Planet-9 > General Discussions > Porsche Dyno Charts » Cayman S SRP vs. Stock Dyno
Porsche Dyno Charts This is the forum to post your dyno charts showing the results of various performance modifications.
Old 05-07-2009, 05:22 PM
GorresKime's Avatar
Insider
Images: 17
SRP vs. Stock Dyno
This is a comparison Dyno chart for my Stock vs Softronic/ 4.1 flash mod (stock air filter).
A nice jump around 5500 but looks like a loss on the lower end. Max torque was actually a bit lower.
Next up: V-Flow (if they ever get in stock), Fabspeed headers and Borla exhaust. Will post again with those results.
Mike
Black '06 Cayman S
My Garage
| My Articles
Old 05-08-2009, 07:30 AM
Gator Bite's Avatar
PCA Cayman Register Advocate
Images: 709
Re: SRP vs. Stock Dyno
Weird dip and lack of smoothness up top, on both runs. Could be a dyno issue, or you could have a vacuum leak on your resonant flap vacuum line.
Gator Bite
Old 05-08-2009, 06:00 PM
Tomasz's Avatar
Images: 36
Wait, if the stock run was before the SRP install then there is no reason for the vacuum leak. Right?
Not to go off topic, would be great to have a list of all the possible ways that once could screw up a SRP install. How can I check if I do or do not have a vacuum leak from one of the vacuum lines? When the engine is running, I hear quite a bit of hissing, but I think that is normal. Secondary air pump is for sure loud.
Scott? Maybe this is worth a FAQ?
Tomasz
Tomasz
Old 05-08-2009, 06:02 PM
Tomasz's Avatar
Images: 36
Thanks Mike. Are you willing to test FabSpeed headers separately of Borla? Glad you have a baseline, although it does look little weird.
Tomasz
Old 05-08-2009, 06:05 PM
Tomasz's Avatar
Images: 36
Sorry, one more. These DynoJets seem comparable:
My DJ run
Tomasz
Old 05-08-2009, 06:41 PM
GorresKime's Avatar
Insider
Images: 17
That dip is present on both runs so I don't think it is a problem with the SRP install. Maybe the dyno?
I will most likely have the headers installed ahead of the exhaust so I will do a dyno run with just the headers added.
I think the dyno looks a bit weird because if the smoothing setting I used. I have the actual data and can produce the graphs myself. I think that may be why it looks different from other dyno sheets.
Mike
Black '06 Cayman S
My Garage
| My Articles
Old 05-08-2009, 07:49 PM
Softronic's Avatar
Platinum Sponsor
Images: 14
Hello,
I noticed the dyno yesterday and was going to make a post however I had thought it was just another dyno gone wrong. I think that everyone should should save some money and stop with all the dyno runs. I can go on and on as to how they are all either skewed by Vendor, Op's that do not know what they are doing etc, etc, etc. I have about 40 on the SRP and they are all different. Some are what I would expect and others not close .....
This dyno does show a very abnormal fluctuation around 5200 rpm . This is either from one of two things. The problem also applies to the apparent earlier run of the car on the dyno. The resonance flap is actuated in this range and it is possible that the unit is defective. Defective being that the flap is not fully opening and closing properly and is damaged. The other is that the dyno is experiencing problems in this range.
Best Regards,
Scott Slauson
Old 05-08-2009, 08:02 PM
Softronic's Avatar
Platinum Sponsor
Images: 14
No Tomasz ???????
My DJ run
Old 05-08-2009, 09:02 PM
GorresKime's Avatar
Insider
Images: 17
Originally Posted by Softronic View Post
...The resonance flap is actuated in this range and it is possible that the unit is defective...
Scott,
Thanks for your feedback. My posting was not meant as a slam on the SRP. I still feel that it was a very worthwhile modification. I just posted what was recorded and really appreciate any feedback as to the results. Maybe the dyno was off and maybe there is something not quite right with my CS. That is the information that is valuable to me. Any information that I can get on how to determine if this is true would be greatly appreciated.
Mike
Black '06 Cayman S
My Garage
| My Articles
Old 05-09-2009, 08:35 AM
Gator Bite's Avatar
Images: 709
Yes. But,though a leak is much less likely on a stock car where nothing has been touched, it is still possible. I am totally guessing. But my guess kind of makes sense because the jaggedness is not in the lower part of the run. If you disconnected the vacuum line to the resonant flap control, or if the actuator failed (ripped diaphram), when the DME called for the flap movement (I think that happens at 5,100-5,200 RPM), instead of getting flap actuation it would get a vacuum leak causing a lean condition that the O2 sensor would see, and the DME would try to compensate. That compensation attempt that could create a jagged output plot.
More likely, this is just a dyno issue. The Dyno Jets do some funny stuff.
I think JCay also had a pretty big dip in this area. That was on a Dyno Dynamics. He did not have the jagged plot.
Gator Bite
Old 05-09-2009, 09:41 AM
GorresKime's Avatar
Insider
Images: 17
Gator,
Thanks for the info. I will pull the resonance flap section to see if I can tell if it is fouled/damaged in any way.
I changed the SAE smoothing to 5 on this plot (was @ 2 ). Does that remove the jaggedness you refer to or do you still see it as a bit abnormal?
Mike
Black '06 Cayman S
My Garage
| My Articles
Old 05-09-2009, 02:02 PM
Gator Bite's Avatar
Images: 709
Originally Posted by GorresKime View Post
Gator,
Yes, looks much better.
