(Moved to tires and wheels forum with the other
TPMS threads.) I suggest you read through the existing threads for ideas. Could be a bad module, bad sending unit, interference from another car with
TPMS, weather changes that put it on the border of reporting, loose valve stem (recommended to replace when changing the tire on the wheel), frequent stopping and starting and some other things. What service did the dealer perform? Maybe there is a clue there as well. Some have reported over inflating and then bleeding back to the correct pressures (using a very good gauge - not the ones that get within plus or minus 3 or 4 lbs pressure) have "reset" the brain. And by all means try getting the system to relearn (have enough time to drive for 15 or 20 minutes on some cars).
If you go back to the dealer it probably isn't going to be a quick check over given the variables, the fact that they will have to figure out the problem, maybe order parts, keep the car to replace them and have time to teach the system.
TPMS
TPMS - The Tire Pressure Monitoring System provides early warning of any drop in pressure by continuously monitoring the pressure in each tire and alerting you in the onboard computer display in the event of a pressure deficiency. It communicates the exact pressure of each tire and/or their deviation from ideal pressure. This does away with the need for regular air pressure checks at the service station, which often prove highly inconvenient.
See the TPMS FAQ for more info. |
