Flapping buttresses
Results 1 to 8 of 8
Thread: Flapping buttresses
    Oct 2013
    Michigan
    117
    57
    Flapping buttresses
    I am finding that when I put my top up one of the buttresses keeps popping out. Does anyone know an easy fix for this?
    Oct 2010
    1,261
    130
    500
    99
    Re: Flapping buttresses
    I would check for dirt and wear on both pieces. I've had this happen once but it was operator error, I hadn't pushed the buttress end into the body socket firmly enough to get the click.
    2014 Mazda 3 DD
    2015 Cayenne Diesel
    2016 Spyder
    Jan 2013
    Massachusetts
    344
    80
    I have had no problems with my Spyder, but I rarely put the top up. Previously there was a post by another Spyder owner who had one of the fasteners come undone at speed. The flapping piece resulted in damage to the body. It turned out that the fastener was defective.
    I would certainly get it checked out.
    williamr
    Nov 2009
    CO
    132
    Make sure that when inserting the buttress end into the body socket you get an audible click as well as confirming that the red indicator tab is recessed.
    Jan 2012
    NJ
    1,587
    432
    761
    I notice that if my trunk is completely closed when i go to click in the butresses, it is much more difficult to get a good 'catch'. when putting my top up, i barely engage the front latch, leave the trunk cracked and insert the buttresses, fully close the front latch, and then push the trunk shut the last final bit. Never had an issue with a buttress popping loose as a result. maybe thy that if you are not doing it already?
    981 Spyder
    Nov 2009
    CO
    132
    Agree- the key is to take some of the stress off of the buttresses while engaging the snaps. I do the opposite: Pull up the top to the front windshield with the rear trunk cracked, engage the flaps, close the trunk, then engage the electric motor to lock everything down.
    Oct 2018
    Quote Originally Posted by Tanajib View Post
    ...as well as confirming that the red indicator tab is recessed.
    Red tab indicator? Where the hell is that?
    Nov 2009
    CO
    132
    Quote Originally Posted by SpyderSenseOC View Post
    It is on the bottom of the tab. When properly engaged, the red tab is recessed. See attached Porsche bulletin.
    Flapping buttresses-porsche-top-fins-jpg
  11. Remove Advertisements
  1. Flapping noise at high speeds
    By UTICaymanS in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 04-22-2009, 09:23 AM
  2. Flapping Sound
    By rcharlebois in forum 987 Cayman and Boxster Chat
    Last Post: 08-14-2007, 09:30 AM