Gator Bite
Old 05-09-2009, 04:57 PM
GorresKime's Avatar
Insider
Images: 17
Ok.. I took a look at the resonance flap and could not see any problems (external damage). I cleaned out the tube as it did have some gummy oil residue. It may be an internal problem or maybe it is just a dyno abnormality.
Either way, while I was in the engine compartment, I decided to pull the air filter and inspect it. I haven't checked it since I got the car because I am planning to install a V-Flow (on order.. been waiting 2 months). The filter was VERY dirty. I removed it and knocked out the dust (A lot came out) then vacuumed it out as best I could.
Results: OMG my car sounds like a different car. I could feel the power difference but the sound was the most evident change (more throaty and loud even at lower RPMs).
I don't think the air filter could have caused the dip @ 5200 but it does explain how the SRP mod came in a bit lower than expected. I'm not sure I agree with Scott that we should stop doing dyno runs but I think we should realize every car is different and that it is not always evident what the bottleneck in our search for more power is. In my case it led me to search further for a possible issue (and I'm pretty sure I found one).
Thanks again for all the feedback from everyone.
Mike
Black '06 Cayman S
My Garage
| My Articles
Old 05-10-2009, 11:32 AM
Tomasz's Avatar
Images: 36
You just reduced your satisfaction level with the V-Flow. As you would have gotten the same result or hopefully) better after installing V-Flow, and you would have attributed it all to it. Just teasing a bit here.
Tomasz
Old 05-10-2009, 11:47 AM
Tomasz's Avatar
Images: 36
Scott - no dyno, no G-Timer, no Durametric time logging... what do you recommend? I know that I can always compare two cars by racing them on a highway. Lets say a 3rd gear run from 50 to 100.
But how do I take a baseline, modify, and measure again to see the effect on my car? I know dynoes are not perfect, but they should be indicative and directionally correct. I rather by approximately right than definitely wrong.
Tomaasz
Tomasz
Old 05-10-2009, 01:51 PM
GorresKime's Avatar
Insider
Images: 17
..Just teasing a bit here.
LOL, I deserve a bit of teasing. I am a bit embarrassed that I hadn't checked the filter when I got the car. I guess I was relying on the dealer to have done that...
Mike
Black '06 Cayman S
My Garage
| My Articles
Old 05-10-2009, 05:55 PM
Softronic's Avatar
Platinum Sponsor
Images: 14
Tomasz with all respect they all have their limitations and especially when done wrong .
Durametric does not check quick enough for times to be accurate.
Dynos are all over the board and especially when not done correctly etc. This is most of all that I have seen. The ones done by other dealers are inherently skewed for the benefit of them trying to sell their product. Others are done on different days with different conditions not alloted for, Etc Etc Etc.
Should you want to do a timer test then perform it at a range that the car would test at correctly or for an expected range of improvement.
We all know that the SRP by itself has a loss below 3500 and then gains above that. I think this has been stated many times before so your testing does not make any sense in saying it should have gained below that and does not now. This is simply because the diverter valve in the stock Plenum is normally closed until then and opens at that range. So basically a dyno that does not show a cross in HP and Torque at that range is not accurate when just the SRP was installed. This would be by the running of the car and many other variables that I do not have the time to list.
Now add the exhaust to it and the gains will be through the entire range. Basically more in more out. This would apply to ANY larger TB and the gains get worse on the lower end the larger the TB. A larger TB being from stock and the given flow of an engine. I could have used a 82mm and it would bolt on however it would be even worse below 3500 and only gain more with a complete exhaust from headers to muffler. The gains then would only be about 7hp at 6500 or so with my software. Bigger is not always better unless for bragging to people who do not know the difference.
I'm forever getting emails from people that had dynos and it doesn't look correct. The first question that I ask is who did it and the dyno type. Many I have told since I'm familiar with the companies that did the testing and tend to be bias to go try another. I do not specify any. They pic another dyno and they get totally different results and are happy. Some test improper installed kits, cars with bad filters, tires inflated incorrectly, cars not secured down correctly and on and on and on.
Scott
Old 05-10-2009, 06:45 PM
Images: 61
Among many assignments I got to be manager of a research lab for awhile at a major oil company where we checked competitor oil products. I learned that dyno results are only as good as the person running them and without very precise standards will give any result a person wishes. Their best use for the amateur is to attempt to compare before and after modification results (not to compare one car vs another at different times, conditions, operators and so forth). Using the firm selling the mod who has skin in the game is foolish as most of recognize.
Old 06-09-2009, 12:48 PM
wpmjr's Avatar
Porsche Idealist
Images: 34
5250 rpm is where hp and torque are always numerically equal- seems too coincidental that the anomaly happens exactly there. Could it be a dyno math glitch?
997 GT3 front sway bar
Quaife TBD
Hawk HP Plus pads
  #20
Old 06-10-2009, 09:46 PM
JCay's Avatar
The driver formally known as Torque
Images: 52
snip...
The dip in my dyno was very small in comparison to this.... and no where near as pronounced.
Tags
dyno, softronic, srp, stock
LinkBack to this Thread: http://www.planet-9.com/porsche-dyno-charts/32634-srp-vs-stock-dyno.html
Posted By For Type Date
Cayman S SRP vs. Stock Dyno - Page 2 - Planet-9 This thread Refback 10-20-2009 11:25 AM
