Re: Tire Temp monitoring device
Hi Gents. I've used IR tire temp sensors onboard race cars with good results. You may be surprised how quickly the temps change, and how quickly they cool and shift as the car is coming into the pits. They are a good tool. However, I've only done it with three per wheel, with the fronts being mounted on a structure connected to the upright - so the sensors stay equidistant from the tire at all times and turn with it. With only one sensor per tire, and mounted on the chassis - results would be very limited, so I would approach with caution. Old-fashioned static tire temps, and looking at the tires closely after running, will tell you a lot for now. -Jeff
