Originally Posted by CaymanQT
Things like Bilstein Damptronic PASM, cat back exhaust, etc. Are we able to use it on the new cayman??
No one knows for certain, but I imagine many things will work on the V2 Cayman that already work on the V1, for example as far as I know the exhaust is unchanged, mounts the same way, etc.
PASM is still
PASM so Damptronic should continue to work as well, but I assume it will take manufacturers some time to get their hands on new cars and test on them.
