions to the correct email for me to contact you.
06-08-2009, 12:34 PM
Porsche Idealist
Originally Posted by Tomasz
Hi:
Tomasz
Yes. Camber plates get you about -1 degree more, for -2 degrees total. LCA's can go further negative and can also be used in the rear.
997 GT3 front sway bar
Quaife TBD
Hawk HP Plus pads
06-08-2009, 12:43 PM
OK, I am concluding that if I want racing performance and have a racing budget - go GT3 LCAs. For people on budget and on a street car plates should be more the sufficient. Front only, rear will still require LCAs if more camber is needed than available from stock parts. Cool. Now I need to decide if I should install these at the same time I install springs.
Tomasz
06-08-2009, 12:44 PM
Yes, install at the same time as springs or you will have to have your car aligned twice as opposed to once.
06-08-2009, 05:42 PM
Boxster Enthusiast
Camber plates increase your neg camber by moving the struts inward where the LCAs add the neg camber by moving the wheels outward giving you a little more stability. Mine go on next week. I think I'm going to shoot for -2.5 and -2.5. Does anyone one have a recommended agressive street/track alignment for an everyday driver?
Here's a good thread, look for wpmjr's post. LCA
06-08-2009, 09:00 PM
I have had -2.0 for a year, and I am planing to going with -2.3 with my next set of track tires. It will depend on how much street vs track driving you do, and if you use the same tires. If you use the same set of tires for track and street, you can get away with -2.5. I am starting to do more track events, and I have dedicated tires.
 Having fun in Puerto Rico
06-09-2009, 09:13 AM
There is also a potential NVH (noise-vibration-harshness) difference. My car is my daily driver, and I care how quiet and comfortable it is. I think that all camber plates have monoball mountings, so there is NO rubber bushing at the top of the strut. The GT3 LCA's retain the rubber bushing at the bottom and the top for a smoother ride. Along with more adjustability and a wider track, the LCA is superior in every way, but costs more.
If you are going full race, of course, you will want monoballs installed in the LCA's, and monoball camber plates...
....its even SAFETY YELLOW! What could be more practical???
06-09-2009, 10:45 AM
Good point on bushings. Monoballs will wear and rattle. No doubt about that.
Tomasz
06-10-2009, 05:41 AM
Member of Northeast Group
There is almorst no increase in noise & rattle with the Tarett camber plates. removing the rubber makes a big difference in turn in and getting the car to take a set. Unless you need more than -3 camber going with the camber plates for street / track use is a no brainer.
Midnight Blue CS...A couple of little tweaks here and there
