Planet-9 > 987 Discussion Group (Cayman/Boxster) > Cayman and Boxster Tech » Boxster S Fabspeed Motorsports Muffler/Header Installation
LinkBack (11) Thread Tools Display Modes
  11 links from elsewhere to this Post. Click to view. #1
Old 02-17-2009, 03:37 PM
Joey@fabspeed's Avatar
Silver Sponsor
1. Lubricate all the bolts with a penetrating oil\ 13mm
2. Loosen the 4 nuts that hold on the 4” factory clamp
3. Then slide the clamp over towards the cat
4. Loosen the 2 nuts that hold the cats to the mufflers
5. Remove nuts on the bottom brackets that hold the muffler
6. Remove bolts on the 3 bolt flange where the headers meet the mid pipe
7. Remove the top mounts by taking off the 2 13 mm bolts and nuts that hold the top mount
8. Then carefully rotate the muffler facing the tip towards the floor the muffler will slide down and out the bottom
Josef Bock(Joey@Fabspeed.com)
283 North Main Street
Ambler, PA 19002-5065
215-646-4945, 215-646-9828fax
Visit us at: www.FABSPEED.com, www.YOUTUBE.com, www.FabForum.com
Old 02-23-2009, 12:48 PM
Silver Sponsor
Re: Fabspeed Motorsports Muffler/Header Installation
Here is a follow up detailing the installation of the Fabspeed Maxflo mufflers with secondary catalytic converter bypass pipes and polished tips.
1. INVENTORY OF PARTS
2. INSTALL THE FABSPEED BOX MOUNT TO THE TOP MOUNTING BRACKET
3. PUT THE 2.25" CLAMP ON THE PIPE THAT JOINS THE MUFFLERS TOGETHER; SLIDE THE MUFFLERS TOGETHER
4. LIFT THE MUFFLERS UP IN PLACE; this will take two people as one person holds the mufflers up against the top bracket and the other person puts the large band strap around the muffler through the box style hanger-->start the nut but do not tighten
5. INSTALL THE FABSPEED BOTTOM BRACKET TO THE MOUNT AND PLACE MUFFLER BAND STRAP THROUGH BRACKET--> do not tighten
6. PLACE THE 2.25" CLAMP AROUND THE MID-PIPE THEN INSTALL The 3 BOLT FLANGE SECTION ONTO THE PIPE
7. SLIDE THE MID-PIPE THROUGH THE CAR AND ATTACH THE 3 BOLT FLANGE TO THE HEADERS USING THE COPPER GASKET--> BOLT TOGETHER BUT DO NOT TIGHTEN. PLACE THE BACK OF THE PIPE INTO THE MUFFLER USING THE V-BAND CLAMP-->DO NOT TIGHTEN
8. TIGHTEN THE 3 BOLT FLANGE TO SEAL WHERE THE INLET PIPES MEET THE HEADERS, TIGHTEN THE CLAMP THATS JOINGS THE FLANGE TO THE AXLE PIPE
9. TIGHTEN ALL BOLTS STARTING AT THE BACK OF THE SYSTEM. THERE ARE TWO CLAMPS AROUND THE AXLE PIPES (Tighten all bolts starting at the back of the system clamps around the muffler all brackets working your way from back to front while adjusting everything to align the tips)
10. Last fine tune the tips by tightening them last making the appearance perfect.
Old 02-23-2009, 02:10 PM
Slatfatf's Avatar
Geek
Images: 261
I like the bellows in the connector pipe from the headers to the mufflers. All systems should have that, if for no other reason than to allow for differential thermal expansion. Nice...
Old 02-24-2009, 07:03 AM
Silver Sponsor
The bellows on the axle pipes also provide more adjustability when installing our Maxflo mufflers to ensure a proper fit and cut down on install time.
Old 02-24-2009, 05:55 PM
BillC's Avatar
Coordinator
Images: 80
I'm guessing that's a 986. Correct?
Having done a couple of 987 exhaust installs, that looks just a little different....
Old 02-25-2009, 08:20 AM
Silver Sponsor
Yes this exhaust setup is for the 986 Boxster/S 2000-2004 only. We redesigned the muffler brackets to reduce the resonance/drone by utilizing the stock mounts instead of the supplied brace on our previous system. The stock muffler mounts are designed to absorb vibration and decrease the resonance of the exhaust. The 987 Boxster/Cayman still uses the supplied brace and "A & B" mounting brackets.
LinkBack to this Thread: http://www.planet-9.com/cayman-boxster-tech/30351-fabspeed-motorsports-muffler-header-installation.html
Posted By For Type Date
986 Forum - for Porsche Boxster Owners and Others - How to remove muffler? This thread Refback 12-14-2009 11:15 PM
Band Muffler Clamp - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 12-12-2009 10:35 AM
986 Forum - for Porsche Boxster Owners and Others - How to remove muffler? This thread Refback 12-07-2009 08:46 PM
986 Forum - for Porsche Boxster Owners and Others - How to remove muffler? This thread Refback 12-02-2009 04:52 PM
986 Forum - for Porsche Boxster Owners and Others - How to remove muffler? This thread Refback 12-01-2009 06:46 PM
986 Forum - for Porsche Boxster Owners and Others - How to remove muffler? This thread Refback 12-01-2009 11:21 AM
986 Forum - for Porsche Boxster Owners and Others - How to remove muffler? This thread Refback 12-01-2009 10:57 AM
986 Forum - for Porsche Boxster Owners and Others - How to remove muffler? This thread Refback 12-01-2009 09:28 AM
Fabspeed Motorsports: 987 Cayman Porsche Maxflo Exhaust System This thread Refback 09-24-2009 11:45 AM
Porsche: 986 Boxster MAXFLO Exhaust, Catbypass Pipes This thread Refback 09-24-2009 10:53 AM
Band Muffler Clamp on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 06-18-2009 09:03 PM
