SOUL | 718 Valved Exhaust and Downpipes
Results 1 to 10 of 10
Thread: SOUL | 718 Valved Exhaust and Downpipes
    Hey everyone! We're happy to have expanded our Boxster / Cayman exhaust lineup into the 718 realm! Have a look below at our Valved Exhaust and downpipes below.
    We'll be looking at a single pipe design from turbo to tips in 2019. We have first hand experience with such a system, and have been taking in feedback. We're going to make it so it is as aggressive as possible while attenuating negative qualities, like rasp and drone, to the best of our ability.
    We will be doing more testing and videos with various models to get a nice catalog of data. If anyone is interested in getting dyno numbers from a reputable shop, we'll pay for the dyno runs. We believe in getting third party, repeatable, realistic results and we won't be making up any power claims without proof. Contact us regarding that.
    That said, we're always here to help in any way we can. Our contact info is at the bottom of the page, just let us know how we can help!
    -Mike Spock
    Marketing Manager
    SOUL VALVED EXHAUST
    MSRP: $2,995.00 – $3,145.00
    Click for Product Page
    DEVELOPMENT:
    Our goal was to offer a valved exhaust that delivers a refined cabin presence. It is easy to increase the volume of the 718, but a challenge to bring out a more aggressive note while making the flat four sound distinctly Porsche which is a common complaint. The turbo and large amount of sound deadening in the 718 do a great job of keeping the cabin calm, but raising the volume to compensate can bring out negative notes in the exhaust such as rasp and drone. We applied the same design principles as our renowned Valved Exhaust line for previous Boxster / Cayman generations to deliver a refined increase in sound that will also pair well with an upgraded, freer flowing downpipe to yield a mature exhaust note without ever being overbearing. This is a superior option for cars not equipped with the Porsche Sport Exhaust from the factory.
    CONSTRUCTION:
    Each system is made from mandrel bent T304L stainless steel tubing (featuring 2.5″ OD over axle pipes) and features mufflers with fortified casings in the interest of durability. With valves closed the exhaust gasses are routed into the SOUL muffler, which is packed with high quality sound deadening material designed to withstand abuse and not blow out over time. The mufflers are incredibly effective at minimizing drone. Exhaust gasses make their way through the muffler and out through perforations into the outer piping. With valves open, exhaust gasses are now free to exit out through large 2.5″ piping while perforations allow exhaust gasses to “talk” with the muffler, encouraging a fuller, more robust tone.
    SOUND:
    You could describe the sound experience as PSE Plus! The tone in the cabin with valves open is about the same as PSE, not intrusive at all. Under heavy load the volume difference is noticeable, more aggressive while still refined. With valves closed, you can carry on a phone conversation on the highway without any intrusion from the exhaust. When paired with an upgraded downpipe / catalytic converter the exhaust offers a respectable level of snarling and crackling without droning at all RPM and throttle loads. Sport mode unleashes an increase in crackles and burbles.
    VALVE OPERATION:
    A valve controller is included with every system and is required for non-PSE cars. PSE equipped cars will retain full factory functionality by using the factory vacuum lines. The valve controller is optional for PSE equipped cars and allows full valve control at all times. Valve functionality can be controlled by the factory PSE button, included valve controller fobs, and with HomeLink buttons.
    TIPS:
    Choose from several different tip styles and finishes. Single wall tips have around a half inch of depth adjustment to allow for the tips to be sunk in to just show the logo at their deepest and pulled out more if desired. Double wall chrome tips are longer in length by 1″ and protrude from the bumper aggressively. Logo customization is available, please contact us.
    ________________________________________________
    SOUL SPORT CATALYTIC CONVERTER
    MSRP: $1,995
    DEVELOPMENT AND TESTING:
    The 718 is rather quiet in factory format. Replacing the restrictive factory catalytic converter with a freer flowing unit adds to drivability and also unlocks the sweet sounds of the turbo without adding any negative notes to the overall exhaust tone. The HJS HD 200 cell catalytic converter and smooth mandrel bent piping ranging from 90mm down to 55mm upon exit encourages better throttle response and a more exciting exhaust note. Easy to bolt in with no modifications required, this is a great, reversible solution to make your Boxster or Cayman more exciting.
    CONSTRUCTION:
    Each downpipe is assembled out of mandrel bent, thick wall T304L stainless steel, then rigorously quality checked. Back purged TIG welding ensures proper weld penetration and longevity.
    HJS CATALYSTS:
    The highest quality catalytic converters available, known for their industry leading flow and durability. They are efficient enough to meet strict EURO 4 emission standards while still allowing for an increase in flow – all without a check engine light. The HD design uses premium triple foil winding for maximum strength. The brazing stripe is an extra feature in the interest of durability – it prevents the core from moving or experiencing any damage from sustained high horsepower abuse. The 200 cell design uses a premium wash coat of precious metals to achieve a high level of effectiveness at catalyzing even with the increase in exhaust flow. We cover our HJS catalytic converters with an unprecedented 3 year warranty while the materials and workmanship are backed by our Lifetime Warranty.
