I am looking for instructions on how to remove the center Dome Light (above the rear view mirror) so I can get into the electrical and install my V1
radar Detector. If anyone can tell me how this is removed from the headliner and also how the Homelink transmitter is removed this would be very helpful!
I expect once these are removed there will be some wirinr in there that can be used to power the V1 when the car is on and off when not. The Rearview mirror wiring and the Homelink wiring are what I am looking into getting at for the switched 12Volts. The domelight wiring will not work, I jut need to get into the headliner.
I did this on my other BMWs (M3 and M5) very easily but do not know how to remove the dome light or Homelink. Please help and I will do a DIY series as it seems to be a common question - with most people wiring down to the fusebox which should not be required.
