Results 1 to 20 of 26
    hawc's Avatar
    hawc is offline Porsche Raconteur 2,000 post club
    Mar 2007
    2,747
    Question Do tires lose traction as they wear down?
    I've had my Michelin Pilot Sport PS2icon for about 2 years now and there's still life left in them, not down to the wear bars yet, and I'm wondering if I'm getting less traction out of them through the corners.
    I would have thought the opposite would be true that less tread meant more traction. But the other day I took a corner pretty quickly and the whole car began a 4 wheel drift (no breaking, only very light acceleration) until the PSM kicked in and I thought, huh, are my tires losing traction?
    Can the rubber's age affect it at all if they're only 24 months old.
    beez is offline Site Donor
    Dec 2005
    Las Vegas, Nevada
    6,825
    Re: Do tires lose traction as they wear down?
    Quote Originally Posted by hawc View Post
    Yes, it can - the continuous heat cycling and the environmental degradation makes the tire compound get harder over time. I've gotten rid of every set of my PS2s (four sets in 3.5 years) because they had heat-cycled out, long before all the tread had been used.
    Mike_in OH's Avatar
    Mike_in OH is offline Porsche Purist 1,000 post club
    Aug 2006
    1,080
    Exactly; I've got a spare set of PS2icon's in the basement I could use on the street but for track use they're pretty much done after 1.5 seasons for DE use. IIRC, there are tools to test the durameter of the tire in order to judge how hard they've gotten.
    When I took these off the track wheels, I replaced them with the PS2's that came with the car to get me through the season--big mistake. After 1 DE, they had less traction than the dedicated track tires. My guess is that the roughly 2 years worth of street use put enough heat cycles into them to essentially render them useless for track duty. Still had plenty of tread..
    tach miami's Avatar
    tach miami is offline PCA Member
    Oct 2006
    1,498
    Quote Originally Posted by Mike_in OH View Post
    To correct a typing mistake, it is durometer.
    2014 991 Turbo
    2013 958 Turbo Diesel
    2006 987 Turbo CS
    jefeant is offline Porsche Enthusiast
    Dec 2008
    NC
    136
    Yes, they do. It depends mostly on age, heat cycles and wear depth.
    However you can "shave" brand new tires and get the best grip there is on dry surface = slick.
    DaveN007's Avatar
    DaveN007 is offline Caymaniac
    5,000 post club
    Oct 2006
    5,625
    Gamertag: CaymanGT
    People shave PS2icon's? You might as well with a street alignment because the edges cord through way before the tread. (if you are dedicating them as track tires.)
    People shave PS2's? Hmmm....really?
    "Carpe Cayman"
    hawc's Avatar
    Mar 2007
    2,747
    Wow, I never knew street tires would heat cycle. That's nuts.
    Dec 2008
    NC
    136
    What do you consider a heat cycle?
    kehr's Avatar
    kehr is offline Porsche Idealist
    Dec 2007
    Missouri
    911
    Heat cycles aside - my PS2s wore out the outer edges. That's where I've noticed the loss of performance. That's after 7 track days.
    equ
    equ is offline Porsche Activist
    Sep 2006
    405
    Bizarrely, same happened to me. I never thought I'd have heat cycled my tires, with no track or auto-x so far, just a bit of spirit here and there. My rears had decent tread at 2.5 years and 17,500 miles, perhaps 5/32nds but very even, decent wear. I was waiting for them to get to 4/32nds, but I got tired of the car feeling so loose in the dry. So, on went a new pair of rears and yes I have rear grip again.
    I wonder if this is a PS2icon issue. I've also noticed that PS2's are more temperature sensitive than pretty much any other summer performance tire I've tried.
    hawc's Avatar
    Mar 2007
    2,747
    Maybe I should switch to Contis for my next set. Do they heat cycle as much?
    Jim Michaels's Avatar
    Jim Michaels is offline Porsche Orator
    1,558
    I'm not convinced that street tires heat-cycle out on track like R-comps and race slicks, but the rubber certainly deteriorates and hardens over time. I think of this effect as weathering (temperature swings, sun, rain, etc.) rather than heat-cycling.
