View Poll Results: Does your Cayman/ Cayman S have factory Carbon Ceramic Brakes?
Yes, I have the Carbon Ceramic (PCCB) Brakes
4 |
5.13% |
No, I have the steel brakes
74 |
94.87% |
01-31-2009, 03:27 PM
Who has Composite Ceramic Brakes (PCCB'S)?
I was just wondering how many members of the club have Caymans or Cayman S' that were delivered with the factory PCCB's from 2006 to present. If you would like to elaborate on your experiences with them please do! Check out the Poll!
01-31-2009, 04:34 PM
Re: Who has Composite Ceramic Brakes (PCCB'S)?
Don't have them, but at times I wish I did...
01-31-2009, 04:53 PM
No but I am working on it
Current Cars:
2004 Atlas Grey - Boxster S
Buy me a Beer:
02-01-2009, 07:42 AM
Porsche Spieler
Another no, and I'm not sure I can afford $20k for a rotor change
02-01-2009, 03:53 PM
Nah ... the yellow calipers would clash with my red and black paint scheme
02-01-2009, 06:11 PM
Yes, I do. No issues to date. 34K and still like new.
'05 Triple Black Boxster S
'01 Seal Gray Boxster
02-20-2009, 12:01 PM
They are half the cars fun !!
02-20-2009, 05:44 PM
No, but shall I get them next time round? I think yes.
2010 Cayman S, special build.
02-20-2009, 07:26 PM
Yup, got 'em.
Would not do it again.
Big time fluid boiling at DE mid-level driving ability.
Best advice to fix that, other than switching to SRF, was
to turn OFF the PSM.
My driving style is very smooth (so my instructors say) and
the PSM is continuously, yet unobtrusively, squeezing the
brakes and overheating the pads and then the fluid. The PSM will
only allow a certain tolerance of slip angle and will do whatever
it thinks it needs to to keep you from exceeding it.
For the price -- nope, not again.
If I could find some "cheap" iron ones to use for DE's, I would
change them.
Best,
- Mark
Rare Cayman Cabriolet S in Meteor Gray,
Cocoa top, Cocoa full leather interior, Sport
seats and steering wheel, PCCBs, PSE,
real Cayman 18 inch wheels and a delightful
3.4L engine with a new set of lifters which
seems to have solved the ticking noise.
02-20-2009, 07:29 PM
Mark sounds like something is wrong, does your car have sport chrono?
02-20-2009, 07:34 PM
I have about 24,000 miles on mine with no wear on them, not even any score marks! I have never had a problem with any kind of brake fade either even under prolonged hard, spirited driving. Of course, I drive that way with PSM off unless there is water on the road..
02-20-2009, 10:32 PM
Sounds like no sport mode so the PSM must be running in "nanny" mode.
Time for a Softronics ECU flash with sport mode upgrade.
02-22-2009, 07:37 PM
Ken,
Yes it does has SC and I always ran with it on.
The three dealers it has been to remain baffled as to why it has
this problem. It has had a new master cylinder and gallons of
fluid run through it.
It got MUCH better with PSM off, but the pedal was still not
solid and hard the way I think it should be at the end of the
session.
I have ridden with instructors, including one in a stock 2000
Boxster S (Pagid Oranges and Motul and R compounds), and
was astonished at how fast they can brake a car. Mine simply
will not do that.
Beats me...
- Mark
02-22-2009, 07:48 PM
Originally Posted by MarkinHouston
Ken,
session.
will not do that.
Beats me...
- Mark
Yes that does sound strange, and it sounds like they've replaced some of the likely culprits. Have you had a chance to drive another GT3 with PCCB's like yours and see if it was different? I've driven the GT3 RS with PCCB's and it didn't exhibit behaviour like what you described albeit I didn't flog it for an entire session because it was someone else's car. Are there other control units they can replace such as the ABC unit, etc? Maybe one of them is having some sort of issue? Hard to tell. It would be interesting to see if our PCCB's could be adapted to a Cayman though.
02-23-2009, 08:40 AM
Ken,
No, I haven't driven another. There is a Cayman with PCCBs who runs a lot of DEs and is very fast, much faster than I am. He runs stock tires and pads and has no braking problem (he says). (He does go off a lot and crashes now and then...)
I have spoken to GT3 guys with PCCBs and they have no problems,either.
The only other component in this car left that might be a problem is the ABS controller. I may be able to plead and whine enough at a dealer in Ft. Worth to get it changed as it might be considered a safety problem.
As I understand it, GT3s use an entirely different brake controller. It may even be adjustable for F/R bias, but I could be mistaken about that.
I have driven two Caymans at the track with regular iron brakes and both of them had soggy pedals, but neither guy complained about them. (This was just driving in the paddock,not at speed) Maybe I just expect too much, but as much as the magazines tout these as indefatigable brakes, that was what I expected to experience.
I still think something is wrong in this car but other than the ABS controller, there really is not anything else to replace.
Thanks for the thoughts, I do appreciate it.
All the best,
- Mark
10-19-2009, 02:27 PM
Lads i am trying to find the oem pads for PCCB anywhere?
Brakes where fine until i changed pads which i think they are not oem and something is very wrong after today's track day .
