06-26-2010, 11:56 AM
|  | Admin & Founder | | Join Date: Aug 2005 Location: Kansas
Country: | | Cayman Club Sport Gets Green Light! Stuttgart - Porsche has officially given the green light to a new lightweight Cayman model variant due to debut for the 2012 model year. The Cayman CS or "Club Sport" will be shown at the Los Angeles auto show later this year and go on sale in 2011 as a 2012 model. The CS will receive some of the same treatment given to the recent Boxster Spyder such as lighter weight components, fabric door pulls, and a uniquely styled set of lightweight wheels modeled after those on the GT2 RS. Recent press reports indicated that this new variant was shown to Sales Managers in US and Europe at recent internal Porsche meetings and given the positive response from their dealership network Porsche has chosen to move forward with production.
A number of technical items have been circulated internally among the team responsible for this variant and include the following:
333hp 3.4L engine
Sport PASM suspension - 20mm lower than stock ride height
A/C, stereo are optional
162-184lbs lighter than stock Cayman S
Aluminum doors, fabric door pulls
Lightweight hatch, optional lexan window (europe only)
19" unique lightweight wheels
Sport bucket seats
Revalved steering assist
Locking rear differential standard
Uprated brakes (optional)
Restylized front fascia
Cayman Club Sport side graphics
Rear diffuser
Ducktail-style larger rear spoiler (fixed)
Club Sport Insignia badging in interior
Optional "Track Pack", includes partial roll cage, harness and fittings plus fire extinguisher (europe only)
Cited performance numbers - 0-62 in 4.6s
Base Price: $66,330  |  |  |  | | PASM - Porsche Active Suspension Management |  | This active damping system offers continuous adjustment of individual damping forces based on current road conditions and driving style.
Need more information about PASM? Click this link: FAQ for PASM | |  |  |  |  |
06-26-2010, 11:58 AM
|  | Moderator Type-S  3,000 post club | | Join Date: Apr 2006 Location: CA
Country: | | | Re: Cayman Club Sport Gets Green Light! Too bad MEGA isn't here any more...he'd suck this news up
__________________ // Interpol / 2009 Cayman S / Carrara White // PDK / Sport Chrono Plus / PCM 3.0 w/ UAI / Full Leather / Bi-Xenon // Champion RG5 Monolite 18" / Borla prototype XR-1 catback exhuast / Eibach Pro-Kit springs / TiKORE titanium lug bolts
// 2006 Cayman S / Speed Yellow / 6MT / traded in 08.2009 |
06-26-2010, 12:15 PM
|  | Porsche Specialist 500 post club | | Join Date: Sep 2005
| | | Re: Cayman Club Sport Gets Green Light! Thanks Ken - sounds promising!  I was expecting -20mm suspension like Spyder, rather than Sport PASM like 997 option. Do you think this could be a miscommunication or do you really expect PASM?  |  |  |  | | PASM - Porsche Active Suspension Management |  | This active damping system offers continuous adjustment of individual damping forces based on current road conditions and driving style.
__________________ 1973 Carrera RS 2.7 Carbon Fiber Tribute (240hp and 1,890 pounds)
06-26-2010, 12:23 PM
| | | Re: Cayman Club Sport Gets Green Light! For perspective on the 0-100kph time of 4.6 seconds, the current Cayman S is conservatively rated at 5.2s with manual and 4.9s with PDK in Sport+ Mode and the new GT3 3.8 is rated at 4.1s. I would guess that the 4.6s time for the Cayman CS is with PDK Sport+ option...  |  |  |  | | PDK - Porsche Doppelkupplung |  | (FAQ in Process)
Derived from motorsport, PDK, available for the 911 Turbo for the first time, achieves one thing above all else: it provides the perfect balance between uncompromisingly dynamic performance and exceptional levels of comfort. It’s purely about point of view. The driver’s especially.
The optional PDK with both manual and automatic modes enables extremely fast gear changes with no interruption in the power flow. For improved acceleration and significantly lower fuel consumption – without having to dispense with the advantages of an automatic.
The driver experiences a sportier, even more dynamic drive with more agility. Depending on driving style, gear changes range from exceptionally comfortable to exceptionally sporty.
Manual gear changes are performed using the PDK’s ergonomically designed gear lever or the switches on the steering wheel: nudge forwards to change up, pull back to change down. The logic behind the optional three-spoke sports steering wheel with gearshift paddles comes from motorsport: pull to the right to shift up, pull to the left to shift down.
PDK has been specially tuned to the characteristics of the new 911 Turbo models. It has seven gears at its disposal. Gears 1 to 6 have a sports ratio, with the top speed being reached in 6th gear. The 7th gear has a long ratio and helps to reduce fuel consumption even further.
PDK is essentially two half-gearboxes in one and thus requires two clutches – designed as a double wet clutch transmission.
This double clutch provides an alternating, non positive connection between the two half-gearboxes and the engine by means of two separate input shafts (input shaft 1 is nested inside the hollowed-out input shaft 2).
