01-04-2012, 08:55 PM
 | PCA Member 500 post club | | Join Date: Sep 2010 Location: Arkansas
Country: | |
| Re: My new 2011 Cayenne Thanks guys and as you've said, I've driven more than she has.
It's a base V6, doesn't have PASM or any of the real cool performance stuff, but does have the Premium Package Plus, Anthracite, full leather, light package, tow package, 20" wheels, Tiptronic, Heated/Ventilated seats, Bluetooth, Nav, etc. I love it.
I've talked to Andrew ( KS-CS), he's had lots of great advise, and he had mentioned his V6 tows his Cayman quite comfortably, so I figure I was set.
We had looked at a 2008 Turbo and a 2009 S, but after my wife drove a 2011, she didn't even want to look at the older Cayennes.
I'm having a blast driving it!  |  |  |  | | PASM - Porsche Active Suspension Management |  | This active damping system offers continuous adjustment of individual damping forces based on current road conditions and driving style.
Need more information about PASM? Click this link: FAQ for PASM | |  |  |  |  |
__________________ Joe - 2007 Porsche Cayman S, 2011 Porsche Cayenne |
