Base to sports steering wheel programming
Results 1 to 1 of 1
Thread: Base to sports steering wheel programming
    Feb 2019
    Hi all,
    New to the forum but have done some searching on the topic without definitive answers.
    I’ve recently installed a sports steering wheel with paddle shifters on my 14’ 981 CS. It’s does not have the sports chrono package. Only the Sport button. I’ve read on here other members were able to get the neutral to work after plug and play, while some needing PIWIS reprogramming. The “neutral” isn’t working on my set up currently. So I’m guessing I need to reprogram. Does anyone know the exact settings that needs to be done through PIWIS? I have an Indy shop here that has the system but I’d like to save time to tell them what exactly should be done to activate the neutral or the wheel itself entirely.
    I found this on the net (http://porschepiwistester2.blogspot....ction.html?m=1) but not sure If there’s additional work that needs to be done to have the neutral work.
    PS: through searching, I’m aware the lcd displays won’t work if I don’t have sports plus or chrono.
    Any help is greatly appreciated!!
    -Chuck
  1. New Steering Wheel from Dallas Custom Steering Wheel
    By angel29 in forum 987 Cayman and Boxster Modifications
    Last Post: 02-14-2017, 11:21 PM
  2. sports design wheel sports chrono spec
    By mrh1275 in forum 987 Cayman and Boxster Chat
    Last Post: 10-09-2011, 11:29 AM
  3. Replies: 0
    Last Post: 05-16-2011, 06:00 PM
  4. Alcantara STD steering wheel vs. GT3 Sport steering wheel
    By casualsurfer in forum 987 Cayman and Boxster Chat
    Last Post: 07-02-2009, 06:22 AM
  5. Sports Steering Wheel = More Room
    By Fiebru in forum 987 Cayman and Boxster Chat
    Last Post: 02-20-2006, 10:40 AM
