Recommendations on removing scratches on headlight lenses
Results 1 to 7 of 7
Thread: Recommendations on removing scratches on headlight lenses
    Jul 2006
    Culver City, CA
    260
    I'm curious what people are using to polish the plastic headlight lenses... Mine are getting pretty scratched (no clear bra), and I've decided to do something about it. I'm soliciting advice from those who've actually removed scratches from the plastic lenses (front or back).
    My first idea was to use my old standby plastic polish Meguiar's #17. About the only thing I've used it for is removing scratches and hazing from CDs. I tried it on one of the lenses, a bit timidly I admit, without much luck. I don't want to make it worse by fogging the plastic.
    Again, I'm looking for a polish to remove scratches, not just a cleaner...
    Any advice?
    NJ
    778
    You can do one of the ssr polishes or optimum polishes. As long as the lenses you're trying to clean up are plastic/polycarbonate, and not glass, they'll usually clean up pretty well. You can do so on an Yellow (better for headlights and not tails, as taillights are usually softer) or orange pad (or white if you prefer a lighter cut at first). I've done some lenses with the cordless drill bit attachment. Put the 4" pad on the attachment, then apply a small amount of product to the pad and work it in to the lense.
    If you have a dual action/random orbital machine (or other), you can use that just as effectively.
    Heres some links to check out.
    Attachment and pads:
    Buffers, Pads & Accessories
    polishes:
    Polishes, Swirl Removers, Paint Cleaners & Compounds
    You can top it off w/ a sealant to help w/ UV protection too. I'd go optiseal. Its very versatile... use it on lenses, wheels, paint... truly great product.
    Opti-Seal
    NC/CA
    5,397
    1126
    1542
    zymöl makes a good plastic cleaner. For me, it works better than the Meguiar's stuff. (Meguiar's is good. I use it. I just think the zymöl stuff is better.) I use it on the windscreens of my motorcycles to get rid of scratches.
    2016 Cayman "Black Edition"
    2015 BMW R nineT
  5. #4
    Jan 2008
    London
    136
    43
    Novus polish is incredible and will restore the heaviest of scratches back to a glass finish. See this link:
    Novus Plastic Polish and Plastic Scratch Remover
    It is produced in the US so should be easy for you to get.
  6. #5
    NC/CA
    5,397
    1126
    1542
    Quote Originally Posted by Tonysim View Post
    Yep, I forgot about Novus. I've got some in my shop. It's very good.
    Plexus Spray is very good for cleaning off bugs, etc. It won't do anything for scratches because it is non-abrasive.
    2015 BMW R nineT
  7. #6
    Feb 2007
    732
    You might want to try "Kit Scratch Remover" from your local auto supply store. It's for painted surfaces but I've used it to remove scratches from non-crystal watch faces. Very mild & easy to use by hand.
    Another thought...There are pros who do this sort of clean up. It was a big problem on older VW's where the headlight covers turned yellow with age. I think the cleaning can only be done one time...than it's new covers. Ask your dealer or a body shop.
  8. #7
    Jul 2006
    Culver City, CA
    260
    I've ordered some Novus 1 & 2 and will report back with the results when I have them.
    Thanks for the suggestions!
  9. Remove Advertisements
  1. Question Scratch on bumper at delivery
    By MPETRO16 in forum 987 Cayman and Boxster Chat
    Last Post: 10-08-2008, 05:27 PM
  2. Paint chips/scratches on my front facia/bumper, Help plz!
    By Mrmz1 in forum Porsche Care and Detailing
    Last Post: 06-26-2007, 10:34 AM
  3. Scratches on Armor Clear Coat
    By Toona333 in forum 987 Cayman and Boxster Chat
    Last Post: 02-15-2007, 08:31 AM
  4. scuff/scratch on front plastic lip spoiler..
    By new06cayman in forum 987 Cayman and Boxster Chat
    Last Post: 02-14-2007, 02:19 AM
  5. Scratches on Passenger Door
    By fulbie in forum 987 Cayman and Boxster Chat
    Last Post: 05-02-2006, 04:21 PM
