Results 1 to 9 of 9
Thread: PASM: can one soften the suspension?
    dtzelepis is offline Porsche Person
    Dec 2008
    Gentlemen, this is my first posting (in my life)
    I have a 987 boxster S with PASM, and it is too hard for Greek roads-where I live...Can one fit the normal shock absorbers in order to soften the car, or it is impossible?Dimitris
    Jim Michaels's Avatar
    Jim Michaels is offline Porsche Orator
    1,558
    Re: PASM: can one soften the suspension?
    Welcome to the swamp.
    It may be that PASM in non-sport mode provides a more compliant ride than the standard suspension. Do you have 19" wheels and tires? If so, switching to 18s may help. Some tire brands also provide a more compliant ride than others.
    Almost any switch is possible, but a proper suspension switch from PASM to the standard suspension might be somewhat expensive, but probably not as costly as going from the standard suspension to the PASM. The standard suspension apparently does have slightly softer spring rates (someone posted the spring rate graphs for the Cayman S here recently), but I don't know how much the shocks differ in their dampening rates. In short, I hope someone who knows more than I steps up to provide a better answer.
    Tomasz's Avatar
    Tomasz is offline Porsche Orator
    1,748
    42
    40
    You could for one fit springs from a non-PASM car - they are softer. There may also be some aftermarket offerings that have progressive springs which will also be more comliant. Finally, 986 springs may be softer and may fit...
    Tomasz
    SIAM6128 is offline Porsche Prophet
    Aug 2008
    attica
    75
    33
    Kalws ton filo mas !!! poy meneis athina?
    a friend of mine has boxster s with pasm, 18 inch wheels and the ride is very soft to mine, which i have a boxster with 18 inch wheels. when he presses pasm, then the ride tightens a lot, as tight as i am. but, you should have a very enjoyable ride though with pasm, i know my friend does!
    Dec 2008
    Gentlemen,
    thank you for all your informative answers! I have already ordered a set of 18" Cayman S wheels with Michelin PS2s which arrive next week. From your comments it seems that this will solve my problems of too hard suspension (and a bad back). In case further improvement is needed, I will put the standard springs. In case a Greek friend is interested, I am selling the set of (unmarked-perfect) Carrera S 19" wheels I have now...
    File SIAM6128, meno stin Filothei, pira tora pou ekana to deutero paidi tin proti moy Porsche! kai exo trelathei na diavazo ola ta periodika (excellence, 911 etc)!!
    stiles_s is offline Porsche Prophet
    Oct 2007
    80
    Quote Originally Posted by dtzelepis View Post
    Gentlemen,
    I honestly don't think you're going to see a ton of difference w/the 18s. I have PASM+18s on my 987s and it's still pretty rough. If this doesn't work out for you, I'd suggest you go a bit further & try 17s. Search for a few threads on this in this forum.
    '08 Boxster S. PASM, cayman 18s, sport seats, RS60 Pi-pipe, etc
    '10 Audi Q5
    '07 gx470
    Dec 2008
    I just installed the 18" wheels (instead of the 19"). Now the ride is just perfect, on the imperfect Greek roads! I strongly suggest it the change to anyone feeling that 19" wheels, even with PASM on "normal", gives too hard a ride...
    1,558
    Thanks for the update. We like hearing about satisfactory solutions.
    paco's Avatar
    paco is offline Porsche Enthusiast
    May 2008
    Bulgaria
    219
    hmmm, that did not work for me on the bulgarian roads (going from 19s to 18s on standard suspension). glad it did for you though.
    enjoy.
  1. 11-20-2013, 01:39 AM
  2. 03-28-2013, 08:02 AM
  3. 03-18-2013, 05:14 AM
  1. can retrofit X73 sport suspension on PASM equipped car?
    By wskstorms in forum 981 Cayman and Boxster Modifications
    Last Post: 04-28-2014, 11:08 AM
  2. Can you lock the keys in one of the trunks?
    By 981WC in forum 981 Chat
    Last Post: 04-08-2013, 05:16 PM
  3. How can one figure out the "correct" tire pressure?
    By ThomWT in forum Porsche Tires & Wheels
    Last Post: 02-14-2009, 12:33 PM
  4. Seen one in the flesh
    By Mark w in forum United Kingdom, Ireland Region
    Last Post: 11-16-2005, 02:36 PM
  5. The Real Reason you Can't Drive the Cayman S!
    Last Post: 11-14-2005, 09:31 AM
