981 base upgrade plan - feedback?
Results 1 to 1 of 1
Thread: 981 base upgrade plan - feedback?
    Jun 2019
    I have retooled my upgrade strategy for my Base 2.7L Cayman to get more for my money in the right departments.
    I've read that the X73 suspension is probably a better fit than trying to do a PASM like solution (DSC stand alone controller + Bilstein) and a lot cheaper.
    Also I have read Cayman's run hot for spirited driving and tracking in hot central California and I should look at*better engine and PDK cooling.
    I will get a better car handling and cooler running car. I'll do headers when I feel I need a bit more HP.
    SUSPENSION
    X73 Sport Suspension Kit (Suncoasticon kit - $1550)
    RSS 361 Front Lower Control Arms $1,200.00** *
    RSS 301 Rear Adjustable Toe Steer Kit $525
    RSS 333 Rear Toe Alignment Locking Plates $90
    COOLING
    CSF Center Radiator for more LN Engineering - $250)
    PDK oil water exchanger (LN Engineering - $1,000)
    OEM GT4 Front Fender liners (vent brakes - about $250/ea)
    BRAKES
    Braided stainless steel lines (FVD Brombacher - $185)
    Street Pads - Textar brake pads with Sebro sensors (Schnell kit - $240)
    Tract Pads - Ferodo DS1.11
    Castrol React SRF Brake Fluid
    AESTHETICS
    Aero Bumper Kit (Suncoast - $3,500 - will sell supplied OEM center radiator)
    HID low beam
    LED high beam