    SOUL COMPETITION DOWNPIPE
    MSRP: $1,395
    The 718 is rather quiet in factory format. Eliminating the restrictive factory catalytic converter adds to drivability and also unlocks the sweet sounds of the turbo with a major increase in snarling and crackles from the exhaust. The sound is aggressive without droning in the cabin. Smooth mandrel bent piping ranging from 90mm down to 55mm upon exit encourages better throttle response and a more exciting exhaust note. Easy to bolt in with no modifications required, this is a great, reversible solution to make your Boxster or Cayman more exciting. We highly recommend an ECU tune with this modification to prevent boost spikes that result from the major increase in exhaust flow.
    https://www.youtube.com/watch?v=AS4dxryPBco
    PACKAGES ARE AVAILABLE pairing both Valved Exhaust and downpipe of your choice for a $245 discount!
    SOUL COMPETITION PACKAGE
    SOUL STREET PACKAGE
    SOUL PERKS
    LIFETIME WARRANTY:
    Enjoy your SOUL exhaust parts with confidence on both the street and track as they are covered by our Lifetime Warranty. Yes, we mean it...a full warranty for track use! Our team will quickly work with you to resolve any issues or answer any questions that you may have.
    PACKING:
    We foam pack every product to ensure your components arrive in perfect condition.
    CUSTOMER SERVICE:
    We are standing by to help in any way we can - pre sale and post sale, just let us know. No customer left behind, ever!
    We are here to help in any way you can. If you have questions, need assistance, or would like to place an order we are always willing to chat with you!
    IN STOCK AND READY TO SHIP!
    Contact us any time with questions, customization requests, to order, or find your nearest SOUL dealer / installer
    Email: [email protected]
    Phone: 855-486-1400
    IG: @soulperformanceproducts
    SOUL PERFORMANCE PRODUCTS
    Outstanding Exhaust Solutions, Fair Pricing, and Quality Service
    https://soulpp.com
    (855) 486-1400 info@soulpp.com
    Sep 2016
    TX
    48
    Re: SOUL | 718 Valved Exhaust and Downpipes
    Wonderful product Soul Performance!
    Link to some stationary video of my cayman with AWE track exhaust and AWE Track Exhaust w/ Soul Performance Downpipe.
    Quote Originally Posted by mattchow View Post
    Thank you, Matt! She sounds great!
    -Mike
    https://soulpp.com
    We've got everything in stock, ready to ship! Let us know if you have any questions. We're happy to take a phone call and chat with you about all options and your mod plans. 855-486-1400
    -Mike
    https://soulpp.com
    Any questions about our components?
    -Mike
    https://soulpp.com
    We've just received a dyno sheet from Growler Motor Labs for before and after numbers for a 718 base Cayman with SOUL Sport Catalytic Converter. Peak gains of 14 whp and 24 ft-lbs of torque! A JB4 is on the horizon along with a custom tune to get even more power - hopefully we will have further dyno information then.
    Video: https://www.instagram.com/p/BvPmhmkpEl5/
    -Mike
    https://soulpp.com
    Dec 2006
    113
    Quote Originally Posted by Soul Performance Products View Post
    -Mike
    Nice gains from DP alone. That’s very tempting. Why the JB4 when ECU is available from Cobb? Curious because I was considering the JB4. Thx.
    Current:
    2013 Odyssey / 2013 TTS / '17 Wrangler Willys
    Previous:
    2002 S2000 / '11 Cayman / '12 GTI / 2002 targa / '87 Wrangler / 2007 RX8 / 2006 GTI / 2006 A3 / 2003 WRX / '00 TDI / '87 RX7 Turbo / '84 RX7 GSL-SE / '82 RX7 / '78 280Z / '77 Buick
    Quote Originally Posted by Optical TDI View Post
    Thank you! It came down to the customers choice. He's had experience using JB4 in the past.
    -Mike
    https://soulpp.com
    In stock and ready to ship, any questions?
    -Mike
    https://soulpp.com
    Two fresh sets of tips out of our custom shop - Satin black PVD coated tips with a custom GT3 logo and gold PVD coated Cayman tips. Feel free to choose your logo and finish with our tips!
    -Mike
    https://soulpp.com
  13. Remove Advertisements
  1. SOUL | Porsche 986 Boxster Valved Muffler Bypass Conversion
    By Soul Performance Products in forum Pistol Petes Boxster Board
    Last Post: 05-22-2019, 01:36 PM
  2. SOUL | GT4 Valved Exhaust
    By Soul Performance Products in forum 981 Cayman GT4 Chat
    Last Post: 05-16-2019, 08:07 AM
  3. Replies: 4
    Last Post: 05-17-2012, 10:27 AM
