Cb4, clearly you and I have differing tastes in cars!
Don't you realize that white Caymans are "cooler" as well as faster?
Of course "cooler" in a temperature sense is more important in Florida than it is in Massachusetts.
That said, a factory installed
LSD was not offered on the Gen I '06-'08s. You'll need to go aftermarket or get an '09. Do a search and you'll find a number of aftermarket options and a lot of discussion on that topic. All of the above is also true for Bluetooth.
There is a
FAQ concerning purchasing a used Cayman and that might be useful for you to read. Purchasing a low mileage used Cayman is an easy way to save a considerable sum of money these days because depreciation has been particularly bad in the current environment for "luxury" vehicles. You might also check out ebay. You might not want to purchase there....but it is a good place to get a sense of the market and a number of dealers use it. If you purchase a used vehicle from a dealer you may be able to negotiate an extended warranty via the CPO program.The money you save can go toward installing Bluetooth and an
LSD.
Good Luck!
