(http://www.planet-9.com/reviews/showproduct.php?product=295)
by: jderiansf
Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”. You’ll need to access the engine compartment to change the air filter, or install a custom intake etc. This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one: Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two: Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point. Now remove the key from the ignition, to prevent accidental operation of the top.Step three: Disconnect two tension rope the ball–pivots located on either side of the convertible top. Just pry gently, and they should pop right off. You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug). Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”.You’ll need to access the engine compartment to change the air filter, or install a custom intake etc.This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one:Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two:Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point.Now remove the key from the ignition, to prevent accidental operation of the top.Step three:Disconnect two tension rope the ball–pivotslocated on either side of the convertible top.Just pry gently, and they should pop right off.You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug). http://www.planet-9.com/gallery/files/7/3/8/8/fabriccover.gifStep four:Release the cloth cover.Gently pull straight down on the plastic cover, preferably right at the clip holders (there are two) one is shown below.By the way, that’s a “mid” strut bar. http://www.planet-9.com/gallery/files/7/3/8/8/clothclip.gifStep five:Lift the top up and grab the attached strap to secure the back of the top.I used a bungee cord to help.You just want to secure the back of the top so it’s out of the way. http://www.planet-9.com/gallery/files/7/3/8/8/topstrap.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap3.gif This is the access you’ll have after removing the speaker and carpet cover.Step six.Remove the Bose speaker by rotating the four black twist – locks.They secure the Bose speaker.Then you can rotate it to get better access to the plug connection. http://www.planet-9.com/gallery/files/7/3/8/8/boseconnection.gifWith the Bose speaker removed, the carpet cover should come right off.Now you have access to the bolts.There are 5 all around the engine cover.http://www.planet-9.com/gallery/files/7/3/8/8/coverbolts.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/coverbolts2.gifRemove these and voila, access to your engine!http://www.planet-9.com/gallery/files/7/3/8/8/engine2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/engine.gifPlease let me know if there are any other questions.Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”.You’ll need to access the engine compartment to change the air filter, or install a custom intake etc.This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one:Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two:Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point.Now remove the key from the ignition, to prevent accidental operation of the top.Step three:Disconnect two tension rope the ball–pivotslocated on either side of the convertible top.Just pry gently, and they should pop right off.You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug). http://www.planet-9.com/gallery/files/7/3/8/8/pivotball.gifStep four:Release the cloth cover.Gently pull straight down on the plastic cover, preferably right at the clip holders (there are two) one is shown below.By the way, that’s a “mid” strut bar. http://www.planet-9.com/gallery/files/7/3/8/8/clothclip.gifStep five:Lift the top up and grab the attached strap to secure the back of the top.I used a bungee cord to help.You just want to secure the back of the top so it’s out of the way. http://www.planet-9.com/gallery/files/7/3/8/8/topstrap.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap3.gif This is the access you’ll have after removing the speaker and carpet cover.Step six.Remove the Bose speaker by rotating the four black twist – locks.They secure the Bose speaker.Then you can rotate it to get better access to the plug connection. http://www.planet-9.com/gallery/files/7/3/8/8/boseconnection.gifWith the Bose speaker removed, the carpet cover should come right off.Now you have access to the bolts.There are 5 all around the engine cover.http://www.planet-9.com/gallery/files/7/3/8/8/coverbolts.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/coverbolts2.gifRemove these and voila, access to your engine!http://www.planet-9.com/gallery/files/7/3/8/8/engine2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/engine.gifPlease let me know if there are any other questions.Step four: Release the cloth cover. Gently pull straight down on the plastic cover, preferably right at the clip holders (there are two) one is shown below. By the way, that’s a “mid” strut bar. Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”.You’ll need to access the engine compartment to change the air filter, or install a custom intake etc.This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one:Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two:Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point.Now remove the key from the ignition, to prevent accidental operation of the top.Step three:Disconnect two tension rope the ball–pivotslocated on either side of the convertible top.Just pry gently, and they should pop right off.You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug). http://www.planet-9.com/gallery/files/7/3/8/8/pivotball.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/fabriccover.gifStep four:Release the cloth cover.Gently pull straight down on the plastic cover, preferably right at the clip holders (there are two) one is shown below.By the way, that’s a “mid” strut bar. Step five:Lift the top up and grab the attached strap to secure the back of the top.I used a bungee cord to help.You just want to secure the back of the top so it’s out of the way. http://www.planet-9.com/gallery/files/7/3/8/8/topstrap.