Re: Ticking noise from driver side tail light
I went to the dealer last Friday, and the shop foreman went with me on a ride and heard the ticking noise. He pressed on various driver side parts that he could reach from the passenger seat, but nothing made a difference. He said to bring it back on Tuesday for a service appointment.
Today I had the car at the dealer today for my service appointment. The invoice says "removed c-pillar trim panel, cover for rear, strut cover, rear wall trim panel, and rear oddments tray to inspect for signs of rubbing parts; found metal anchors for fastening screws to be gouging plastic, fitted felt tape between fastening points. also found metal catches for clips between spring strut cover and oddments tray to be slightly worn, applied felt tape accordingly. noted points of contact between all trim panels were slightly worn, applied felt tape and re-assembled for best fit. road tested with shop foreman, verified noise is no longer present. put a total of 6 miles on vehicle during road tests."
When I drove away, no ticking noise, but once I got closer to home I could hear the noises again, so I think what they did helped, but did not eliminate the problem. I'm not sure what to do now.
