Engine cooling next step after 3rd rad. larger oil cooler or deep sump - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Engine cooling next step after 3rd rad. larger oil cooler or deep sump
  1. #21
    Sep 2013
    CO
    499
    89
    Re: Engine cooling next step after 3rd rad. larger oil cooler or deep sump
    Which "larger oil cooler" did you get from BGB? For the PDK or the engine?
    2014 981S, PDK
  3. #22
    Apr 2018
    MN
    futurz, the engine oil cooler
    I will report back when I hit my local track again on the difference since I do not have before and after from road america.
    2014 Cayman S gt4 front clip center radiator, gt4 side vents, gt4 rear diffuser, rss lca and toe links -2.7 F, -2.8 rear, re71r, ag lightweight wheels, fabspeed race headers and cobb tune, kw H.A.S springs, gt3 front bar, tarrett rear bar, techno brace, giro discs, ds1.11, custom brake cooling, macan paddle steering wheel...2018 was my first summer, love this forum, it helped me to deplete my savings account.
  4. #23
    Aug 2013
    Massachusetts
    124
    How difficult was the install? Is it plug and play?
  6. #24
    Jan 2016
    Washington
    690
    The BGB oil cooler you are installing, uses the same base as the water/oil exchanger, but has more capasity, like using a GT3 one? Did BGB give you details on how much larger the capasity?
    2007 SC, Bi Xenon, roof rack, red tail light kit, Ohlins R&T, Tarett Cup LCA's f&r, Tarett GT sway bars, down links, Elephant toe & bump steer links f&r, r toe locker plates, f slotted frame camber mount, Pedro's technolink brace, Function First orange motor mount insert, Numeric short shifter&cables, GT3 throttle body & Agency Power Plenum, EVOMS V-flow Intake, Milltek Muffler & tips, GT2 brake ducts f&r, Signature SV104 forged monoblock Black Chrome Powder coated 18 race wheels, RE71R's tires, LN deep 2 Qt sump & skid plate, Porsche Motor sports AOS.
  7. Remove Advertisements
  1. Deep Sump & Accusump Vs Deep Sump & Dual Tandem Scavenge Pumps?
    By Globespy in forum 987 Cayman and Boxster Modifications
    Last Post: 03-09-2019, 01:23 PM
  2. Replies: 6
    Last Post: 01-08-2014, 08:24 AM
  3. Any experience with the Suncoast Deep Sump Oil Pan Spacer?
    By lbk8950 in forum 987 Cayman and Boxster Modifications
    Last Post: 04-02-2012, 02:07 PM
  4. Mantis Sport Deep Oil Sump Extension
    Last Post: 03-12-2012, 02:10 PM
  5. FS BK R-9095 deep sump oil kit for 986/996
    Last Post: 04-11-2010, 08:00 PM
