How do you buff/wipe Wax off?
Results 1 to 17 of 17
Thread: How do you buff/wipe Wax off?
    Mar 2008
    417
    33
    I was curious, after applying wax, how do you remove it?
    I mean, do you simply use elbow grease and do it by hand?
    That's how I've been doing it so far, but since I own a PC, I was thinking if there's an attachment I could use to make waxing the car even more pleasurable
    NC/CA
    5,502
    1195
    1629
    What kind of wax are you using? If you are using a good carnauba wax you can easily apply it and remove it by hand.
    I have several orbital buffers and a PC. The only time that I ever use them is for cleaning and polishing. By the time I get to the wax stage I do everything by hand.
    2016 Cayman "Black Edition"
    2015 BMW R nineT
    NJ
    778
    You could definitely do some liquid waxes by pc if you'd like. Just depends what you'd like to use. Some that will work well by machine: EX Sealer Wax EXP collinite 845 insulator wax clearkote carnauba moose wax
    Just use a blk or blue pad to apply
    Buffers, Pads & Accessories
    Now, you could also do paste wax by machine, but I prefer to leave the wax in the jar and apply those by hand personally.
    Removal is always by hand w/ a quality mf towel
    Feb 2008
    Jacksonville, FL
    532
    34
    Quote Originally Posted by iqwertyi View Post
    I just put on 2 coats of the new P21S. I had read how different it was from other waxes but part of me really thought it was a bunch of hype. I decided to give it a try anyway with this new car and to my surprise it really did behave totally differently than any wax I had used before. Easy to apply, very easy to buff off with a microfiber towel, Minimal to no dust, and some how when I was done there were no little lines in all the creases of every panel. I think that it is just so easy to remove the towel gets it out of the little cracks without having to dig in there or use any pressure. Now the buffing is the easiest part of the job where before it was the part I dreaded.
    Try it, you'll like it. I got mine from Chris(NJ).
    Mar 2008
    417
    33
    I'm using the Poorboy's Blue Paste Wax.
    It's not too bad to take off. There is a little bit of dust that I see.
    I am using micro fibre towels to remove the wax currently.
    Unfortunately I just bought the poorboys, so I'd hate to dump it.
    Maybe if I get to use it half way, I won't feel too bad. Or just give it to my brother.
    My next wax will definitely be the P21S.
    To those using the P21S, are you using the 100% carnuba? or their other wax?
    I have to say, this is the first time in my life where I'm spending so much on detailing products. But, I guess there's always a first for everything.
    Mar 2008
    OR
    177
    I just applied the P21S-100 last weekend. At first I was a little perplexed as it was very dry and difficult to apply. Turns out that it needed to be warmed up (temp was in the low 60s). Just holding the container in my hand for awhile was enough to soften it up to the point where it became easer to use. It buffed off very easily. Next time I will wait for a little warmer day. The results were great.
    NJ
    778
    The nattys blue is definitely an easy wax to use, and does look great, so I wouldnt give it away just yet
    I know a lot of guys have picked up the 100% since it came out, so I think most will be referring to that, but cant say that for sure. HEres the link for reference.
    p21s 100% carnauba wax
    And dont worry,.. the detailing bug only gets worse
    96
    I have used the P21S wax for the last 10 years. Use it pretty regularly with elbow grease to get it on, and use a MF towel to the first layer off, and them finish it with cheesecloth. The more used the cheesecloth, the better.
    Feb 2008
    Jacksonville, FL
    532
    34
    Yes, 100% the grey topped plastic jar one.
    Quote Originally Posted by 4thtimeacharm View Post
    That sounds like a good idea I had a friend a long time ago that swore by cheese cloth. What is cheese cloth made of? What do you think of this Chris(NJ)?
    NC/CA
    5,502
    1195
    1629
    Quote Originally Posted by cheerIO View Post
    Cheesecloth should be 100% cotton gauze. I have never used it for taking wax off a car but it is often used in furniture refinishing (especially French polishing). It should work because it is a gauze type fabric and will not load up with wax. Just make sure that the cheesecloth is 100% cotton as polyester will scratch a finish. (I'm pretty sure that cheesecloth is 100% cotton. I just can't prove it.)