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap3.gif This is the access you’ll have after removing the speaker and carpet cover.Step six.Remove the Bose speaker by rotating the four black twist – locks.They secure the Bose speaker.Then you can rotate it to get better access to the plug connection. http://www.planet-9.com/gallery/files/7/3/8/8/boseconnection.gifWith the Bose speaker removed, the carpet cover should come right off.Now you have access to the bolts.There are 5 all around the engine cover.http://www.planet-9.com/gallery/files/7/3/8/8/coverbolts.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/coverbolts2.gifRemove these and voila, access to your engine!http://www.planet-9.com/gallery/files/7/3/8/8/engine2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/engine.gifPlease let me know if there are any other questions.Step five: Lift the top up and grab the attached strap to secure the back of the top. I used a bungee cord to help. You just want to secure the back of the top so it’s out of the way. Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”.You’ll need to access the engine compartment to change the air filter, or install a custom intake etc.This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one:Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two:Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point.Now remove the key from the ignition, to prevent accidental operation of the top.Step three:Disconnect two tension rope the ball–pivotslocated on either side of the convertible top.Just pry gently, and they should pop right off.You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug). http://www.planet-9.com/gallery/files/7/3/8/8/pivotball.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/fabriccover.gifStep four:Release the cloth cover.Gently pull straight down on the plastic cover, preferably right at the clip holders (there are two) one is shown below.By the way, that’s a “mid” strut bar. http://www.planet-9.com/gallery/files/7/3/8/8/clothclip.gifStep five:Lift the top up and grab the attached strap to secure the back of the top.I used a bungee cord to help.You just want to secure the back of the top so it’s out of the way. http://www.planet-9.com/gallery/files/7/3/8/8/topstrap2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap3.gif This is the access you’ll have after removing the speaker and carpet cover.Step six.Remove the Bose speaker by rotating the four black twist – locks.They secure the Bose speaker.Then you can rotate it to get better access to the plug connection. http://www.planet-9.com/gallery/files/7/3/8/8/boseconnection.gifWith the Bose speaker removed, the carpet cover should come right off.Now you have access to the bolts.There are 5 all around the engine cover.http://www.planet-9.com/gallery/files/7/3/8/8/coverbolts.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/coverbolts2.gifRemove these and voila, access to your engine!http://www.planet-9.com/gallery/files/7/3/8/8/engine2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/engine.gifPlease let me know if there are any other questions.Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”.You’ll need to access the engine compartment to change the air filter, or install a custom intake etc.This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one:Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two:Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point.Now remove the key from the ignition, to prevent accidental operation of the top.Step three:Disconnect two tension rope the ball–pivotslocated on either side of the convertible top.Just pry gently, and they should pop right off.You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug). http://www.planet-9.com/gallery/files/7/3/8/8/pivotball.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/fabriccover.gifStep four:Release the cloth cover.Gently pull straight down on the plastic cover, preferably right at the clip holders (there are two) one is shown below.By the way, that’s a “mid” strut bar. http://www.planet-9.com/gallery/files/7/3/8/8/clothclip.gifStep five:Lift the top up and grab the attached strap to secure the back of the top.I used a bungee cord to help.You just want to secure the back of the top so it’s out of the way. http://www.planet-9.com/gallery/files/7/3/8/8/topstrap.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap3.gif This is the access you’ll have after removing the speaker and carpet cover.Step six.Remove the Bose speaker by rotating the four black twist – locks.They secure the Bose speaker.Then you can rotate it to get better access to the plug connection. http://www.planet-9.com/gallery/files/7/3/8/8/boseconnection.gifWith the Bose speaker removed, the carpet cover should come right off.Now you have access to the bolts.There are 5 all around the engine cover.http://www.planet-9.com/gallery/files/7/3/8/8/coverbolts.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/coverbolts2.gifRemove these and voila, access to your engine!http://www.planet-9.com/gallery/files/7/3/8/8/engine2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/engine.gifPlease let me know if there are any other questions.Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”.You’ll need to access the engine compartment to change the air filter, or install a custom intake etc.This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one:Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two:Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point.Now remove the key from the ignition, to prevent accidental operation of the top.Step three:Disconnect two tension rope the ball–pivotslocated on either side of the convertible top.Just pry gently, and they should pop right off.You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug). http://www.planet-9.com/gallery/files/7/3/8/8/pivotball.