Bug that shows up for some reason from time to time, I'll have to manually edit those accounts. I've had to do this a few times since we migrated, not sure what the cause of the bug actually is.
And Discovered that Ken Smiley - is No Longer the Biggest Poster!
(How Can that Be?)
fjpdds HAS 4,294,967,285 Posts (Although you can Only Read 3 of them)
KMN BRAT HAS 4,294,967,283 Posts (None Available to Read)
HAS the CaymanClub been Hacked Into? Or Just a BUG?
It is interesting to note that 2 to the power of 32 (ie., maximum 32 bit integer value) is 4,294,967,295. That would make these counts small negative integers possibly. Looks like there is a bug where something is counting backwards.
It is possible, I guess, that if they had zero posts in the forum that if they make a post in the gallery or classifieds it is supposed to add to their post total, but possibly if one of those add-ons reduced that number for say a photo or ad that was removed maybe it changed it to -1 which then got changed to the higher number. Obviously something happened with each, but I don't know what exactly to cause it to happen. I've reported it to our developer to take under advisement.
2 to the 32 power is actually one more than 4,294,967,295 the number ends with 296.
Computers start counting from zero, so there are 2 to the 32 integers starting with 0 (if the computer uses 32 bit integer representation). The 4,294,967,296th integer value counting in this fashion is actually 1 less.
This does bring up another point. I am frankly a bit embarrassed at time by the sheer volume of posts I have generated over the years. Any way to hide my total?
Change your identity and start posting intelligent comments. We won't have a clue that it's you!
And I am not familiar with what either might have done over the last couple of weeks to generate that. Let me go take a look and see again. The developer has this on their "to do" list of items to fix...
