Clearing out stock
Up for grabs are Toyo Proxes R888 shaved competition tires used for only 1 track day
These are by far the best tire for street and track use.
Hook like a drag radial, corner like a PZero Rosso
UTQG is 100 AA A
Setup guidelines:
Operating Temperature: 140°F to 220°F, optimum around 200°F
Hot Inflation Pressures: High 30s to Low 40s (psi)
Camber: -2.5° to -5.0°
Caster: As much positive as possible
If you set and heat these tires up you'll have trouble spinning them so you'll get all your power to the road
Tires will have some pickups and will be near or touching the wear bars due to the shaving.
Guaranteed no punctures or mounting issues.
These will last you roughly 3-5k miles of spirited street driving to the cords, ideal for dry hot pavement, weaker in the rain. the more you drive these tires the more contact you'll have till you're effectively on slicks.
Available sizes are as follows:
235/45R17
275/40R17
315/35R17
265/35R18
275/35R18
285/30R18
295/30R18
305/35R18
335/30R18
MSRP for new shaved R888's is around 465USD
All these Toyo's are priced at 130USD each shipped to your door in the continental USA
2 for 250USD shipped to your door in the continental USA
4 for 475USD shipped to your door in the continental USA
Select availability of used Hoosier A6 and R6 may also be available.
Select availability of used Kumho V710 may also be available.
Contact information removed - No Unsolicited Advertising Allowed.
Paypal only please
Thanks for looking.
335/30R18 pictured
