Pagids are very popular for Porsches, but some here also use Performance Friction (PFC) 97 compound. For spirited road driving and autocross I still prefer OEM pads to track pads. Track pads need some heat before they reach optimum slowing rate, and they may squeal some under light applications such as normal driving and slowing. Pads are easy enough to switch at the same time one mounts track wheels/tires for track events.
I hesitate to answer for
KS-CS, but I suspect he means that track pads generate a higher slowing rate because they produce more friction or torque against the discs. That does generate more heat, but track pads are designed to handle the extra heat. The extra heat does transfer to the discs and brake fluid, however, so high boiling point brake fluid helps to manage the heat and prevent brake fade. I still don't know how to prevent discs from getting heat cracks, however.
