stubborn brake dust removal?
Results 1 to 7 of 7
Thread: stubborn brake dust removal?
    Jan 2008
    PA
    782
    36
    70
    33
    I have the 19inch sport design wheels, love them, and for the most part they look great, but on the front wheels, in some of the corners there is very stubborn brake dust that seems not to budge no matter what...I've used ps21 spray with no luck....anyone have any other suggestions that might help with the removal.
    appreciated
    Jun 2009
    Re: stubborn brake dust removal?
    Quote Originally Posted by saucerman View Post
    appreciated
    Sprays work great but it sounds like you need a gel supported by agitation. We've developed a wheel cleaning gel that clings to a wheel's surface long enough to get the job done.
    Take a look at our Gloss-it Signature Wheel Gel. Simply spray on your wheels when they are cool to the touch and let it sit for 30-60 seconds - longer if need be. Feel free to use a soft boar's hair brush (coming this week to our store) to help break up hard and older deposits.
    It's safe for every type of wheel finish under the sun and even cleans your rotor hats and calipers!
    Now available in 4oz sample size!
    http://www.gloss-it.net/Glossits22ozSignatureWheelGelCleaner-idv-158-23.html
    1,558
    The corners where each spoke joins the rim are notorious for collecting brake dust and dirt. Unfortunately, the Sport Designs have 15 spokes, so there are 30 such nooks (crannies?). Very frequent cleaning of these areas helps to prevent build-up. Once built-up, it can be very stubborn to remove safely. PS2icon spray is actually a very gentle wheel cleaner, so you'll probably need something more like what Jason's hawking. With Sport Designs, you're gonna need more than the 4-oz. sample size though.
    NC/CA
    5,579
    1254
    1673
    Take the wheels off and clean them. (You might have to use something like diluted Simple Green or Jason's Wheel Gel.) Then wax the wheels with a product called "Wheel Wax". Cleaning will be a lot easier after that.
    2016 Cayman "Black Edition"
    2015 BMW R nineT
    NJ
    778
    Theres obviously a few ways to go about it. Going w/ a stronger cleaner is certainly one way to do it, but remember, the stronger the product, the greater chance of it harming some types of wheel finishes. For instance, Meguiars makes a hot wheel cleaner, which, on uncoated surfaces can actually harm the finish if the product isnt neutralized prior to rinsing it off. I'm not saying that will happen to an oem/clearcoated finish, but I do want you to be aware of what some cleaners can do to a wheel.
    With that said, the next step up from your p21s wheel cleaner would be the p21s wheel gel. You can spray it on, allow it to dwell and agitate w/ a brush prior to rinsing. Chemical Guys also developed a citrus based wheel gel which is quite similar.
    If you wanted to go even a little stronger, Poorboys Spray n Rinse is pretty strong stuff and I've used it on a lot of wheels w/ caked on brake dust to help remove it.
    One other option for you is to use some clay. A stronger cut of clay can help remove brake dust. In fact, on really bad wheels, I have had great success using spray n rinse, a heavy cut clay and poorboys ssr2.5 polish. I'm not saying your wheels are bad enough to require it, but wanted you to know how I've gone about cleaning up really bad areas.
    I also think that the brake dust being in the corners will make it a little more challenging than if it were to just be on the inner barrels, b/c the area you're working with limits your use of tools and ability to apply good pressure across the area.
    Anyway, here is a link for you to check out some wheel cleaners. Wheel Sealants and Wheel Cleaners
    And as Spencer mentioned, you might consider going w/ a wheel sealant to help future cleanings. Poorboys Wheel Sealant is a fabulous example of this type of product, however, dont feel limited to products marketed as just "wheel waxes or wheel sealants". I apply Optimums OptiSeal to my oem M3 wheels and it works beautifully and really cuts down on time due to its design.
    Jan 2008
    PA
    782
    36
    70
    33
    thank you all for the advice....looks like some gel, elbow grease, and some sealant is the way to go. Like I said it's not really bad, just annoying to have a clean wheel except for some stubborn areas in those corners.
    Sep 2005
    New York
    1,176
    222
    81
    +1 on the Wheel Wax once you get the brake dust off. Best stuff I've ever used.
  10. Remove Advertisements
  1. Brake Dust
    By ploc36 in forum 987 Cayman and Boxster Chat
    Last Post: 10-05-2006, 06:05 AM
  2. Brake Dust/Oil on Cayman S
    By Whitelightning in forum 987 Cayman and Boxster Chat
    Last Post: 09-02-2006, 01:53 PM
  3. The bane of my life... BRAKE DUST!
    By unpollo2 in forum Porsche Care and Detailing
    Last Post: 03-23-2006, 04:58 AM
  4. Wheelwax - brake dust
    By F1 in forum Porsche Care and Detailing
    Last Post: 02-21-2006, 01:01 PM
  5. Folks, what's the story on brake dust?
    By Fiebru in forum 987 Cayman and Boxster Chat
    Last Post: 02-14-2006, 04:51 PM
