Planet-9 > General Discussions > Porsche Tires & Wheels » Please tell me these will fit
Old 05-20-2009, 09:03 PM
CaymanSteve's Avatar
I'm just not sure about the rears. I know other members have fit 11" on a Cayman S. Just not sure if I will run into problems because of the offset. Really need advise quick. Thanks
fronts 19x8.5 +51
rears 19x11 +38
Old 05-21-2009, 12:25 AM
themperor's Avatar
Images: 31
Re: Please tell me these will fit
Everything I have read says yes to a 11" rear with a 38mm offset. I did alot of research before buying my wheels. It is not a good comparison but I run a 10" rear with a 33mm offset and 285/30 tire.
Old 05-21-2009, 08:29 AM
Jeff G in NE GA's Avatar
Hi CaymanSteve. They Will fit. I am currently installing 19x11 +40 on the rear of my 06CS. I measured .127" between the strut and the wheel/tire, which I consider about perfect (considering deflection). Your wheels will be 2 mm further outboard, relative to the strut. The outer edge of my wheel/tire is almost peeking out of the fender as viewed from above, but looks just about right to me. You may need to roll your rear fender lip slightly, esp if lowering, but may not. The fronts are fine. Enjoy.
Old 05-21-2009, 02:31 PM
Thanks fellas. Time for some new shoes
