What product do you use on the Cayman Glass?
Page 1 of 3 123 LastLast
Results 1 to 20 of 55
Thread: What product do you use on the Cayman Glass?
    Oct 2007
    So. California
    384
    Not happy with the glass cleaners that I have tried. I use Invisible Glass in an aerosol can with newspaper for road trips and it works well for that purpose. Have not found a regular cleaner that I like after the car is washed when at home. Would like to hear what other people are using.
    New York, NY
    974
    Re: What product do you use on the Cayman Glass?
    I use a dilute solution from Optimum No Rinse which I use to wash my car with. Works better than any window cleaning product I've used.
    Jan 2010
    AZ
    64
    I use Adam's glass cleaner. It works really well. Best i've found so far.
    Sep 2007
    Stoner Invisible Glass aerosol as well here... Does the job...
    ID
    1,272
    Windex works fine.
    Whatever you do, wherever you go, enjoy the drive.
    I love this:
    Quote Originally Posted by wanderer65 View Post
    I find the GT3 very sexy while the cayman very attractive. The GT3 is like a girlfriend while the cayman is a wife.
    May 2008
    358
    Outside I've been using the RainX Original Glass Treatment. The older treatment was a pain and left a haze; this new stuff seems to do the job and is easy to apply. Then again maybe any glass cleaner would work as well.
    Inside I use Invisible Glass (spray or aerosol).
    I use a bunch of cheap microfiber towels to remove.
    Apr 2010
    South Carolina
    565
    I'll be watchin' this thread. I was happy at first with Windex, but for some reason, now it streaks. It's annoying.
    Oct 2007
    Calif.
    772
    175
    Oct 2009
    170
    Quote Originally Posted by Cantrax View Post
    +1 Order direct from factory
    Apr 2006
    5,832
    116
    967
    45
    Thread moved.
    Another one here for Stoner's Invisible Glass. No reason why you can't use it at home as well as on the road. Cheap, easy to find anywhere, and works well. Stoner's also makes an Invisible Glass cleaner with rain repellent that's supposed to work like Rain-X without all the streaking and cloudiness that Rain-X leaves behind.
    // Interpol / 2014 981 Cayman S / White
    // PDK / PASM / PTV / SC+ / PCM / PDLS / LDP
    // Borla cat-back exhaust / TiKORE titanium lug bolts
    // 2009 987.2 Cayman S / Carrara White / PDK / traded in 06.2013
    // 2006 987.1 Cayman S / Speed Yellow / 6MT / traded in 08.2009
    Southern California
    134
    Quote Originally Posted by Falcon7 View Post
    Falcon 7,
    Greetings. I have had the same problem for many years. I could never find a great glass cleaner; and, I've tried several. I would always get the dreaded "fog" several days later. I've tried newspaper, and cotton and microfiber towels. Most are good, but none are perfect.
    Recently, I had a clear 3M bra installed on the front bumper. The bra came with a DVD installation guide. They suggested an alcohol/water mixture to clean the bumper before installation. A clean bumper was imperative to a proper installation.
    Hummm, I tried the mixture on my windows - perfect. The mixture uses isopropyl alcohol (70%) and sterile water (bottled, distilled, purified, etc.). The formula is 1/3 alcohol and 2/3's water in a spray bottle.
    Isopropyl alcohol 70% can be purchased nearly anywhere - Costco, any drugstore, Target, Walmart, etc.
    Please remember, isopropyl alcohol is flammable - use caution around open flames.
    I use a Griot's Garage disposable cotton wipe or microfiber towel to wipe dry - good luck.
    It works great and is very inexpensive.
    Semper Fi
    Oct 2007
    So. California
    384
    Quote Originally Posted by Former USMC View Post
    Falcon 7,
    Semper Fi
    Thanks, I will give that a try it makes perfect sense.
    Sep 2008
    491
    47
    Don't use newspaper. That old trick doesn't work anymore, and there are much better alternatives, like the glass microfiber from Detailers Domain. The stoners is good stuff. Keep using it.
    2015 GT3 - Sapphire Blue
    2013 Audi S4
    2014 BMW 328d Sportwagon
    [Sold] 2012 911 Carrera S (991)
    [Sold] 2012 BMW 550xi
    [Sold] 2008 Cayman
    [Sold] 2006 Audi A4 Quattro
    Jan 2008
    534
    103
    I go back and forth between Windex and Stoners. I like the results of the Stoners with rain repellant, but sometimes experience "wiper hop" when it rains!? My results seem to be related to the relative humidity when I wash the Cayman. I get much better overall results when the humidity is low.
    Apr 2010
    South Carolina
    565
    I've read that a vinegar and water mixture works well also. I haven't tried it, though. Have any of you? I don't think I'd use it inside the car, 'cause I'm sure it would make the vehicle smell like vinegar.
    Missouri
    127
    85
    I use Stoners also as it has alcohol in it. I ditched using Windex years ago on any kind of glass. The type of drying towel is half the issue, use a clean microfiber towel. On my new 07 CS, which had sat all winter, the glass accumulated a lot of set in dirt and was very rough even after cleaning. So I used claybar on it, then cleaned with Invisible Glass. Now it's really clean and dust does not stick to it as easily.
    Be carefull with the alcohol/water as it will strip wax on the outside finish and might not be too good for where it oversprays on the inside.
    Tennessee
    77
    I picked up a container of Armor All glass wipes a couple of weeks ago, and I like the results.
    25 Year PCA Member
    Sep 2008
    8 miles from Graceland
    104
    Quote Originally Posted by chaudanova View Post
    +1
    Red Pony blazing across the plains!
    http://scumshine.smugmug.com/photos/410044916_gZPZ3-L.jpg
    Aug 2008
    I use Meguiar's. Works very well.
    Jan 2008
    PA
    777
    69
    33
    Glass cleaner is the only thing I do not have in my cleaning arsenal...I just use zaino z-6 - when I do my whole car I just spray a little extra on the windows and use a micro-fiber towel and I'm good to go. Seems to do the trick rather nicely.
  1. What tape do you used to tape the weights?
    By qhb in forum 981 Cayman and Boxster Competition
    Last Post: 10-19-2013, 04:02 PM
  2. What product do you use on the Cayman Glass?
    By Falcon7 in forum 987 Cayman and Boxster Chat
    Last Post: 05-04-2010, 08:38 AM
  3. What lease deals have you received on the Cayman S?
    By P-car Fan in forum Porsche Sales & Leasing
    Last Post: 04-05-2010, 09:00 AM
  4. What do you call yours (the cayman!)..
    By Kez in forum United Kingdom, Ireland Region
    Last Post: 02-13-2008, 08:20 PM
  5. What Interior products do you use for Cleaning and Conditioning
    By Bluzfan in forum Porsche Care and Detailing
    Last Post: 01-07-2007, 10:44 PM