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/fabriccover.gifStep four:Release the cloth cover.Gently pull straight down on the plastic cover, preferably right at the clip holders (there are two) one is shown below.By the way, that’s a “mid” strut bar. http://www.planet-9.com/gallery/files/7/3/8/8/clothclip.gifStep five:Lift the top up and grab the attached strap to secure the back of the top.I used a bungee cord to help.You just want to secure the back of the top so it’s out of the way. http://www.planet-9.com/gallery/files/7/3/8/8/topstrap.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap2.gif This is the access you’ll have after removing the speaker and carpet cover.Step six.Remove the Bose speaker by rotating the four black twist – locks.They secure the Bose speaker.Then you can rotate it to get better access to the plug connection. http://www.planet-9.com/gallery/files/7/3/8/8/boseconnection.gifWith the Bose speaker removed, the carpet cover should come right off.Now you have access to the bolts.There are 5 all around the engine cover.http://www.planet-9.com/gallery/files/7/3/8/8/coverbolts.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/coverbolts2.gifRemove these and voila, access to your engine!http://www.planet-9.com/gallery/files/7/3/8/8/engine2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/engine.gifPlease let me know if there are any other questions. This is the access you’ll have after removing the speaker and carpet cover.Step six. Remove the Bose speaker by rotating the four black twist – locks. They secure the Bose speaker. Then you can rotate it to get better access to the plug connection. Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”.You’ll need to access the engine compartment to change the air filter, or install a custom intake etc.This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one:Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two:Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point.Now remove the key from the ignition, to prevent accidental operation of the top.Step three:Disconnect two tension rope the ball–pivotslocated on either side of the convertible top.Just pry gently, and they should pop right off.You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug). http://www.planet-9.com/gallery/files/7/3/8/8/pivotball.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/fabriccover.gifStep four:Release the cloth cover.Gently pull straight down on the plastic cover, preferably right at the clip holders (there are two) one is shown below.By the way, that’s a “mid” strut bar. http://www.planet-9.com/gallery/files/7/3/8/8/clothclip.gifStep five:Lift the top up and grab the attached strap to secure the back of the top.I used a bungee cord to help.You just want to secure the back of the top so it’s out of the way. http://www.planet-9.com/gallery/files/7/3/8/8/topstrap.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap3.gif This is the access you’ll have after removing the speaker and carpet cover.Step six.Remove the Bose speaker by rotating the four black twist – locks.They secure the Bose speaker.Then you can rotate it to get better access to the plug connection. With the Bose speaker removed, the carpet cover should come right off.Now you have access to the bolts.There are 5 all around the engine cover.http://www.planet-9.com/gallery/files/7/3/8/8/coverbolts.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/coverbolts2.gifRemove these and voila, access to your engine!http://www.planet-9.com/gallery/files/7/3/8/8/engine2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/engine.gifPlease let me know if there are any other questions.With the Bose speaker removed, the carpet cover should come right off.Now you have access to the bolts. There are 5 all around the engine cover. Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”.You’ll need to access the engine compartment to change the air filter, or install a custom intake etc.This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one:Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two:Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point.Now remove the key from the ignition, to prevent accidental operation of the top.Step three:Disconnect two tension rope the ball–pivotslocated on either side of the convertible top.Just pry gently, and they should pop right off.You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug). http://www.planet-9.com/gallery/files/7/3/8/8/pivotball.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/fabriccover.gifStep four:Release the cloth cover.Gently pull straight down on the plastic cover, preferably right at the clip holders (there are two) one is shown below.By the way, that’s a “mid” strut bar. http://www.planet-9.com/gallery/files/7/3/8/8/clothclip.gifStep five:Lift the top up and grab the attached strap to secure the back of the top.I used a bungee cord to help.You just want to secure the back of the top so it’s out of the way. http://www.planet-9.com/gallery/files/7/3/8/8/topstrap.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap3.gif This is the access you’ll have after removing the speaker and carpet cover.Step six.Remove the Bose speaker by rotating the four black twist – locks.They secure the Bose speaker.Then you can rotate it to get better access to the plug connection. http://www.planet-9.com/gallery/files/7/3/8/8/boseconnection.gifWith the Bose speaker removed, the carpet cover should come right off.Now you have access to the bolts.There are 5 all around the engine cover.http://www.planet-9.com/gallery/files/7/3/8/8/coverbolts2.gifRemove these and voila, access to your engine!http://www.planet-9.com/gallery/files/7/3/8/8/engine2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/engine.gifPlease let me know if there are any other questions.Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”.You’ll need to access the engine compartment to change the air filter, or install a custom intake etc.This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one:Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two:Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point.Now remove the key from the ignition, to prevent accidental operation of the top.Step three:Disconnect two tension rope the ball–pivotslocated on either side of the convertible top.Just pry gently, and they should pop right off.You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug). http://www.planet-9.com/gallery/files/7/3/8/8/pivotball.