The flow of power from the engine is only ever transmitted through one half-gearbox and one clutch at a time, while the next gear is preselected in the second half-gearbox. During a gear change, therefore, a conventional shift no longer takes place. Instead, one clutch simply opens and the other closes at the same time. Gear changes can therefore take place within milliseconds.
Clutch 1 controls the first half-gearbox, which contains the odd gears (1, 3, 5, 7) and reverse. Clutch 2 controls the second, which contains the even gears (2, 4, 6).
The optional Sport Chrono Package Turbo with dynamic engine mount system provides PDK with two additional functions, ‘Launch Control’ and ‘motorsport-derived gearshift strategy’.
PDK – sporty, comfortable and efficient. Characteristics that have been given some thought elsewhere too: in the specification for the new 911 Turbo models. | |  |  |  |  |
06-26-2010, 12:29 PM
|  | Porsche Chatter | | Join Date: Oct 2006 Location: MD
Country: | | | Re: Cayman Club Sport Gets Green Light! Sounds fabulous. I greatly admire my 2006 Cayman S, but the thought of about 13% more HP and perhaps 150 lbm less weight catches my interest.
I can do without the stereo, particularly if Bose has anything to do with it. But in my locale, Maryland, the AC would be a must...well, here goes some more weight., back on the chassis.
Based on your information, Ken, I would seriously consider a new Cayman S Club Sport. |
06-26-2010, 12:33 PM
Originally Posted by cjhaughney Sounds fabulous. I greatly admire my 2006 Cayman S, but the thought of about 13% more HP and perhaps 150 lbm less weight catches my interest.
Based on your information, Ken, I would seriously consider a new Cayman S Club Sport. | I wish it was 13% more HP - only 4%
I agree about A/C. It''s a must in a closed midengined car, unless you live on the Oregon Coast or something.
__________________ 1973 Carrera RS 2.7 Carbon Fiber Tribute (240hp and 1,890 pounds) |
06-26-2010, 12:40 PM
|  | Member of Northeast Group | | Join Date: Sep 2007 Location: New Jersey
Based on your information, Ken, I would seriously consider a new Cayman S Club Sport. | WOW So they are finally going to do it. If I were in the market for a exclusive track car I would do this is in a second...Sounds good...very curious about the fascia, diffuser and wing
__________________ JCO CST |
06-26-2010, 12:54 PM
Originally Posted by grant Thanks Ken - sounds promising!  I was expecting -20mm suspension like Spyder, rather than Sport PASM like 997 option. Do you think this could be a miscommunication or do you really expect PASM? |
You know I'm not sure, I'm seeking clarification on some of the points that seem a little rough, but again this comes from items circulating internally at Porsche, not from any official press release so the chances of getting someone to "verify" something in writing are pretty slim.
With regard to HP increase I think he was comparing to the 2006 S's 295 HP vs. the 2012's 333, which would be an increasse of 38hp, or 38/295 which is a 12.8% increase over the numbers in 2006, but yeah only 13hp more than the currently shipping 320. |
06-26-2010, 12:56 PM
|  | Member of West Coast Group | | Join Date: May 2006 Location: California
Originally Posted by grant I wish it was 13% more HP - only 4%
I agree about A/C. It''s a must in a closed midengined car, unless you live on the Oregon Coast or something. | well it is 13% if you're coming from a Gen 1 car with 295 HP (as the poster who originally wrote about 13% more HP is given they wrote about their 2006 CS)...... :^)
06-26-2010, 01:12 PM
|  | Site Donor  2,000 post club | | Join Date: Aug 2005 Location: Florida
Country: | | | Re: Cayman Club Sport Gets Green Light! I was told non PASM sport suspension to keep costs down. My source was also right about the Lexan hatch, but wasn't sure about whether it would be US or ROW only. I asked about colors and was told that hasn't been decided upon.  |  |  |  | | PASM - Porsche Active Suspension Management |  | This active damping system offers continuous adjustment of individual damping forces based on current road conditions and driving style.
Need more information about PASM? Click this link: FAQ for PASM | |  |  |  |  | |
06-26-2010, 01:23 PM
|  | Porsche Activist | | Join Date: Sep 2009
Country: | | | Re: Cayman Club Sport Gets Green Light! Cool car. Id like to see it get the Sport Classic Fuchs. Not sure its worth leaving a current Cayman S for one though. The improvements are marginal at best. The upgrade from a 2006 CS would be about $30-35,000 out of pocket. Just add an exhaust and a couple other items for $3,500 and reach the same results. As a person looking to get into a Cayman for the first time, rather than upgrade, it does look like a compelling option however. That said, Id never buy a new Porsche when you can get as-new 3yr old cars for half price, but thats just me.
