Restocked Wheel Spacers And Lug Studs!
Results 1 to 6 of 6
Thread: Restocked Wheel Spacers And Lug Studs!
    Jul 2013
    3,819
    114
    805
    We just restocked on our top selling wheel spacers and lug studs!
    Widen your track for better traction and cornering, or to provide more clearance for wider tires, or to just make your car look better with our wheels spacers!
    Our wheel spacers are available with either extended wheel bolts, or with Schnell Autosports' lug stud conversion kit for proper and safe installation.
    Both options include countersunk rotor screws for securing the 7mm rotors to the hub.
    Wheel spacer installation writeup: Schnell Autosports - European OEM/Aftermarket Parts + Racing: Wheel Spacer Installation
    To place an order please give us a call at 1888-978-9899 or visit our website.
    If you have any further questions, feel free to ask us on our contact page!
    *Prices do not include shipping or any applicable taxes.
    your one stop shop for car care, parts and racing equipment for your porsche
    Jul 2013
    3,819
    114
    805
    Re: Restocked Wheel Spacers And Lug Studs!
    Schnell Autosports 7/15 Hubcentric Spacer Set!
    Widen your track for better traction and cornering, or to provide more clearance for wider tires, or to just make your car look better!
    Wheel spacers are available with either extended wheel bolts, or with Schnell Autosports' lug stud conversion kit for proper and safe installation.
     (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/205715d1550021808-restocked-wheel-spacers-lug-studs-7-15mmspacerpackage-2_1-jpg)https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/205717d1544058315t-restocked-wheel-spacers-lug-studs-7-15-jpg (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/205717d1550021833-restocked-wheel-spacers-lug-studs-7-15-jpg)https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/205715d1528298523t-restocked-wheel-spacers-lug-studs-7-15mmspacerpackage-2_1-jpg (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/205715d1550021808-restocked-wheel-spacers-lug-studs-7-15mmspacerpackage-2_1-jpg) (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/205717d1550021833-restocked-wheel-spacers-lug-studs-7-15-jpg)
     (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/205719d1550021852-restocked-wheel-spacers-lug-studs-7mm-2_1-jpg)https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/205721d1528298523t-restocked-wheel-spacers-lug-studs-15mm-2-jpg (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/205721d1550021869-restocked-wheel-spacers-lug-studs-15mm-2-jpg)https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/205719d1528298523t-restocked-wheel-spacers-lug-studs-7mm-2_1-jpg (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/205719d1550021852-restocked-wheel-spacers-lug-studs-7mm-2_1-jpg) (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/205721d1550021869-restocked-wheel-spacers-lug-studs-15mm-2-jpg)
    Jul 2013
    3,819
    114
    805
    If you're tired of the juggling act of holding your wheel up to keep it from falling straight down while taking off that last bolt, or holding your wheel up and trying to keep the holes aligned while you put in the first bolt, we have the solution for you.
    Schnell Autosports offers a lug stud conversion kit, which converts your stock lug hole/lug bolt setup to a more familiar (and easier to deal with) lug stud/lug nut setup. Our conversion studs also feature an unthreaded portion at the end of the stud, to allow you to easily guide your wheel and lugnuts on without risk of cross-threading or damaging the threads on the stud.
    Schnell Autosports Lug Stud Conversion Kit
    Find out more information here.
     (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/206195d1551749217-restocked-wheel-spacers-lug-studs-12-jpg)https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/206197d1551749244t-restocked-wheel-spacers-lug-studs-5_1-jpg (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/206197d1551749244-restocked-wheel-spacers-lug-studs-5_1-jpg)https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/206195d1551749217t-restocked-wheel-spacers-lug-studs-12-jpg (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/206195d1551749217-restocked-wheel-spacers-lug-studs-12-jpg) (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/206197d1551749244-restocked-wheel-spacers-lug-studs-5_1-jpg)
     (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/206199d1551749280-restocked-wheel-spacers-lug-studs-13-jpg)https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/206201d1551749344t-restocked-wheel-spacers-lug-studs-10-jpg (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/206201d1551749344-restocked-wheel-spacers-lug-studs-10-jpg)https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/206199d1551749280t-restocked-wheel-spacers-lug-studs-13-jpg (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/206199d1551749280-restocked-wheel-spacers-lug-studs-13-jpg) (https://www.planet-9.com/attachments/987-cayman-and-boxster-modifications/206201d1551749344-restocked-wheel-spacers-lug-studs-10-jpg)
    Oct 2013
    TX
    330
    416
    114
    I've had the Schnell 7/15 spacers for almost 5 years and the car looks so much more aggressive than stock. They become more than a cosmetic upgrade during track time.
    2013 Boxster S, PDK, Sport Chrono, Cobb 93 tune, Soul Valvetronic exhaust, Schnell rear lower support bar, Schnell 7mm & 15mm spacers, Porsche center radiator, ... rear view camera may be next, or headers, yeah headers, that's the ticket.
    Jul 2013
    3,819
    114
    805
    Jul 2013
    3,819
    114
    805
    We've just stocked more of our popular wheel spacer sets! Place an order today!
    One set (two 7mm spacers and two 15mm spacers) of high quality CNC machined hubcentric wheel spacers for your car.
    Other wheel spacer options here.
    Installation is easy! writeup: Schnell Autosports - European OEM/Aftermarket Parts + Racing: Wheel Spacer Installation
  9. Remove Advertisements
  1. Restocked Wheel Spacers And Lug Studs!
    By SchnellAuto in forum 987 Cayman and Boxster Modifications
    Last Post: 06-19-2019, 05:52 PM
  2. Schnell Autosports Wheel Spacers and Lug Studs
    By SchnellAuto in forum 981 Cayman and Boxster Modifications
    Last Post: 12-07-2018, 05:43 PM
  3. Schnell Autosports Wheel Spacers and Lug Studs
    Last Post: 12-05-2018, 06:07 PM
  4. Schnell Autosports Wheel Spacers and Lug Studs
    Last Post: 09-17-2018, 06:36 PM
  5. Replies: 0
    Last Post: 06-01-2018, 05:51 PM
