Old 02-05-2009, 08:37 PM
Coupe-de-Gras's Avatar
Images: 5
Original brake pad life
Just thought I'd pass this quality tidbit on...
Around the the 2nd week of of January my brake pad wear light came on for the first time. I had over 25,500 miles on the odometer (25,905 as of this post) and this was nearly 2 weeks shy of being exactly 3 years on my original set of pads (and rotors)! This is after driving and braking with a "spirited" attitude for that entire time, 3 autocrosses and 2 track days. Needless to say, I am greatly impressed. Btw, I am still driving with the pads and the wear light coming on, but I am driving as much like a conservative granny () as I can until I can replace them next month. Fyi, it's only the fronts wearing out, the rear pads still have a few thousand more miles left.
I'm curious, is this normal for Porsche pads or is it my driving style or not much track time or the mid engine physics or some combo of them? Regardless, all I can say is "wow..."
Old 02-05-2009, 10:29 PM
Images: 13
Re: Original brake pad life
Everyone drives/brakes differently, but what you describe is pretty normal. The sensor light comes on with about 2mm of pad left - about 20% - so if you really are going to take care of it in a month, there's no reason to worry - drive normally.
Old 02-05-2009, 10:32 PM
4by4's Avatar
Images: 21
Hey same here.
I just replaced my original pads and rotors prior at 40,000kms (25,000miles).
The service light had not come on yet, although it was very close. Ive done about 10 events and dont baby the car.
She's a beauty!
2010 Cayman S, special build.
Old 02-06-2009, 08:48 AM
gmsracing's Avatar
Mine are about done with 11k miles and 1 track day. I've got Pagid Yellows waiting to go on this weekend.
Nov 16, 2007 build:
Old 02-06-2009, 06:16 PM
KenRose's Avatar
I'm at 60,000 km's and my light hasn't come on yet.
Old 02-06-2009, 08:33 PM
My pads are just about done as well (46K mi) but for some reason my rear pads have worn out faster than my front???
Wonder if this is normal?
Did anyone else experienced this on a Cayman S?
I have about 30% left in the front pads and 10% left in the rear...
Old 02-06-2009, 11:21 PM
Original Pads died within 12k km with 2 trackdays 70+ laps x 5km.
Rotors died in 15K km 4 trackdays 140 laps x 5km
now for track only using Pagid orange. Stock pads cannot take the track.
Old 02-07-2009, 10:32 AM
blueyes's Avatar
I've never known a car wear the rears before the fronts.
Well there was one... but that had been clocked: mileage turned back.
Bought it from a BMW main dealer with 4k miles on it, got to 12k and the rear pads needed changing.
That aside, did you have the car from new?
If not, there's a possibilty that the previous owner has changed the fronts once already. Also the PSM works by braking each wheel as necessary so if you have been "drifting" with the PSM light flashing a lot it might wear the rears out first. Unlikely though.
Old 02-07-2009, 11:59 AM
uknick's Avatar
Are the rear calipers sticking?
Old 02-07-2009, 08:57 PM
ul2fly's Avatar
Images: 9
How many rear tire sets have you gone through?
PSM may have caused this, but you would know that by how often it kicked in.
Old 02-08-2009, 02:41 AM
On my car the rear pads wear at a uniform rate with the fronts. For a mid engined car, the rear brakes get worked hard too. I agree with you normally the rears have an easy time, but the 911 and Cayman are pretty special and have more rear brake bias.
Old 02-10-2009, 08:27 PM
Kenkg's Avatar
Insider
Images: 13
I changed mine at 16,ooo mi which included 270 miles of track. The sensor had not tripped yet, but were very close.
Kenny
Old 03-01-2009, 12:12 AM
jurnes's Avatar
I just burned through the fronts and rears in 4000 miles.
My Boxster S was new in Sept 08. The use of the car included 8 track days at Laguna and Thunderhill. I think I need to replace one rear rotor, as it was grinding metal to metal just to get home today.
The check brake wear warning came on while I was in Monterey at Laguna Seca today and the grinding started just after I left the track.
I would think that the pads should have lasted more than 4000 miles!?
Old 03-01-2009, 04:09 AM
Pint of Brew's Avatar
With 8 track days? It really depends on how you break.
Old 03-02-2009, 10:56 PM
jurnes's Avatar
Spent the day getting the rotors turned (still have 1 mm left before the minimum spec thickness of 22mm)
Because I went all the way to the end of the pads (rear inside pads) and almost to the end of the fronts, I had to buy wear sensors also.
The bill for parts: FR RR pads, sensors was $450.00! If I had gone to my local Porsche Dealer the cost would have been about $550.00 for pads and sensors.
The rotors were $30.00 for each end of the car. At least I did not need to replace them.
I could have saved at least $100.00 by ordering from SunCoast, but I needed to expedite the repairs.
I think I need to get into the Pagid Yellow pads for DE days. Who has the best deal for Pagid pads?
Old 03-03-2009, 07:54 AM
PistolPete's Avatar
Homewrecking Super Mod
5,000 post club
Images: 2229
For Pagid stuff, check with our sponsor Craig here:
www.RennStore.com -- The source for Pagid brake pads
Pete
2008 Meteor Grey Cayman S
Old 03-03-2009, 08:14 AM
Nick_USA's Avatar
Images: 100
Pete they are not the only sponsor that sells Pagid pads.
Automotion, TRG etc etc
Check out the Sponsor List here http://www.planetporsche.net/sponsors.php and shop around for the best prices but remember to mention Planet Porsche / Cayman Club when checking out.
Current Cars:
2004 Atlas Grey - Boxster S
Buy me a Beer:
Old 03-05-2009, 01:03 AM
jurnes's Avatar
Thanks for the input RE: Pagid retailer. I am getting the Pagids from TGR.
