Re: 295-35-18 with a mild drop?
Hi Mkiv,
You are correct, 295/35/18 is closer to stock height, at .22" OAD less than stock. I have 295/30/19s on 11" wheels on my rear and they are fine. Your offset sounds close. I would fit the tires and then trial fit them to the car using washers as spacers (statically - no driving) to determine what thickness spacer to buy, if any - or you could search on here more to find 18" offset specifics. But, it will work, and you're on the right track. Enjoy. -Jeff
