Results 1 to 9 of 9
    Kman Dreamer's Avatar
    Kman Dreamer is offline Site Donor
    Mar 2006
    MS
    145
    Nitto NT01 tire pressure?
    I am wondering what tire pressure everyone is running in their nt01's. I picked up a set for my track wheels and I have a track day next Sunday.
    CCC4321's Avatar
    CCC4321 is offline PCA / POC Member #125
    Aug 2006
    502
    141
    33
    Look for 37-40 PSI hot. See what feels best for you. I like them around 38 front and 39 rear at Willow springs but was trying to keep them even at California Speedway this past weekend, around 38 hot.
    DISCLAIMER: I'm not an engineer, I just play one on the internet.
    BBI Under-Drive Pulley V2 |
    BBI Brake cooling| GT3 Lower control arms
    GT3 Front Sway bar
    | Quaife | PSS9 | Tarett Everything! |Mantis Sump |996 Swirl Pods |Motorsports VOS |
    Motorsports Electric Power Steering |
    consolidated's Avatar
    consolidated is offline Site Donor
    416
    38 or 39 worked best for me, they drop off quickly over 40psi, at 44 it gets really fun, but slow.
    PolarPorsche's Avatar
    PolarPorsche is offline Porsche Specialist
    Sep 2007
    Alberta
    540
    48
    I'm running 33 Front & 37 rear and the car seems to really stick in the corners at these pressures. I tried higher PSI but the car felt very loose (understeer) in the corners. The temp of the track will also make a difference so each location may require difference PSI settings.
    esaam ismail's Avatar
    esaam ismail is offline Site Donor
    Jun 2006
    305
    i'm close to polarporsche, with hot pressures of 34 front and 38 rear.
    KS-CS's Avatar
    DFW TX
    3,880
    427
    169
    Agree with above . . .
    Around 38 hot seems to work well with mine, you can definitely tell when the rears go over 40 as it will get very loose. I'm starting with cold pressures of about 28-29 in the Rear and 30-31 in the fronts.
    STLPCA's Avatar
    STLPCA is offline Site Donor
    Sep 2005
    MO
    2,596
    102
    Quote Originally Posted by PolarPorsche View Post
    ... I tried higher PSI but the car felt very loose (understeer) in the corners.
    A car that is "loose" is oversteering, not understeering.
    Understeer is described as "push" or "tight."
    Dan
    National PCA DE Instructor
    2006 Cayman S 3.8L 997S X51 Turbo
    Sep 2007
    Alberta
    540
    48
    Quote Originally Posted by STLPCA View Post
    Yes, I agree.
    My car would understeer and "push/understeer" entering the corners and the tail would step out "loose/oversteer" coming out of the corners if I got on the gas to hard. Dropping the PSI to 33F/ 37R seem to make the car nuetral.
    Mar 2006
    MS
    145
    Thanks for the input guys I can't wait to try them out.
  1. 18" Track Setup - BSA Eaglerock, Nitto NT01 Tires, Pagid Orange Pads
    By operator_stavros in forum Planet-9 Classifieds
    Last Post: 07-21-2014, 02:22 PM
  2. Cayman Nitto NT01 Used Track Tires
    By wylescoyote in forum Planet-9 Classifieds
    Last Post: 12-04-2012, 03:37 PM
  3. Cayman S Wheels OEM with Nitto NT01 tires- Free Delivery
    Last Post: 07-19-2011, 02:58 PM
  4. Tire Pressure at delivery
    By Archer993 in forum 987 Cayman and Boxster Chat
    Last Post: 02-26-2006, 12:25 PM
  5. Tire Pressure Question
    By scubadriver in forum Site Vendors & Sponsors
    Last Post: 02-22-2006, 12:08 PM
