Originally Posted by qualitech
if it fuel because of a poor filling station for instance water in the fuel, could that lead to long term engine damage?
if it's not fuel, what possible problems after 700km could occur to the engine?
thank you, sorry for too many questions.
zohar
assemblies) there is a higher number of failures early on, then this failure number drops quite steeply and stays very low for a long time, then the failure curve starts to rise again as old age starts to play a role.
The curve sort of looks like a bath tub viewed in profile.
If car under warranty your best plan of action is to get car to dealer for diagnosis and repair. It is probably nothing serious. A bad plug, coil, injector.
These are a few of the many other critical parts to an engine that all add their failures to the overall failure rate of the system.
Water in gas quite rare. Stale gas might be a possibility but the effect from this is usually transitory.
Get car to a qualified shop, OPC, Ithink is the term, and let the experts look car over.
Sincerely,
Rockster.
