Hey folks, once in a while we get a car that literally has every possible stone over-turned and this 2009 GT Silver one is most certainly it
Seriously, with an EVOMS EVT700 kit, a full TechArt Type II body kit, a full suspension over-haul (including all the RSS/SharkWerks links/arms and TechArt Noselift kit) and some HRE wheels this has to be my all-around favorite TT to date that we've done so I'd figure I'd share some of the fun
Go-Fast Bits:
Starting with the power gear, here's an EVT700 turbo set up with one of the EVOMS boost recirculation valves on it:
On go the turbos, EVOMS VTG headers, upgraded intercoolers and hose kit:
We also went with the Cargraphic Loud exhaust and its HJS high-flow cats. Great, great sound as many of you can attest.
It also has the IPD
plenum and new Y-pipe kit on it:
The TechArt Type II & body..
Starting with the Tail... The Type II rear wing is not only aggressive looking but it's actually quite functional too with the two fresh-air inlet ducts feeding more cold air into the airbox than the stock wing at higher speeds. We painted the inlet ducts black:
Here you can see the decklid/wing installed and with the factory fan etc... all in place.
The rear wing fits perfectly as with all TechArt body parts:
The TechArt Type II rear bumper kit comes with new intercooler shrouds that need to be modified to fit the larger EVOMS intercoolers:
Before installing it we also had to transfer/re-locate all of the rear parking sensors too (not fun
Also there's a neat lower valence that's part of the kit.