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/fabriccover.gifStep four:Release the cloth cover.Gently pull straight down on the plastic cover, preferably right at the clip holders (there are two) one is shown below.By the way, that’s a “mid” strut bar. http://www.planet-9.com/gallery/files/7/3/8/8/clothclip.gifStep five:Lift the top up and grab the attached strap to secure the back of the top.I used a bungee cord to help.You just want to secure the back of the top so it’s out of the way. http://www.planet-9.com/gallery/files/7/3/8/8/topstrap.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap3.gif This is the access you’ll have after removing the speaker and carpet cover.Step six.Remove the Bose speaker by rotating the four black twist – locks.They secure the Bose speaker.Then you can rotate it to get better access to the plug connection. http://www.planet-9.com/gallery/files/7/3/8/8/boseconnection.gifWith the Bose speaker removed, the carpet cover should come right off.Now you have access to the bolts.There are 5 all around the engine cover.http://www.planet-9.com/gallery/files/7/3/8/8/coverbolts.gifRemove these and voila, access to your engine!http://www.planet-9.com/gallery/files/7/3/8/8/engine2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/engine.gifPlease let me know if there are any other questions.Remove these and voila, access to your engine!Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”.You’ll need to access the engine compartment to change the air filter, or install a custom intake etc.This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one:Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two:Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point.Now remove the key from the ignition, to prevent accidental operation of the top.Step three:Disconnect two tension rope the ball–pivotslocated on either side of the convertible top.Just pry gently, and they should pop right off.You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug). http://www.planet-9.com/gallery/files/7/3/8/8/pivotball.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/fabriccover.gifStep four:Release the cloth cover.Gently pull straight down on the plastic cover, preferably right at the clip holders (there are two) one is shown below.By the way, that’s a “mid” strut bar. http://www.planet-9.com/gallery/files/7/3/8/8/clothclip.gifStep five:Lift the top up and grab the attached strap to secure the back of the top.I used a bungee cord to help.You just want to secure the back of the top so it’s out of the way. http://www.planet-9.com/gallery/files/7/3/8/8/topstrap.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap3.gif This is the access you’ll have after removing the speaker and carpet cover.Step six.Remove the Bose speaker by rotating the four black twist – locks.They secure the Bose speaker.Then you can rotate it to get better access to the plug connection. http://www.planet-9.com/gallery/files/7/3/8/8/boseconnection.gifWith the Bose speaker removed, the carpet cover should come right off.Now you have access to the bolts.There are 5 all around the engine cover.http://www.planet-9.com/gallery/files/7/3/8/8/coverbolts.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/coverbolts2.gifRemove these and voila, access to your engine!http://www.planet-9.com/gallery/files/7/3/8/8/engine.gifPlease let me know if there are any other questions.Description: The goal of this article is to show the step by step process to put a 987 Boxster into “maintenance mode”.You’ll need to access the engine compartment to change the air filter, or install a custom intake etc.This is only a guide, an I take no responsibility for errors, or problems with your car. But I will gladly make changes to the description, as necessary.Step one:Park the car on a flat surface, leave the car in gear, and set the parking brake.Step two:Open the convertible top approximately 24 inches; just enough to raise the rear cover to its highest point.Now remove the key from the ignition, to prevent accidental operation of the top.Step three:Disconnect two tension rope the ball–pivotslocated on either side of the convertible top.Just pry gently, and they should pop right off.You may need to remove the convertible top hinge covers (if not now then later to access the Bose speaker plug). http://www.planet-9.com/gallery/files/7/3/8/8/pivotball.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/fabriccover.gifStep four:Release the cloth cover.Gently pull straight down on the plastic cover, preferably right at the clip holders (there are two) one is shown below.By the way, that’s a “mid” strut bar. http://www.planet-9.com/gallery/files/7/3/8/8/clothclip.gifStep five:Lift the top up and grab the attached strap to secure the back of the top.I used a bungee cord to help.You just want to secure the back of the top so it’s out of the way. http://www.planet-9.com/gallery/files/7/3/8/8/topstrap.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap2.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/topstrap3.gif This is the access you’ll have after removing the speaker and carpet cover.Step six.Remove the Bose speaker by rotating the four black twist – locks.They secure the Bose speaker.Then you can rotate it to get better access to the plug connection. http://www.planet-9.com/gallery/files/7/3/8/8/boseconnection.gifWith the Bose speaker removed, the carpet cover should come right off.Now you have access to the bolts.There are 5 all around the engine cover.http://www.planet-9.com/gallery/files/7/3/8/8/coverbolts.gifhttp://www.planet-9.com/gallery/files/7/3/8/8/coverbolts2.gifRemove these and voila, access to your engine!http://www.planet-9.com/gallery/files/7/3/8/8/engine2.gifPlease let me know if there are any other questions.Please let me know if there are any other questions.
