Selections in Vehicle Info menu
Results 1 to 2 of 2
Thread: Selections in Vehicle Info menu
    Jul 2013
    Pennsylvania
    420
    86
    Question Selections in Vehicle Info menu
    I leave the Vehicle Information screen on in the instrument panel by default, mostly to observe the oil temperature (I drive more gently until that one gets out of the blue zone).
    I chose water/coolant temperature, oil temperature, oil pressure and voltage as the four selections, which mostly means that I don't watch the turbo boost gauge.
    Any comments on this? I wasn't sure what I would do with that information, although you could say the same about some of the gauges I did choose.
    I think most of the time the boost gauge shows a value above zero, it's when I'm paying more attention to the road that the gauges.
    Aug 2017
    Ohio
    179
    44
    Re: Selections in Vehicle Info menu
    Quote Originally Posted by paylors View Post
    Oil, coolant, boost, and I forget the 4th one (compass?).
    With the boost gauge on, you can really see the difference in boost usage with the 3 drive modes (Normal, Sport and Sport+).
    Normal: No boost used unless you really put your foot down
    Sport: more low-end grunt (without boost), but then boost kicks in a lot more readily than Normal
    Sport+: Boost hits 1-2psi as soon as you even tap the accelerator (almost like it's pre-spooling the turbo) and almost always is in at least 1psi of boost.
    2017 718 Cayman - GT Silver, Black/Bordeaux Red, PDK/PSE/Sport Chrono
  4. Remove Advertisements
  1. Ban All Non-Emergency Cell Phone Use in Vehicles?
    By RSS_feed_bot in forum The Polk Blog
    Last Post: 12-15-2011, 09:29 PM
  2. Replies: 0
    Last Post: 12-10-2011, 07:20 AM
  3. Where is the Aftermarket In-Vehicle Infotainment Industry?
    Last Post: 06-10-2011, 06:30 AM
  4. Innovative In-Vehicle Electronics for Current and Future Cars
    Last Post: 06-11-2010, 06:10 AM
  5. "Front Spoiler Lip Painted in Vehicle Color" in '06 Cayman
    By YoungTurk in forum 987 Cayman and Boxster Chat
    Last Post: 05-04-2009, 11:35 AM
