Nitto NT01 tire pressure?
Results 1 to 9 of 9
Thread: Nitto NT01 tire pressure?
    Mar 2006
    MS
    145
    I am wondering what tire pressure everyone is running in their nt01's. I picked up a set for my track wheels and I have a track day next Sunday.
    Aug 2006
    502
    141
    39
    Look for 37-40 PSI hot. See what feels best for you. I like them around 38 front and 39 rear at Willow springs but was trying to keep them even at California Speedway this past weekend, around 38 hot.
    DISCLAIMER: I'm not an engineer, I just play one on the internet.
    BBI Under-Drive Pulley V2 |
    BBI Brake cooling| GT3 Lower control arms
    GT3 Front Sway bar
    | Quaife | PSS9 | Tarett Everything! |Mantis Sump |996 Swirl Pods |Motorsports VOS |
    Motorsports Electric Power Steering |
    473
    38 or 39 worked best for me, they drop off quickly over 40psi, at 44 it gets really fun, but slow.
    Sep 2007
    Alberta
    540
    48
    I'm running 33 Front & 37 rear and the car seems to really stick in the corners at these pressures. I tried higher PSI but the car felt very loose (understeer) in the corners. The temp of the track will also make a difference so each location may require difference PSI settings.
    Jun 2006
    305
    i'm close to polarporsche, with hot pressures of 34 front and 38 rear.
    DFW TX
    3,909
    45
    445
    170
    Agree with above . . .
    Around 38 hot seems to work well with mine, you can definitely tell when the rears go over 40 as it will get very loose. I'm starting with cold pressures of about 28-29 in the Rear and 30-31 in the fronts.
    2011 Macan S: Wifey's DD
    Sep 2005
    MO
    2,870
    454
    105
    Quote Originally Posted by PolarPorsche View Post
    ... I tried higher PSI but the car felt very loose (understeer) in the corners.
    A car that is "loose" is oversteering, not understeering.
    Understeer is described as "push" or "tight."
    Dan
    National PCA DE Instructor
    2016 Rhodium Silver GT4
    Sep 2007
    Alberta
    540
    48
    Quote Originally Posted by STLPCA View Post
    Yes, I agree.
    My car would understeer and "push/understeer" entering the corners and the tail would step out "loose/oversteer" coming out of the corners if I got on the gas to hard. Dropping the PSI to 33F/ 37R seem to make the car nuetral.
    Mar 2006
    MS
    145
    Thanks for the input guys I can't wait to try them out.
  12. Remove Advertisements
  1. Replies: 7
    Last Post: 07-21-2014, 02:22 PM
  2. Cayman Nitto NT01 Used Track Tires
    By wylescoyote in forum Planet-9 Classifieds
    Last Post: 12-04-2012, 02:37 PM
  3. Cayman S Wheels OEM with Nitto NT01 tires- Free Delivery
    Last Post: 07-19-2011, 02:58 PM
  4. Tire Pressure at delivery
    By Archer993 in forum 987 Cayman and Boxster Chat
    Last Post: 02-26-2006, 11:25 AM
  5. Tire Pressure Question
    By scubadriver in forum Site Vendors & Sponsors
    Last Post: 02-22-2006, 11:08 AM
