Old 04-09-2009, 10:35 AM
titanic's Avatar
Images: 18
Resetting TCU
Does anyone know how I can reset the transmission control unit (TCU)? Does pulling out the fuse work? Where can I locate the right fuse?
Old 04-09-2009, 11:57 AM
Nick_USA's Avatar
Images: 100
Re: Resetting TCU
What are you trying to achieve?
Current Cars:
2004 Atlas Grey - Boxster S
Buy me a Beer:
Old 04-09-2009, 07:30 PM
titanic's Avatar
Images: 18
Re: Resetting TCU
I susupect my TCU has gone beserk. I want to try resetting it to see if it works, like rebooting a computer.
Old 04-09-2009, 08:11 PM
Images: 61
Re: Resetting TCU
There should be a fuse diagram in your fuse box. If not you can download one from the files section here. Disconnecting the battery will also reset everything. But why do you suspect your TCU has "gone berserk"? If you describe the problem maybe someone else has had similar issues and can help before you experiment.
Old 04-09-2009, 09:39 PM
KS-CS's Avatar
Super Moderator
Images: 247
Re: Resetting TCU
The Tiptronic Control Unit has a couple of fuse assignments: Row B8 and Row C5, however, I would also just disconnect the negative lead on the battery for a couple of minutes, to see if that accomplishes anything.
Old 04-10-2009, 07:31 AM
titanic's Avatar
Images: 18
Re: Resetting TCU
PSM, ABS, PASM all failing, gearbox in limp mode. Everything fine until I left the car idle for more than 3 months, battery completely drained. After putting in a new battery, this thing happened.
Old 04-10-2009, 10:55 AM
Images: 61
Re: Resetting TCU
Did you replace the battery with an OEM? Is it fully charged? How far have you driven since battery replacement? It takes a few blocks to get reset.
Old 04-11-2009, 09:09 PM
titanic's Avatar
Images: 18
Re: Resetting TCU
I am not sure if battery is OEM or not. My workshop did it for me. I have driven tens of kilometers. I pulled out all the related fuses for a day. The problems still there. The error codes I am getting are:
PSM: 4211 speed sensor rear right, C1 control module faulty
PAS: 8004 SC+, C1 control module faulty
PASM: C203 fault steering wheel, C1 control module faulty
Really scratching my head.
Old 04-12-2009, 07:57 AM
Nitro8472's Avatar
Porsche Spieler
Images: 41
Re: Resetting TCU
I'm sure u considered this, but why dont you just go to your dealer and have them worry about it?!
Old 04-12-2009, 08:17 AM
Images: 61
Re: Resetting TCU
Also noticed from another post that you have had a new steering wheel installed. Did this start right after that by any chance? Perhaps the steering wheel sensor was damaged? That could cause those problems.
As nitro said above the dealer is an obvious choice at this point.
For DIY try disconnecting the battery, waiting and reconnecting and go drive.
While you are doing that find out if you have a correct replacement battery in the car. It may be the wrong replacement or defective so who ever installed it should check it or replace it. However, your "workshop" should not have sent you out if the car was not working correctly so I'd be concerned about them. They may have also messed up a critical module of some sort.
Sounds like there may be more to this story than we know.
Old 04-12-2009, 11:06 PM
titanic's Avatar
Images: 18
Re: Resetting TCU
Car gone to dealer today. Immediately they called back to tell me they can't access the ECU, with their equipment? What the heck? It has nothing to do with swapping steering wheel. The problem was there all along.
Old 04-13-2009, 04:45 AM
luft911's Avatar
ZONE 1 Member
Re: Resetting TCU
Titanic, Sometimes when the battery has been dead or disconnected for a long period of time the gateway can loose it's coding and will need to be reprogrammed with PIWIS. From the fault codes and now the dealer saying they can't access the tip ecu, this may be your problem. Once the gateway ecu is reprogrammed, all the installed ecu's should be accessible again and be able to clear the faults stored. Good luck.
Old 04-13-2009, 09:29 PM
titanic's Avatar
Images: 18
Re: Resetting TCU
Spoke to dealer about your suggestion. They told me it was impossible. Even for cars left alone for six months. They need to run more checks and possible swap some of the DMEs. My car is a unique case according to them.
Old 05-16-2009, 05:01 AM
titanic's Avatar
Images: 18
Re: Resetting TCU
Latest update: my car is back after three weeks. Dealer went down wrong track of assuming faulty TCU. The hassle of sourcing a replacement TCU from head office is an absolute nightmare. In the end, it wasn't the TCU, and it wasn't any other control module, it was the wheel hub bearing at the rear sending wrong electromagnetic signals to the PSM. Heads up for any of you getting PSM/ABS CEL and transmission limp, check the wheel hub bearing.
I still don't know how the bearing got damaged.
Looking for LED rear light units to replace stock
Old 05-16-2009, 12:37 PM
Bearing may not be damaged just pickup weak....
and not getting strong reliable signal for wheel revolutions.
Sincerely,
Rockster.
