| Porsche Sales & Leasing Forum for discussion of buying, selling or leasing a Porsche or for discussion of items listed in the Classified Ads. This forum is NOT for listing items for sale, PLEASE USE THE CLASSIFIEDS! |
06-28-2009, 03:16 AM
How did I do?
Just put my money down on an 06 arctic silver with black interior. Manual trans. Bought more car than I intended to. Here's what I got:
Standard Leather,
Heated Front Seats,
19" Carrera S Wheels,
TPMS,
3-Spoke Sport Steering Wheel,
PASM,
Chrono Package Plus,
Bose High End Sound Package,
Bi-Xenon Headlamp Package,
PCM 2.1, Black Mats - Porsche lettering.
The car has 14,000 miles on it & it is a CPO vehicle. The dealer is putting new rear tires on the car, they may also change the fronts. Carfax came out clean.
Car has had two owners.
Origional selling price was $71425.00. I got it for $39995.00. Is that pretty fair?
TPMS
TPMS - The Tire Pressure Monitoring System provides early warning of any drop in pressure by continuously monitoring the pressure in each tire and alerting you in the onboard computer display in the event of a pressure deficiency. It communicates the exact pressure of each tire and/or their deviation from ideal pressure. This does away with the need for regular air pressure checks at the service station, which often prove highly inconvenient.
See the TPMS FAQ for more info. |
06-28-2009, 03:23 AM
Re: How did I do?
From what others here have posted here, you did okay, enjoy.....
06-28-2009, 04:19 AM
Life is a wonder.. my life that is!
Re: How did I do?
Thank you for your post... Both you & I almost share all the options. I bought mine on ebay back in March for $39k. Of course with overseas shipping, customs and registration it went up to $48k  but that's pretty good in comparison to the prices and conditions of PCO CS here in Saudi Arabia.
It had the following:
Porsche Cayman S 2006 Model
Factory warranty until 3/2010
13000 Miles ONLY!
6-speed manual transmission
Navigation/PCM 2.1 with a Parrot hands free visor-mount phone unit
Porsche Active Suspension Management ( PASM),
Porsche Stability Management ( PSM)
Sport Chrono Plus Package
Preferred Package
Tyre Pressure Management System ( TPMS)
9-spkr Bose Surround Sound w/CD
19" Sport Wheels with painted crests
Bi-xenon headlamps
K40 Built-in radar
HomeLink
Keyless entry w/alarm
Just serviced and inspected by Porsche
All original and not a scratch on it.
Original sticker price with these options was $72,000 in the USA.
TPMS
www.Hassaan.com
Mine: Cayman S '06
Mine: Land Cruiser '10
Bro's: GT2 '03
06-28-2009, 06:31 PM
Re: How did I do?
Originally Posted by Rockhouse
...14,000 miles on it & it is a CPO vehicle....$39995.00. Is that pretty fair?
From afar, seems like a good deal.
06-29-2009, 03:47 AM
Re: How did I do?
Standard Leather,
Heated Front Seats,
TPMS,
PASM,
I bought the EXACT same '06 color and options in May. This color and options must have been a suggested package from Porsche for dealer orders because the options on mine are absolutely identical. Everything exactly the same except mine was in the low 16,xxx miles. I paid $38,460 for mine. It is a WONDERFUL car. You did good!!!
You will learn to appreciate every option on the car. They work well together. It takes about 3 weeks to figure out the GPS if you've never used on like this.
You need to do the Bose Subwoofer Stuffing. You buy a plastic bag of poly pillow stuffing at a crafts store for $8 or so. You use two sizes of torx wrenchs to pull off the subwoofer from the front passenger's floor area, find the hole in the plastic housing and stuff it as full as you can with the poly pillow stuffing. Put it back together and zippo, unlistenable stereo transformed into very listenable stereo. Seems this plastic housing improves bass response and also mucks up all the other frequencies. Damp this out and everything else comes out again like it's supposed to. It's not a bad unit! The whole process takes 20 minutes or so. Read about it in ARTICLES section or search "bose". You'll find it along with a bunch of complaining about the stereo from folks who haven't done this.
PASM is needed with 19" wheels for adequate comfort on the street. Read about these options in the FAQ area.
-TB
TPMS
06-29-2009, 03:21 PM
I'm an excellent driver ....
Re: How did I do?
Pretty fair??? How does it feel?
Screw it, go drive it - enjoy....
06-29-2009, 10:41 PM
Re: How did I do?
-TB
Do the 2009 have this problem as well? Do we have to do this fix on the new 2009?
06-30-2009, 01:07 AM
Re: How did I do?
Dunno, but if you hate the Bose stereo when you buy one, know that there's a cheap fix that is really effective and takes all of 20 minutes. Better than spending hours bitching to the dealer and getting nowhere.
I've heard they fixed the trunk clunk and then I heard they didn't...same with the Bose. It's a sports car. It's almost a tradition to have some little issue you have to mess around with.  I was just reading the Miata Club site....full of foibles and fixes.
-Six
06-30-2009, 02:40 AM
Newbie
Re: How did I do?
Hi Guys
First post here, just wanted to introduce myself and also add a little bit of information related to the topic. I just placed my deposit on a 2006 White CS, the car is CPO and price out the door was $39,XXX. The car comes with:
19 inch Carrera S Wheels
Rear Window Wiper
Automatic Climate Control
3 Spoke Sport Steering Wheel
Preferred Package Plus
Power Seat Package
6 Disc CD Changer
I know thats a little bit more than what some people have paid, but I went to see the car myself and it was mint and only had 11,XXX miles and had all the options I wanted (plus colour was most important to me). Congrats to the original poster, spending this much money never felt so good!
06-30-2009, 07:55 PM
Re: How did I do?
Originally Posted by BSo
Hi Guys
Rear Window Wiper
Power Seat Package
6 Disc CD Changer
BSO:
You did good!!! Right in the zone with the rest of us. I have a few different options and a few more miles and paid slightly less, but mine is not a Porsche Certified Pre-owned car.
Great deal...Buy it!!!
-Six