    On the other hand, a good microfiber cloth will work for removing wax and it will not scratch the finish.
    2015 BMW R nineT
    Mar 2006
    USA
    11,197
    2054
    3167
    106
    Quote Originally Posted by gfspencer View Post
    Cheesecloth is a bit old fashioned. It used to be popular 30 years ago for buffing off carnauba residue. Today, you may have trouble finding it at any automotive store. MF has taken over and is reusable.
    Further, with many modern waxes, they leave virtually no residue and "buffing" per se no longer exists. There is an amazing difference between "the old days" and today. I was using some carnauba liquid wax that was terrible to "buff off". Then go try some Mezerna FMJ and the difference is night and day. Bottom line, the days of hard "buffing" of the residue is long gone.
    For the OP, if you have a PC, you can buy some MF covers that go over a pad for the PC for "buffing" but I found it not worth the effort. It's just too simple to run some MF over the residue and it comes off easily.
    nc
    984
    Before I found this site I blew about 100 bucks at Autozone on fake Zymol and crummy microfiber towels that were useless after 2 washings. The concors look- (not 100%) P21S is perfectly good and I am very happy with the results. The paintwork cleaner is also excellent. I plan to buy the 100% stuff and use the concors look non 100% stuff on my other vehicle.Use the poorboys on your other car if you have one. From what I understand it's not that bad. This habit only gets worse.
    Feb 2007
    732
    ***** I've used carnuaba for years. Use one rag to take off the haze, another rag to buff it up, & when you're all finished, wipe the whole car down with a damp towel. It's also a good idea to have a soft detail brush for cleaning excess wax from hard to get places. Don't forget to open the doors,hood, & hatch to wax around the edges of them. Same goes for the edges of the wheel well openings. It's a labor of love. Hug your Porsche today.
    Mar 2008
    MA
    202
    Exclamation Correct Wax Application & Buffing
    Please put the PC down. NOW!
    It's not really that hard. In fact, you've already have most of your work done! Use a good quality microwipe, which forces the wax to bond to the paintwork. Then a good quality towel to buff when you finish. Voala! A masterpiece!
    Stay away from the cheapo big-box store towels and microwipes as they can often scratch and usually contain sizing. Wash your detailing towels and microwipes separately, and DON'T use dryer sheets. They contain sizing, which causes streaks.
    Check our FREE online detailing guide at Detailbest.com detailing your car. And Happy Mothers' Day to all the Cayman Club moms!
    Best regards,
    Roger the Waxmeister
    Roger at Detailbest.com
    Because It's OK To Love Your Car!
    Dec 2007
    250
    59
    Maguires Gold class, truly is awesome, okay it is mainstream but makes the paintwork look like glass, Sometimes i use Autoglym as it make the red stand out i feel.
    James
    99DC2 Honda Integra typeR 00 Audi TT 180 coupe
    02 DC5 Honda Integra typeR 01 Alfa Romeo spider 3.0 V6 01 Honda s2000 03Audi TT Roadster 225
    02 Porsche Boxster S
    07 Porsche cayman BORLA 4" EQUIPED
    Feb 2008
    PA
    43
    Gamertag: The Vee
    I use the Zaino bro's products and they wipe off really easy with just a cotton towel. Minimal effort to remove.
    Mar 2006
    USA
    11,197
    2054
    3167
    106
    I used a PC and Menzerna FMJ today and there was really no buffing at all to do. There was virtually not residue at all. It's a far cry from "the old days"
    Anybody got some Blue Coral
  20. Remove Advertisements
  1. How do you change those little browser icons?
    Last Post: 02-22-2009, 01:27 PM
  2. How do you maintain between wash/wax?
    By iqwertyi in forum Porsche Care and Detailing
    Last Post: 05-04-2008, 11:47 AM
  3. How do you turn off Radio AM/FM?
    By tian6869 in forum 987 Cayman and Boxster Electronics
    Last Post: 03-21-2008, 03:32 PM
  4. How do you describe the Cayman S?
    By psycho in forum 987 Cayman and Boxster Chat
    Last Post: 01-01-2006, 11:41 AM
  5. How do you connect a tire trailer?
    By DavidNJ in forum 987 Cayman and Boxster Competition
    Last Post: 11-12-2005, 08:29 PM
