Results 1 to 7 of 7
    solrac6262 is offline Porsche Enthusiast
    Jul 2009
    TX Dallas
    166
    TPC inactive system learning
    Hello guys,
    last sunday I was going to wash my CS, and noticed that I had a lost of pressure warning light on my rear tire, I left the car like that, this saturday I reset my tpms and then the tire info went blank and then this message came up.. TPCicon inactive system learning after driving for a bit goes to normal, but the tire pressure on my 4 tires goes everytime differnt, and then I get this message everytime I reset the tpms like on pic #3 .. and this is everytime I get in the car I have to drive but keeps doing the same odd thing.. any one that had this problem before?
    thanks
    Attached Thumbnails Attached Thumbnails TPC inactive system learning-tires.jpg   TPC inactive system learning-tpcm.jpg   TPC inactive system learning-rarotpcm.jpg
    PetroGuy's Avatar
    PetroGuy is offline Porsche Prophet
    May 2011
    Golden, CO
    Re: TPC inactive system learning
    I've been having the same problem with my car, except it doesn't ever go back to normal. Does anyone know a quick fix to this problem? I tried leaving my car battery disconnected overnight and it didn't help at all.
    Thanks,
    PetroGuy
    '07 Porsche Cayman S - I LOVE it!
    Greywolf is offline Site Donor
    May 2008
    IN
    1,287
    Not sure if there's a quick fix. My '08 required a reprogram of the TPMS computer and a new wheel sensor to get it happy again. Fortunately under warranty.
    Before taking it in I tried the switch tire types to force a relearn, raise and lower tire pressures routines that I found here by searching to no avail.
    Les
    rsfdoc's Avatar
    rsfdoc is offline Site Donor
    Fl.
    78
    Having same issue for 3 weeks with my '06 S. Have tried different things but nothing seems to change. Off to the dealer next week. Thankfully have a CPO until 2012.
    PistolPete's Avatar
    PistolPete is online now Super Mod
    11,448
    5262
    76
    The batteries in the TPMS sensors have a limited lifespan (5-7 years as I recall). As always, some will last longer than others.
    I suspect some of the 06 and 07 model year cars equipped with TPMS will start to see strange symptoms soon.
    I see that solrac6262 has an 08, if you're still under warranty, take it in quick before it runs out.
    Pete
    2008 Meteor Grey Cayman S
    PetroGuy's Avatar
    May 2011
    Golden, CO
    I've done a little bit more searching to a solution and some say that resetting the TPMS computer might help. I wasn't able to find out how to do the reset in my manual.. Does anyone know how to do this?
    rsfdoc's Avatar
    Fl.
    78
    Just got car back from dealer. Battery on wheel sensor at zero. Remainder of sensors (other 3 wheels) OK with minimum of 22 months left on charge. Apparently have technology to measure remaining? They removed tire from wheel and replaced sensor/valve for a grand total of $335 (warranty price to Porsche). My cost $0 thanks to CPO. Per adviser, private cost would have been close to $400. Hmmm, for these kind of parts/repair costs, got me thinking about a newer CPO CS before the warranty wears out in March.
  1. 12-12-2012, 07:33 PM
  1. tpc inactive after pagid yellow pads and non TPMS wheels/tires
    By p997s in forum 987 Cayman and Boxster Modifications
    Last Post: 04-21-2010, 02:38 PM
  2. TPC Stuck on "learning"
    By DC-Cayman in forum Porsche Tires & Wheels
    Last Post: 01-07-2009, 11:37 AM
  3. "TPC Inactive" code--how to fix?
    By Foulweather Jack in forum Porsche Tires & Wheels
    Last Post: 10-18-2008, 09:44 AM
  4. TPC Inactive Warning
    By Cayman Jason in forum Porsche Tires & Wheels
    Last Post: 11-13-2006, 03:49 PM
  5. TPC Inactive Warning
    By Cayman Jason in forum 987 Cayman and Boxster Chat