    I must be at the other end of the continuum from beez (4 sets of PS2s in 3.5 years), as I just ditched my OEM PS2s for a new set of RE-11s after 3.5 years. Yes, they had become noticeably less grippy than they were a year or so ago, but the rears were down to the wear bars anyway.
    There was/is an old rumor to the effect that high performance summer tires are constructed with a harder compound near the wear bars, so they will wear slower toward the end. That was supposedly justified as a "safety" feature, but, if so, I guess sliding around more in the rain wasn't considered. The sidewall rubber seems to harden over time as well, which seems consistent with the time-in-service and weathering explanation.
    Dec 2005
    Las Vegas, Nevada
    6,825
    Quote Originally Posted by Jim Michaels View Post
    It will be interesting to see how my RE-11s compare to the PS2s over time, since I don't use the street tires as much as I used to...
    hawc's Avatar
    Mar 2007
    2,747
    I tend to agree with Jim. I don't have the track experience that all you guys have, but my gut tells me Michelin wouldn't produce a widely used consumer street tire that heat cycles that badly. It probably is just weathering.
    Also the tires come off every winter and sit in a warm basement, don't know if that has any effect.
    DMN987S's Avatar
    Alabama
    1,569
    70
    My rear PS2s would always lose traction when they got near the wear bars. I drive 15K miles a year which is about how many miles I get from my rear tires.
    4by4's Avatar
    4by4 is offline Crusin worlds most isolated city
    May 2006
    down-under
    3,603
    40
    Confirming new tyres have a lot more grip.
    2010 Cayman S, special build.
  17. #17
    beleary's Avatar
    beleary is online now Porsche Enthusiast
    Colorado
    184
    Fascinating thread all. I just replaced my PS2s with RE-11s, primarily because I wanted to get two DE run days on 'sticky' tires before the snow falls, and am very excited to try them out on the track.
    The outer edges of the PS2s were fairly worn on the fronts, although all four still had a little tread above the bars. Once the tires were off, I took a good look at them with the Porsche mechanic and at first glance I felt like I may have pulled the trigger on the PS2s a little early. He pointed out that all of the tires had small cracks running in between the tread grooves (weathering?). They also were very loud when driving and seemed overly firm (I bought the car used and the tread was about half gone at that time, so I didn't know how new tires would be). They were not too bad on the track after letting out a proper amount of air.
    I've only got about 20 miles on the RE-11s, and my mechanic said that the chemical used to help release the tires from the mold would need to wear off before the tires would get sticky. My first attempt going around a corner fast did not go too well (not sure what happened, but it didn't hold the corner). They also don't seem as responsive as the PS2s, but again, only 20 miles so far.
    Any thoughts?
  18. #18
    4by4's Avatar
    May 2006
    down-under
    3,603
    40
    If the surface is not shinny anymore then you are good to go.
    Now the trick is for the R specs to work correctly you must first get them HOT. Dont expect too much if they are warm or cold. Also different brand tyres will have different characteristics at different temperatures in this respect.
  19. #19
    jaica's Avatar
    jaica is offline FAQ TEAM
    Apr 2006
    Puerto Rico
    1,610
    78
    I am not an expert, but I have been told you need at least 50 miles to wear through the mold release.
    Having fun in Puerto Rico
  20. #20
    beleary's Avatar
    Colorado
    184
    Thanks. Yea, the mechanic who installed them said 50 miles, but I read on another thread that it was 500 miles! I'd better get busy driving - the DE is less than three weeks away!
  1. What do I lose?
    By reward72 in forum 981 Cayman and Boxster Electronics
    Last Post: 07-15-2013, 06:40 AM
  2. Do PS2's get really greasy as they wear?
    By eslai in forum Porsche Tires & Wheels
    Last Post: 05-20-2011, 10:32 PM
  3. Replies: 0
    Last Post: 05-21-2008, 07:10 PM
  4. Are they as good as they used to be?
    By filahebe in forum 987 Cayman and Boxster Chat
    Last Post: 01-09-2008, 06:45 PM
  5. I know that in the past, cars used to get quicker as they were broken in,
    By LA Boy in forum 987 Cayman and Boxster Service and Tech
    Last Post: 02-05-2007, 10:43 PM
