United Kingdom, Ireland Region Discussion for members in the UK & Ireland, local events, etc. |
01-08-2009, 10:55 AM
Possible CS at 911Virgin.com
Hello,
Still on the hunt for a car at the right price ...
Anyone have any opinions on the following car at the above indi? Or any experience with said indi. (PM is appropriate)
Cayman 3.4S. 6 speed manual gearbox. 2005 55-registration. First registered 29/11/2005. Finished in Arctic Silver with Ocean Blue leather. A huge list of cost options totaling £10,500 meant an original purchase price from Porsche Centre Nottingham of £55,000!!!. Fitted with Porsche Ceramic Brakes (PCB), tyre pressure monitoring, hard backed sports seats, BOSE, Sport Chrono, Cruise Control, CDR24 cd/tuner, PSM (Porsche Stability Management) on-board computer, full climate controlled air conditioning, heated seats, Litronic headlights with headlamp wash, rear wiper, Porsche over mats and Traffic Master TrackStar security. All the usual power steering, ABS braes, electrics and so on. Supplied with Main agent service history from new. In amazing condition throughout. With unmarked alloys, an unmolested interior and gleaming paintwork. One of the nicest examples available. 16,900 recorded miles. £29,995
Many thanks.
Cuch
01-09-2009, 06:02 AM
Re: Possible CS at 911Virgin.com
Looks like excellent value, even given current climate. If you're in the market for a PCCB car, this is pretty much a no-brainer. There's almost none out there on sale and this one is up for a decent price. If it didn't have PCCB, I'd say the price is not bad, even for 911Virgin (who is a reputable dealer, even if he is a little unconventional). Bare in mind 911V is not an official dealer, and he sells the cars practically as they're sold to him. With that spec, I'd personally prefer PASM included in on the spec sheet, but all in all it looks like a fabulous offer.
01-09-2009, 06:35 AM
Oh ****! Did not realise that it did not have pAsm!
As for the PCCB, not really fussed ... Would rather not have it .. But it has to have PASM.
Oh well ... Back to the classifieds
Many  for the heads up
01-09-2009, 08:05 AM
Agreed that PASM is worth having but hard to find on used Cayman S cars
How about this car that has been on Pistonheads for two to three months?
Stirlings Passion For Porsche Perfection : Cayman S 7000 Miles
01-09-2009, 08:19 AM
 for that.
Not sure where they are based as I could not see an address on their website. Google seems to indicate that they are in Cornwall! - Am in West Sussex. I would need to have a "touchy feely"  session with the car before deciding mind.
They say they can fit PCM Sat Nav. Any ideas as to how much something like that would cost?
I guess retro fitting the Sports Chrono Pac is out of the question?
TIA
Cuch
01-09-2009, 08:25 AM
'Yellow Peril'
Originally Posted by Cuchillo
 for that.
TIA
Cuch
This is Where they are...............
We are near Uxbridge, just off junction 1 of the M40 or junction 16 of the M25.
porsche sales. used porsche for sale uk. Porsche 911. Porsche Boxster. Porsche 944. Porsche 928.
Cheers Karel
01-09-2009, 08:33 AM
Sorry.
Ment Stirlings.
01-09-2009, 09:50 AM
ARe you pt ex
I was going to sell mine then I changed my mind when i advertised it lol
But I would sell her to some one who was not pi55ing me about.
Its very top Spec and all the Sports options and PASM and PCM
etc etc was 53k, its unmarked not been tracked is garaged and has no bumps or any issues.
Porsche fitted the quick shift for me a few months back also.
And it has xenons which seem a rare option but are so sweet.
I have just fitted new Disks and Pagid rs42 pads front and rear, done prob 100 miles on them as the car is off the road atm.
PM me if you are serious, as if I stll have her by Feb its having some money spent on it ready for the summer and a keeper.
Save the cheerleader save the world
01-09-2009, 10:11 AM
PM sent
01-10-2009, 03:29 PM
Mark from Stirlings is a top guy and well worth a call
01-11-2009, 12:32 PM
Sent an email a couple of days ago. Waiting a replay.