__________________ 06 Cayman S | 88 911 Turbo | 86 944 Turbo (Past Life) |
06-26-2010, 02:08 PM
|  | PCA Member - Golden Gate Region | | Join Date: Oct 2007 Location: CA
Country: | | | Re: Cayman Club Sport Gets Green Light! Having both a 2008 CS and a new 2011 Spyder, I have to say this is great news for the Cayman. The Spyder is a whole different animal than either a Boxster or my Cayman and it will be a welcome addition to the lineup. |
06-26-2010, 02:11 PM
| | Porsche Chatter | | Join Date: Nov 2008
Country: | | | Re: Cayman Club Sport Gets Green Light! Yes, but does it have the oil sump problem? Can you go around a track counter-clockwise? |
06-26-2010, 02:42 PM
Originally Posted by clark666 Yes, but does it have the oil sump problem? Can you go around a track counter-clockwise? | There is no oil sump problem, there is an oil starvation problem on 2006-2008 models, but none on 2009+ so the answer to your question would be "no". |
06-26-2010, 03:37 PM
|  | Site Donor  1,000 post club | | Join Date: Feb 2009 Location: california,Grass Valley
Country: | | | Re: Cayman Club Sport Gets Green Light! Great! Hopefully a sign of more and better things to come
__________________ |
06-26-2010, 04:03 PM
| | Porsche Activist | | Join Date: Dec 2009 Location: CO
Country: | | | Re: Cayman Club Sport Gets Green Light! Can't wait to see it! I have an 09 CS so for the differences it is not worth trading it in for one but it might be tempting if cosmetically its different enough. As mentionned, a few grand in mods and a Gen II is as fast and you can probably buy the light weight wheels to add to it as well.
__________________ 09 Cayman S- Meteor Gray Metalic & Black Interior- Carrera Sport 19 wheels, Alcantara GT3 Steering Wheel, Alcantara Gear Lever & Handbrake, Rear Center Console in Aluminum Look, Alcantara Storage Lid with Logo, Side Strips with Model Designation, Spoiler Lips in Aluminum look, Bi-Xenon Dynamic Cornering lights, Bose Premium System, Heated Sport Seats, Sport Chrono, Colored Crest Wheel Caps. |
06-26-2010, 04:11 PM
|  | PCA Member 500 post club | | Join Date: Nov 2009
Originally Posted by K-Man S ....uniquely styled set of lightweight wheels modeled after those on the GT2 RS.......
19" unique lightweight wheels | Aren't the boxter spyder wheels styled after the GT2 RS wheels as well? |
06-26-2010, 04:22 PM
|  | Porsche Spieler 2,000 post club | | Join Date: Apr 2009 Location: N. Illinois
Based on your information, Ken, I would seriously consider a new Cayman S Club Sport. | CJ:
If you hate the Bose system in your car...STUFF IT! There is an article in the articles section. This really works, costs near nothing and takes 20 minutes to do. I promise it makes a night and day difference in the Gen 1 Bose system in the Cayman. The subwoofer enclosure in the passenger's side floor next to the center tunnel is made of plastic and is built like a cheap boom-box. This makes the bass muddy and it colors the sound of all the rest of the frequencies. When you stuff this enclosure with as much poly pillow stuffing (from craft stores) as will fit, the bass cleans up and all the other frequencies are better defined. The thing actually sounds good! If you look at the Bose components, they're pretty nice items. This plastic sub box is the villan here. Damp it well and the whole system works. One of our Cayman Club members is an acoustical engineer and came up with this. Another member also used some stick-on sound deadener on the walls of the sub box to further dampen it. I've tried that and it's another 10% improvement, but just using the stuffing is a 90% improvement. Cheap and easy.
__________________ -Sixisenuff
'06CS;Arctic/BlkStdLea;PCM2.1Nav;SC+;Bose/stuffdsub,gtwy500,iPod;ClutchDlyFix;udPulley;psCoo ler+wintrcover;gt3VOS;sumpExt;TTPOilsafe;MDSGrills ;18"ChmpRg5w235/40+265/40MichPSS;18"Forgestar+245/40&275/40NT01;18"BoxsterSRims+Pir240Winters235/40&265/40;HeigoRllBar;SptBuckets;Schroth6pt;SoftrncPlenm& 4.1flsh;TchartTUVcatbck;gt3LCAs;gt3scoops;tpcSwayb ars(quietlnks);PCCBmasterCyl;PASM/Dmptrnics;PgdYel+StockPds;StockRtrs;Motul600;FOR SALE:1newRecaroProfiXLw/slidrs+mounts,19"CarreraS/Nitto555/F235/35&R275/35;CDC4chngr;ROTTec sCGTF Seats w/Cayman mnts. |
Originally Posted by amdeutsch Aren't the boxter spyder wheels styled after the GT2 RS wheels as well? | Dunno, haven't seen them side by side. |
06-26-2010, 06:30 PM
|  | Porsche Chatter | | Join Date: Apr 2006 Location: Washington
Country: | | Re: Cayman Club Sport Gets Green Light! Please, Oh Please! tell me it wont get that god awful ducktail spoiler! I was waiting for a new track version but will not buck up if this styling feature makes the cut. (unless I can delete the option).
__________________ 2007 Cayman S
Arctic Silver, Full Leather -Blk,
19" Carrera Classic
PASM, Sport Chrono
Short Shift, Bi-Xenon
Sport Seats, Sport Wheel |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | |
