06-21-2009, 03:28 AM
Best mods for 05-06 Boxster S
I am condisdering moddding my low milage 05 Boxster S What are the best mods for these cars to increase HP and overall responsiveness?
Any insight would be much appreciated
06-21-2009, 04:12 AM
Re: Best mods for 05-06 Boxster S
Software!
2010 Porsche Cayman S PDK
06-21-2009, 04:47 AM
Boxster Enthusiast
Look at the Softronic special. They are selling a combo of exaust and software. Suspension mods would be the way to go, if you plan on going to the track.
06-21-2009, 10:18 AM
Dmn987s
+100% on that
You car will feel like a super car!!!!!!
06-21-2009, 06:29 PM
Thanks for the info,
It doesn't look like the Softronic mods are available for the 280HP 3.2 liter engine.
Also any plenum, throttle body and/or exhaust mods worth considering?
06-21-2009, 07:20 PM
Platinum Sponsor
The car is a 987 so the exhaust and Flash would work along with the Durametric.
Best,
Scott
06-21-2009, 08:51 PM
Thanks for the fast reply Scott
You will be on my short list. Any dyno charts available. I guess the percentage that your getting from the 3.4 987S could be extrapolated to the 3.2 987S
06-22-2009, 05:30 AM
Hello Scott,
I have a 2005 2.7 Boxster.....warranty just expired and i would like to see what my options are with you.
I have now on the car a Fabspeed exhaust and headers with no cats....what is my best option to maximize my hp...what would be my gains and total price of package if available?
I have sent a few message on the boards,and have not gotten a answer back,but i have seen you have answered other questions that came a day after mine....please get back me when you can....I am currently in Dubai,and the time difference makes it difficult for me to call.Will be back in the states later this week,but would like to get an order in process so items will be there upon my return.....recap..2005 Box 2.7 has already exhaust and headers with no Cats,would like to see what options you have that would complement these bolt ons..what is the price and HP gains...is there any specials for bundling items together?
06-22-2009, 06:22 AM
PCA Cayman Register Advocate
Stage 1: Intake, Exhaust and Software
Stage 2: Engine transplant. You can buy low mileage M97.21s (3.4L 987 engine) for around $5,000. I bet you can get good deals on the 3.6L 996 engines too.
Gator Bite
06-22-2009, 02:23 PM
Platinum Sponsor
GO TURBO!!!
An engine swap is possible, but even if you get your motor for $5,000 it will still likely cost close to another $5,000 to get the motor installed and properly running. For that cost we could Provide a Turbo Kit that will have you putting down over 400HP at the crank. For the the same cost or less than an engine swap we can provide you MORE power!!
06-22-2009, 02:53 PM
Originally Posted by Josh@TPCRACING
GO TURBO!!!
Correction... A LOT more power.
Gator Bite
06-22-2009, 03:02 PM
06-23-2009, 02:38 AM
Wow, I would have thought the 3.4L would go for more than that. Thanks Gatorbite. Any idea what a nice 997S engine would go for?
I guess the Stage 1 would make the most economic sense.
I would have no problem with a low boost turbo option except I hear about these intermdiate shaft horror stories. I'd worry that maybe the added stress would cause the bearing to go.
I really love my S but wouldn't mind a few extra ponies. Since the car only has 17k miles I am thinking that a engine transplant would make more sense than selling it and buying an 09. Plus I really like the GT Silver and full Cocoa leather which ain't cheap options on a new car. I wonder if the new Cayman DFI engine would cost more than 20k installed?
Again all who posted thanks for your thoughts.
DFI
06-23-2009, 05:16 AM
Life is a wonder.. my life that is!
Originally Posted by DrKareem
Software!
Ok Doc, you said software and somebody else said Turbo... I'd love to go step by step into from the software all the way to the turbo.
My question (seriously) is there any shop you know in Bahrain or KSA who can do any of the above? Would you trust them if it was your CS? Can you refer me to someone who tried them? And how much would it cost? Their website? ...etc.
My CS warranty will expire early next year... and I am giving serious thoughts to boost my gator into a real beast!
www.Hassaan.com
Mine: Cayman S '06
Mine: Land Cruiser '10
Bro's: GT2 '03
06-26-2009, 01:40 AM
Hey thanks for all the feedback. BTW who would you recommend that do engine swaps? Thanks
06-26-2009, 04:39 AM
Boxster Enthusiast
Where do you live?
06-26-2009, 05:24 AM
Platinum Sponsor
I would recommend myself  This way I would not have to get a phone call later on how to fix another swap that was not done correctly. I'm not saying other shops cant do this, I get phone calls daily stating , "Since my swap ... " or " Why doesnt it run correctly" etc.
Best,
Scott Slauson
