04-16-2009, 07:53 PM
Miss matched front and rear tires
I need to replace my rear tires one has a side wall blister and tread is 50% gone so need to replace both. the front tires are in great shape, 90% left. Don't want to get the same P Zeros to expensive and didn't like them much. Can I put different brands on the rear? I know left and right tires must mach but is the front and rear tire matching a myth?...
04-16-2009, 08:11 PM
Boxster Enthusiast
Re: Miss matched front and rear tires
I'm doing it right now. I had some Bridgestone Pole Positions and I usually use 2 sets of rears for each front set. I decided to go back to PS2s, so I replaced the rears and left the PPs on the front. I didn't notice a difference. I wouldn't track my car without a matched set. I think you'll be OK as long as they are similar type tires.
04-16-2009, 09:13 PM
And I'm hesitant to replace just the worn PS2 rears with more of the same?
Be careful out there.
04-17-2009, 06:22 PM
Porsche Spieler
Well its not that I recommend it, but I have Ecsta's on the fronts and OEM Potenzas on the back, I think the Ecsta's have a little less grip but overall its ok.
P.S. I did participate in track events (albeit low speed ones on a karting track)
04-17-2009, 06:35 PM
Personally, I'd keep the same brand all the way around. Kinda' sloppy to have mix-match tires....but that's just me. Michelin PS2's are my choice....since it came with them new......
04-18-2009, 10:05 AM
Maybe you could swap all four with a matching set, and sell the fronts either locally (no shipping necessary). There are several shops in the bay area that buy and sell used tires.
Alternately you could sell 'em on craigslist or ebay. This way you reach a wider "audience" and recoup some $ for the fronts.
BTW you also get rid of the the tires that you admittedly don't like much.
Jason
04-18-2009, 11:19 AM
Yes you can swap one end at a time.
I was running Nitto fronts and PS2 rears for a while. My observations are, as the tire becomes worn and heat cycled, the only real problem you'll run into is a raised PSM threshold. I believe the PSM must work off of the tire's slip angle, and of course worn out burnt tires don't generate much slip angle before they break loose. I noticed the same with thing with my Corvette too.
