At what point do you invest in a head and neck restraint?
Results 1 to 9 of 9
Thread: At what point do you invest in a head and neck restraint?
    Mar 2016
    34,114
    33
    This is likely a stupid question but I'm going to ask anyways. It is clearly not required at the track events I have attended (not referring to club racing). I do see drivers with them but they all appear to be driving a dedicated track car (e.g. racing seat, 5 or 6 point harness, etc.) which makes sense to me since presumably these cars do not have air bags. But as I am driving my car with air bags does it still make sense?
    Omaha
    1,761
    80
    459
    Re: At what point do you invest in a head and neck restraint?
    It's not necessarily the airbags that's the reason for using a HANS but the seat belts. PCA now requires you to use a HANS if you have a 5 or 6 pt belt because they (the belts) stop your momentum immediately. If you're not wearing a HANS, your head will not stop and we know how that ends. A passenger seat belt will not restrain you as well and will work in conjunction with the airbag.
    I don't know if there are HANSs designed to work with passenger belts. The racing versions work with the duel shoulder belts to hold them in place. It's a good question you ask. My initial thought was how high speed do you go on your particular track, but then I decided coming to a sudden stop at even 50mph could be catastrophic so there probably isn't some mph crossover where you should or shouldn't have one.
    PCA National HPDE Instructor
    2008 Cayman S Sport
    Nov 2008
    Houston
    1,033
    203
    Just me but I don't get in a car on a track without a head-neck restraint. With 6pt harness I usually use a HANs. For cars with only 3pt belts I use a Simpson Hybrid. The Simpson is to my knowledge the only device tested with 3pt belts in the FMV crash test. Even with 3 pt belts it reduces neck tension in a frontal crash. Lots of sources to purchase these- Apex, OG, Stable energies and others. Worth considering for HPDE. And not at all a stupid question!
    2008 911 Carrera S (sold)
    2009 Cayman 2.9 (sold)
    2012 Cayman R
    2004 Boxster S
    2015 GT3
    Jan 2014
    New jersey
    33
    On the day you find yourself on the slippery slope. With 3 point seat belt, buy a Simpson Hybrid or one of the other one or two rated brands.
    I have moved up into a six point harness and still use the hybrid.
    Aug 2016
    86
    if you have a standard 3-point harness and get in an accident, then your body will move a little and then your head, and the airbags work in conjunction. if you have a 6-point harness, your torso is locked down and only your head moves. To make this worse, the weight of the helmet adds to the weight of your head, which increases the inertia, and your neck is not strong enough.
    If I have to wear a helmet, then I also want to wear the Hans.
    Sep 2015
    Ohio
    140
    Airbags are the “pre HANS”. Anyone wearing a HANS with a 3-point and airbags is just throwing money away and is having to deal with an inconvenience with the device. Disclosure-this is my opinion and I am not in any way endorsing one side or the other.
    Nov 2008
    Houston
    1,033
    203
    Quote Originally Posted by Porschebab1 View Post
    I'm not sure about this. I'm not an expert but a clear difference is the additional mass of the helmet. Human head is about 10lbs, and a typical full face helmet is 3.5, so a 30+% increase in mass. I don't know how much difference that may make relative to the design of the 3pt belt/airbag safety system. For me, it's enough of a concern that it's worth the cost and inconvenience of the hybrid system.
    2012 Cayman R
    2004 Boxster S
    2015 GT3
    Oct 2016
    TX
    195
    I don't have one yet, but I'm seriously considering a Simpson Hybrid S.
    Here is a link to the Simpson web site with some relevant test data: https://simpsonraceproducts.com/hybr...lt-compatible/. There is a webinar link on the Quick Links tab where they go into some of the design and testing details.
    2014 Boxster S - Racing Yellow, Sport Chrono, PASM, PTV, PDK, 3rd radiator (Pagid RSL29's & Nitto NT-01's on the track)
    Apr 2015
    SoCal
    583
    65
    135
    Ask 100 drivers, get 100 very different answers. I sat on the PCA Z8 safety committee for 7 years and we discussed this a lot.
    My thoughts (not recommendations):
    * An older car 96 or earlier with limited OEM driver safety or a stripped out track car, I prefer racing seats, harnesses, roll protection, HANS, and fire protection (suit and fire suppression). All of this works together as a well-proven driver safety system.
    * A modern reasonably stock car with full interior, 3 airbags per occupant, OEM 3pt belts, OEM hardened steel cabin structure and roll protection, offers a lot of driver protection and I don't feel the need for a fire suit or harness/HANS. Note: Others struggle with this but the data is pretty clear that injuries during a PCA DE day in one of these cars is vanishingly low.
    * Stuff I no longer find acceptable:
    -4pt harnesses without full ASM technology.
    -5/6 pt harnesses without a proper racing seat, HANS, roll protection, and fire protection as a complete safety system.
    Improperly installed harnesses, or a harness without racing seat, HANS, and roll protection, have resulted in multiple deaths at race tracks in the US over the last 5 years. A partial safety system is as good as no safety system so do it right or don't do it at all. JMHO
    2009 Cayman 2.9L PDK with a few tweaks
    PCA-GPX Chief Driving Instructor
    PCA National DE Instructor
  12. Remove Advertisements
  1. Self Restraint
    By JCCc in forum 981 Cayman and Boxster Configurations and Ordering
    Last Post: 11-18-2013, 09:06 AM
  2. Would you invest in building a new F1 racetrack?
    By qhb in forum Automotive Off Topic
    Last Post: 04-19-2013, 06:26 PM
  3. Replies: 0
    Last Post: 07-23-2010, 07:42 AM
  4. R3 and head restraint question
    By ndporsche in forum 987 Cayman and Boxster Competition
    Last Post: 07-11-2007, 01:36 PM
